Question about Samsung Infuse 4G Smartphone
When I swipe to make a call the screenlight goes out and does not illuminate at the end of the call, thus I can't disconnect the call. I have to wait until the connected party hangs up to resume use of my phone. Sometimes this takes several minutes.
  • 3 Answers
I believe the phone is using the gyrospcope to sense if the phone is in a still position. Usually if you bring it down and flip it, the screen will undim and you can hang up. Root your phone and get a custom ROM if you want to get rid of this.
Posted on Jul 31, 2013
2003 XKR dashboard illumination goes off when main lights switched on or if dash lights do stay on after starting they go off when main beam is operated.
is this car the all alluminium xk model ? if so it sounds like a bad earth the earth studs are all bonded to the body and are prone to detatching from the body and causing all strange probs. the favorite ones are both front behind the wheel arch liners, if its the older xk still sounds like a bad earth poss behind the headlamps. the only other probs i had was wires coming detatched/poor connection from the column switch, hope this helps
Oct 03, 2016 | 2003 Jaguar Xkr
SS. My rear window defroster does not work, switch illuminates, connectors are on, grid has no cuts
check the Resistance between two end of the grids if OK,when switch illuminate, it only means power goes to solenoid,not out of it,possible bad solenoid
Dec 27, 2015 | 1987 Chevrolet Monte Carlo
My app won't work on my iPad mini when I touch it
As soon as your iPad starts acting strange, it is time for a reset.
you can do this by simply closing all running apps. Press the home button twice and then swipe all apps up. They are closed then.
If all apps are closed, press the on / off button and keep it pressed till it says swipe to shut down. Swipe and wait till everything is out.
Then press the on / off button again, for a second or so. The iPad starts again.
Somewhat drastic, if you can't switch it of the normal way: Press and hold both, the on / off button and the home button, till the screen goes dark.Then the apple loge appears and again wait till the screen is dark. After that you can switch on again.
If it still does not work, goto settings then general then scroll to the bottom, where it says reset. then reset network settings. It will reset your network settings, but also the rest of the iPad. This is the most dramatic reset, without loosing your apps and documents.
One step further will wipe your data too, so that you must keep for the worst case and only after you are sure you have a backup on your computer from all your data.
Apps can be restored from the App store for free, if you have payed for them, but the data, unless you have backups, will be lost fro ever.
Oct 21, 2014 | Apple iPad Tablets & eReaders
Battery drain on 1995 buick lesabre, where do you start to find it
Disconnect the red battery cable.Take a test light and hook 1end to the + batt post and the other end to the +batt cable. This will make the test light illuminate. Pull 1 fuse at a time until the light turns off. This will pin point the electrical circuit that has "parasitic draw". (be sure to reinstall each fuse that has no change)
Dec 26, 2012 | 1995 Buick LeSabre
Warning lights remain illuminated, Alero
First check for error codes (DTCs) to see if you can determine the problem.
Apr 16, 2017 | 2000 Oldsmobile Alero
does the anti-lock brake light come on too? and ive found the best way to reset codes manually is disconnect the battery terminals pos. and ground. then touch them together( the battery cable terminals) their is a copasitor that will store enough power to hold your codes in the ecm. this way you are essentially grounding the system to drain all residual power stores
Feb 09, 2012 | 2000 Oldsmobile Alero
I have a 2007 slk 280 and the srs light remains on. There was no problem prior to this just one day the srs light illuminated and never went out. Any possible solutions?
disconnect battery then feel under the seat for the wiring loom that goes to teh pyrotechnic on the seat belt ,clean the connection both ends with a black lead of a pencil then reconnect the battery and try it again if no joy then its a dealer only job as encrypted software used
Nov 17, 2010 | 2007 Mercedes-Benz SLK-Class
Screenlight on/off problem
Try turning up the brightness function key on the keyboard, I have had the same problem and this is certainly better.
Dec 16, 2008 | HP Pavillion ZV6000 Athlon 64 3500+ 15.4in...
Samsung Infuse 4G Smartphone Logo
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
