My ice maker has become "unattached" to from the roof of where it supposed to be attached and is preventing me from removing the ice bin and reattaching. I can partially remove the bin just enough to get my hand inside of the bin but i cannot lift the ice maker up enough to remove the ice bin to reattach.
SOURCE: Ice Maker
Found in the FAQ section on Samsung.com:
Samsung refrigerator freezers produce about 120 cubes per day, which is in line with most manufacturer specifications.
Empty the ice tray and let the unit run for 24 hours.
If fewer than 50 cubes are produced during the 24-hour test, then your refrigerator requires service. Please contact Samsung Service at 1-800-SAMSUNG to schedule a service appointment.
If your freezer is producing 50 to 90 cubes per day, try the following:
If you want your freezer to produce more than 120 ice cubes in a day, try the following:
NOTE: If you have just installed your refrigerator, it will take 6 to 12 hours for the refrigerator to produce ice.
You should throw away the first three batches of ice cubes that the ice maker produces (approximately 30 cubes) to ensure the ice maker is making ice from clean water.
SOURCE: ice maker leaks inside freezer
check the water discharge hose which fills the ice maker after ice is dumped into the bin. the line is located in most cases at one end of the ice maker and allows the water to flow into a funnel like device above the ice maker mold. the hose has the diameter of a penny, it is probably misaligned with the ice maker itself/
SOURCE: Ice maker bin indicator arm is stuck in the bin is full position
You should be able to move it gently to the lower position. If it doesn't want to move don't force it. Try shutting the ice maker off in case the arm is frozen in the up position. After the ice maker defrosts a bit try again to move the arm gently.
SOURCE: ICEMAKER WILL NOT DUMP ICE
reset the power cool and freezer control buttons.first remove the ice bin then press the power cool and freezer control button for 12 seconds this will set the option which is shown under the fridge control button.set option to 3.wait for 24 hours then you will hear ice dumping in the ice tray.
