Question about Cell Phones
Sound ringtones code nokia ce0434 - Cell Phones
  • 135 Answers
SOURCE: undo restriction code nokia 6500s-1
NOKIA UNLOCK AND OTHER CODES
You will need a nokia phone (only).
IT IS A CRIME TO DELETE/CLONE OR INSERT AN IMEI Number on a PHONE,
However you may if you own the phone you may pick a service provider sim's "free phone".
Any network this is for (NOKIA phones only),
*3370# Activate Enhanced Full Rate Codec (EFR) - Your phone uses the best sound quality but talk time is reduced my approx. 5%
#3370# Deactivate Enhanced Full Rate Codec (EFR)
*4720# Activate Half Rate Codec - Your phone uses a lower quality sound but you should gain approx 30% more Talk Time.
#4720# Deactivate Half Rate Codec.
*#0000# Displays your phones software version, 1st Line : Software Version, 2nd Line : Software Release Date, 3rd Line : Compression Type.
*#9999# Phones software version if *#0000# does not work.
*#06# For checking the International Mobile Equipment Identity (IMEI number). #pw+1234567890+1# Provider Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols).
#pw+1234567890+2# Network Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols).
#pw+1234567890+3# Country Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols).
#pw+1234567890+4# SIM Card Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols).
*#147# (vodafone) this lets you know who called you last.
*#1471# Last call (Only vodofone).
*#21# Allows you to check the number that "All Calls" are diverted to.
*#2640# Displays security code in use.
*#30# Lets you see the private number.
*#43# Allows you to check the "Call Waiting" status of your phone.
*#61# Allows you to check the number that "On No Reply" calls are diverted to.
*#62# Allows you to check the number that "Divert If Unreachable (no service)" calls are diverted to.
*#67# Allows you to check the number that "On Busy Calls" are diverted to.
*#67705646# Removes operator logo on 3310 & 3330.
*#73# Reset phone timers and game scores.
*#746025625# Displays the SIM Clock status, if your phone supports this power saving feature "SIM Clock Stop Allowed", it means you will get the best standby time possible.
*#7760# Manufactures code.
*#7780# Restore factory settings.
*#8110# Software version for the nokia 8110.
*#92702689# Displays - 1.Serial Number, 2.Date Made, 3.Purchase Date, 4.Date of last repair (0000 for no repairs), 5.Transfer User Data. To exit this mode you need to switch your phone off then on again.
*#94870345123456789# Deactivate the PWM-Mem.
**21*number# Turn on "All Calls" diverting to the phone number entered.
**61*number# Turn on "No Reply" diverting to the phone number entered.
**67*number# Turn on "On Busy" diverting to the phone number entered.
12345 This is the default security code.
press and hold # Lets you switch between lines
*#06# for checking the IMEI (International Mobile Equipment Identity).
*#7780# reset to factory settings.
*#67705646# This will clear the LCD display(operator logo).
*#0000# To view software version.
*#2820# Bluetooth device address.
*#746025625# Sim clock allowed status.
#pw+1234567890+1# Shows if sim have restrictions.
*#92702689# - takes you to a secret menu where you may find some of the information below:
1. Displays Serial Number.
2. Displays the Month and Year of Manufacture
3. Displays (if there) the date where the phone was purchased (MMYY)
4. Displays the date of the last repair - if found (0000)
5. Shows life timer of phone (time passes since last start)
*#3370# - Enhanced Full Rate Codec (EFR) activation. Increase signal strength, better signal reception. It also help if u want to use GPRS and the service is not responding or too slow. Phone battery will drain faster though.
*#3370* - (EFR) deactivation. Phone will automatically restart. Increase battery life by 30% because phone receives less signal from network.
*#4720# - Half Rate Codec activation.
*#4720* - Half Rate Codec deactivation. The phone will automatically restart
If you forgot wallet code for Nokia S60 phone, use this code reset: *#7370925538#
Note, your data in the wallet will be erased. Phone will ask you the lock code.
Default lock code is: 12345
Press *#3925538# to delete the contents and code of wallet.
Unlock service provider: Insert sim, turn phone on and press vol up(arrow keys) for 3 seconds, should say pin code. Press C,then press * message should flash, press * again and 04*pin*pin*pin# \
*#7328748263373738# resets security code.
