Question about Sony TA-AX520 Audio/Video Control Center Integrated Stereo Amplifier
How do you set up the system - Sony TA-AX520 Audio/Video Control Center Integrated Stereo Amplifier
My ps3 comes up with an error when i am trying to do the new update for FIFA 10. Comes up with error 8002ae22... can someone help in normal people terms on how to fix this
If you receive an 800 series error code on the PLAYSTATION 3 system, we recommend performing the following steps which may correct the problem.
Install the Latest System Software Update
To check what version of the System Software is currently installed on your PLAYSTATION 3, from the PS3 Home Menu go to Settings > [System Settings] > [System Information]. The system will display the System Software version number. You can check online to make sure you have the latest version installed.
Restore Default Settings
From the PS3 Home Menu, go to Settings > [System Settings] > [Restore Default Settings]. Once you select Restore Default Settings, you will see a list of settings that will be restored. Scroll through them and press the X button to restore the settings. After the operation is complete, you will see the initial set-up screen that appeared the first time you turned on the PLAYSTATION 3 system. You will need to go through the initial set-up process before you can use the PLAYSTATION 3 system.
Jun 28, 2010 | Sony Playstation 3 (PS3) Console
On my playstation 3 im trying to play socom u.s navy seals confrontation.I have to install it and it doesnt even say 1 it say error code 80710723. What does that mean and how can i fix it.
If you receive an eight digit 800 series error code, there may be a few solutions.
Update the System Software.
Visit Playstation 3 System Software Update to download and install the most recent version.
To check what version of the System Software is currently installed on your PLAYSTATION 3:
1. From the XMB home menu, go to (Settings) > (System Settings) > [System Information].
2. The system will display the System Software version number.
Power-Cycle all Network Equipment
Power-cycle means to turn the networking devices OFF (i.e., unplug it from the power source), and then to turn it back ON after a set period of time. This will allow the network devices to refresh its settings.
Please power-cycle ALL of your network equipment, including any wireless access points, routers, Voice Over IP (VOIP) modems, and broadband modems for two (2) full minutes. After 2 minutes, you can turn on (or plug in) your equipment.
Check Your Enviroment
  • Make sure to allow adequate ventilation to flow from the PLAYSTATION 3's vents (i.e., avoid obstructing the vents with long/shaggy carpet, inadequate airflow from cramped entertainment cabinet setups, etc.).
  • Make sure to keep the PLAYSTATION 3 away from excessive dust, smoke, steam, extreme temperatures, humidity, or direct sunlight.
  • See the PLAYSTATION 3 system Safety and Support manual for full details on Safety Precautions and Use and Handling (manual included with the PLAYSTATION 3 system and available for download from PLAYSTATION 3 Manuals)
During certain troubleshooting situations, it may be necessary to restore all of the PLAYSTATION 3 system settings back to their original "default" configuration.
  1. From the XMB home menu, go to (Settings) > (System Settings) > [Restore Default Settings].
  2. Once you select [Restore Default Settings], you will see a list of settings that will be restored. Scroll through them and press the (X) button to restore the settings.
  3. After the operation is complete, you will see the initial setup screen that appeared the first time you turned on the PLAYSTATION 3.
    You will need to go through the initial setup screen before you can use the PLAYSTATION 3.
IMPORTANT
The Restore Default Settings feature will erase any previously saved settings and restore all of the following settings to the default:
  • BD/DVD Settings
  • Music Settings
  • Chat Settings
  • System Settings
  • Date and Time Settings
  • Accessory Settings
  • Display Settings
  • Sound Settings
  • Security Settings
  • Network Settings
  • Internet Browser Settings
Also, do not confuse "Restore Default Settings" with the "Restore PS3 System" option (the next option down on the menu). The "Restore PS3 System" will not only restore the default settings, but it will also delete all hard disk content (You will lose all saved content from your PS3 system's hard drive if you use "Restore PS3 System.
Hope this helps.
Jun 22, 2009 | Sony Playstation 3 (PS3) Console
Error
IMPORTANT
  • BD/DVD Settings
  • Music Settings
  • Chat Settings
  • System Settings
  • Display Settings
  • Sound Settings
  • Security Settings
  • Network Settings
Hope this helps.
