Programming procedure is very difficult to type in all here by this window. If you wish to get more details, check the sites linked here. It has setup code list and setup procedure to many popular brand remote controls. http://remotesearch.blogspot.com/ http://electrohelponline.blogspot.com/ http://electronicshelponline.blogspot.com/ Pull up previous posts, either by its left side bar, or view it in Mosaic / Timeslide option.
SOURCE: programming a universal remote control for a tv
The code for a Sanyo TV set should be 100. Press and hold the TV button on the remote while entering the code. The light should blink 5 times if it was accepted, and then you can test to see if it worked.
SOURCE: lost directions for universal remote control
sent to me by nextech....
Save Code list for future reference. Refer to the setup procedure below and look up the 4 digit code for your brand of TV, VCR, etc., from the list below.
1519001B, 1519002B, 1519003B, 1519006, 1519007 CL
Refer to the Owner’s Manual for your remote for more information.
Direct Code Entry
1.
Press and hold the
SETUP button until the
red indicator stays on,
then release the SETUP
button.
2.
Press and release
the desired Mode button
(TV, VCR, etc.). The red
indicator blinks, then stays
lit.
3. Enter the 4 digit code from
the code tables. Note: after
a valid code entry, the red
indicator turns off. For
an invalid code, the red
indicator flashes.
4. With your device on,
press CHANNEL UP. If
the device responds, no
further programming is
required. Note: If some
buttons do not operate
your device, try one of
the other codes for your
brand.
Note, when all codes have
been searched the red
indicator flashes rapidly for
3 seconds.
Code Search
If after trying “Direct Code
Entry” your device does not
respond, or if your brand is
not listed, try doing a search
of the code library for your
code by following the steps
to the right.
1. Manually turn on the
device (TV, VCR, etc.) to
be controlled.
2. Press and hold the
button.
3. Press and release the
desired Mode button
indicator blinks once, then
stays on.
4. Press the CHANNEL UP
button repeatedly (up to
300 times) until the device
to be controlled changes
channel. The red indicator
blinks, then stays lit.
5. Press and release MUTE
to install the code. The
indicator light goes off.
Most users will want to
store VCR codes under the
VCR button, Cable codes
under CBL, etc. If you want
to store a VCR code under
CBL, etc., first follow the
procedure for Direct Code
Entry and press CBL in step
2 of Direct Code Entry, then
enter ANY VCR code in
step 3 of Direct Code Entry.
Then follow the steps above
for Code Search.
Direct Code Entry
1.
Press and hold the
button.
2.
Press and release
lit.
indicator flashes.
brand.
3 seconds.
Code Search
to the right.
be controlled.
button.
desired Mode button
stays on.
for Code Search.
answer found at [email protected]
SOURCE: INSTRUCTIONS NEEDED FOR THE SHARPER IMAGE - JUMBO UNIVERSAL REMOTE
Hello kls1996... programming your remote is rather easy. The easiest way (thanks to The Sharper Image Jumbo Remote being a LEARNING SMART remote) is to do the following:
1 - Point the head of your Sharper Image remote at the head of your Sanyo TV remote (nose to nose so the clear bulbs on each remote are facing each other).
2 - Press the "TV" button on your Sharper Image remote (located in the upper left-hand corner).
3 - Hold the "LEARN" button on your Sharper Image remote (located in the left edge under the volume buttons) until the red light flashes.
4 - Press the key on your Sharper Image remote (e.g. Volume Up or +VOL)... the red light will go solid (indicating that it is waiting for a signal from the other (in your case Sanyo) remote.
5 - Press the key on your other remote (in your case the Sanyo remote) that you want programmed in your new Sharper Image remote... the red light will flash rapidly again.
6 - Repeat step #4 until you have programmed each key.
7 - When done... press the "LEARN" key on your Sharper Image remote. Your Sharper Image remote should be programmed to operate your device (in this case, your Sanyo TV).
NOTE: You can program other devices such as your VCR, DVD, VHS, SAT, CABLE, etc. and not just one device.
Code For Model RCR311S Code 1003 for Panasonic TV Code 1054 for Panasonic TV Code 1062 for Panasonic TV Code 1109 for Panasonic TV Code 1170 for Panasonic TV Code 1248 for Panasonic TV GOOD LUCK THESE ARE THE CODES LISTED FOR YOUR REMOTE/
SOURCE: I need to program ge universal remote jc024 for
I also lost the manual for my GE JC024 Universal Remote. I remembered though that you just hold in the button for the device you want to program and the "SETUP" button at the same time for about 5 seconds until the red light on the remote flashes and stays lit. then let go of the buttons.Then you basically just press and let go of the on/off button, pausing for a second or two in between presses until your device turns off. then you have to press the "ENTER" button and it'll store the code for that device. This method just cycles thru all of the possible codes for that device. sometimes you get the wrong code and the remote wont completely work. like hitting the volume button makes the tv mute for example. just repeat the steps until the device turns off again and eventually you should be able to get it. hope this helps.