Default security code is 12345
These codes should provide everything you need to mod your phone.
Mike.
Posted on Feb 21, 2009
aliyancheema
  • 1118 Answers
SOURCE: i forget my security code
You may try default phone and security code to remove
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
Posted on Sep 07, 2010
  • 3 Answers
SOURCE: ce0434 nokia security code automati
you can try resetting your phone through codes. its the safe way to reset your phone. because when you reset your phone through software or hardware there are possibilities for data getting corrupted or lost. but there is no such possibilities when you reset through codes. thats y i prefer this method to reset my phone. i got the codes from this site Unlockfree.com to reset my phone. try it
Posted on Aug 23, 2011
mobil master
  • 14641 Answers
SOURCE: restriction code for a Nokia 2760
My Dear Brother:
You may try default phone and security code to remove restrictions.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Posted on Dec 07, 2012
Geekman
  • 32281 Answers
SOURCE: lock code my nokia ce0434
Unlock Cell Phones
Your cell phone may be locked to a particular cell phone provider and in this case it needs to be unlocked to use with a different cell phone service provider. To get the security code/restriction code to unlock the cell phone from the current cell phone provider so you can use the SIM card with a different phone provider, Please click on this link and follow my instructions :- http://www.fixya.com/support/r4049238-unlock_cell_phone
If your phone provider does not help you then these WEB sites it provides security codes for a small price. http://www.mobileunlockstore.com/?gclid=CKDb2_y2558CFSlJagodxBkDHw http://www.mobileunlocksolutions.com/ http://www.superunlockcodes.com http://unlockcellphonecode.com/
Posted on Dec 14, 2012
Nokia X1-01 FORGOT SECURITY CODE HOW TO RESET SECURITY CODE?
Nokia ce0434 modle x1 Code 059d8n7 imei 1 : 357890/04/279674/1 imei 2: 357890/04/279675/8
Feb 15, 2016 | Nokia Cell Phones
Nokia 5030c2 (CE0434)
You can unlock your nokia 5030 using unlock code. To get unlock code for your mobile visit Simpleunlocking.com and you can get free unlocking instructions here mobileunlockguide.com
Jun 26, 2013 | Nokia Lands Phones
Unlock code
You can get the unlock code for Nokia X2-01 from SimpleUnlocking.com . There you have to give your Country and current network name along with your IMEI number to get the unlock code.
May 12, 2013 | Nokia 002T9B4 X2-01.1-rd GSM Includes...
Forgot my security code for Nokia 1110
If you forget security code of your Nokia 1110 mobile phone then try default code 0000 or 1234. If it didn't work then visit Unlock-free.com here they provide master reset code for some Nokia,Alcatel mobile models at free of cost.By using this you can reset your mobile and set a new security code for your mobile.
Mar 12, 2013 | Nokia 1100
Forgot my security code for my nokia CE0434
nokia c1-o1 srl 51-53 sector 1 oyj c$ 0434
Dec 04, 2012 | Nokia 1650 Cell Phone
Nokia 5200 Restriction Code
You can get the restriction code for your Nokia 5200 from your service provider or from any reliable online sites!!! I would suggest simpleunlocking.com , here they provide perfect codes at reasonable price!!!
Jul 03, 2012 | Nokia 5200 Cellular Phone
I frget my mobile nokia ce0434 unlock code please give me a master code
There is no model like ce0434 in Nokia Phone.You need to specify the model correctly.You can Unlock Nokia Phones from security lock using default code ...Try 12345 or 0000 or 1234 or 1234 if these default code not works means get the master reset code from the site
Mobile-unlocker.com/nokia-dct-master-code-service/rs2wp10/and reset from security lock.
Jun 13, 2012 | Cell Phones
I have nokia CE0434. So, what is the security code of nokia CE0434
Please send me the security code for this IMEI #359747045234708
am Merie
Nov 15, 2011 | Nokia 1650 Cell Phone
I forget my security code of nokia ce0434
Sep 07, 2010 | Nokia 1650 Cell Phone
Cell Phones Logo
26 people viewed this question
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