I dont know
IMPORTANT
  • BD/DVD Settings
  • Music Settings
  • Chat Settings
  • System Settings
  • Display Settings
  • Sound Settings
  • Security Settings
  • Network Settings
Hope this helps.
Jun 22, 2009 | Sony PlayStation® 3 (80GB) Console
DNS error 80710102
IMPORTANT
  • BD/DVD Settings
  • Music Settings
  • Chat Settings
  • System Settings
  • Display Settings
  • Sound Settings
  • Security Settings
  • Network Settings
If all these fixes fail to work you can contact sony at:
http://www.uk.playstation.com/Support/PS3
or
http://www.us.playstation.com/help-support/PS3
Hope this helps.
Jun 21, 2009 | Sony Playstation 3 (PS3) Console
Error 800100a
IMPORTANT
  • BD/DVD Settings
  • Music Settings
  • Chat Settings
  • System Settings
  • Display Settings
  • Sound Settings
  • Security Settings
  • Network Settings
or
Hope this helps.
HOW DO YOU SET THE DATE AND TIME?
It should be in 'settings' on your cell phone menu. Search around your phone. It could also be in 'organizer'. On my old one, it was in 'organizer', and once I went there, there was a 'set date and time' button. Here is the answer from the Vtech website: "Make sure the answering system is on. Press [Time/Set]. The system will announce the current clock setting, then announce "to set date and time, Press Time/Set". Press [Time/Set]. Press [Change] until the system announces the correct day, then press [Time/Set]. Press [Change] until the system announces the correct hour, then press [Time/Set]. Press [Change] until lthe system announces the correct minutes, then press [Time/set]. The system announces the current clock setting. Note: You can press and hold [Change] to advance the mninutes in increments of ten. "
Jun 06, 2009 | Vtech Lands Phones
My playstation will not read dvd's and just recently stopped reading games. I'm just wondering how to reset the entire system
  1. From the XMB™ home menu, go to icn_settings.gif(Settings) > icn_syssettings.gif(System Settings) > [Restore Default Settings].
  2. Once you select [Restore Default Settings], you will see a list of settings that will be restored. Scroll through them and press the icn_btnx_color.gifbutton to restore the settings.
    You will need to go through the initial setup process before you can use the PLAYSTATION 3.
IMPORTANT
  • BD/DVD Settings
  • Music Settings
  • Chat Settings
  • System Settings
  • Display Settings
  • Sound Settings
  • Security Settings
  • Network Settings
Read this next paragraph carefully!!!!!!
Also, do not confuse "Restore Default Settings" with the "Restore PS3 System" option (the next option down on the menu). The "Restore PS3 System" will not only restore the default settings, but it will also delete all hard disk content. (You will lose all saved content from your PS3 system's hard drive if you use "Restore PS3 System.)
Apr 21, 2009 | Sony Playstation 3 (PS3) Console
Polycom 7000 series System Settings
Web into the unit by it's IP address and go to "Home Screen Settings" and check "system".
Mar 18, 2009 | Polycom VSX 7000 Video Conference
Error code 80010514
Sony has a few fixes for this.
Visit PLAYSTATION 3 System Software Update to download and install the most recent version.
  1. From the XMB™ home menu, go to icn_settings.gif(Settings) > icn_syssettings.gif(System Settings) > [System Information].
OR During certain troubleshooting situations, it may be necessary to restore all of the PLAYSTATION 3 system settings back to their original "default" configuration.
IMPORTANT
  • BD/DVD Settings
  • Music Settings
  • Chat Settings
  • System Settings
  • Display Settings
  • Sound Settings
  • Security Settings
  • Network Settings
OR
Power-Cycle All Network Equipment Power-cycle means to turn the networking devices OFF (i.e., unplug it from the power source), and then to turn it back ON after a set period of time. This will allow the network devices to refresh its settings.
Hope this helps. Good luck and happy gaming!! // //
Sep 29, 2008 | Sony Playstation 3 (PS3) Console
Sony TA-AX520 Audio/Video Control Center Integrated Stereo Amplifier Logo
21 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
