What is "pair mode"? - Computers & Internet
    Top Expert:
  • 12,223 Answers
See this Pairing Mode Is That Two Device Are Linked Or Paired To Each Other To Share Usefull Information Between Them Instead Of Intercepting By a Third Party..It's Also Allow The Person To Send Information Widout The Permission OF The Person You Were Sending The Information Too As Pairing Is Done Only When The Person IS Trustworthy
God bless you
Posted on Jul 31, 2013
How do i put lg hbs-700 into pairing mode
I had the same issue, fixed by using the Manual mode for pairing. From the manual:
2) Manual Pairing (Pairing with another phone or re-pairing)
a) With the Power off, press the CALL button and move the power switch to the
'ON' position at the same time for 4 seconds.
b) When the headset enters Pairing Mode, the LED indicator will show a solid
blue light. After the procedure repeat Easy Pairing steps c through f.
Steps C through F are to go to the bluetooth settings area and manually select the HBS-700 for pairing.
Mar 14, 2015 | Home
Tip
How to make a bluetooth headset pair with your phone or computer
1. All bluetooth headsets can be discovered by other bluetooth enabled devices (e.g. phone, computer) whenever they are in pairing mode.<br /><br />2. You'll know that it is in pairing mode by paying attention to its indicator light, which will always show a different configuration from the usual stand-by mode. On some of them, it will be steadily lit, whilst on others will flash rapidly, often in more than one color.<br /><br />3. You must ensure your headset is turned off, prior to putting it in that mode.<br /><br />4. Most bluetooth headsets, mainly the ones which are turned on by pressing and holding a Multi-Function Button (MFB, also called answer/end button) for a couple of seconds, enter the pairing mode by pressing and holding the MFB for much longer than the time required for them to be turned on (usually 6 to 10 seconds). Release the button when you notice it is in already in pairing mode (see rule #2). Other headsets, usually the ones whose microphone is in a boom, enter the pairing mode just by opening the boom, provided that either they have never been paired to other devices before, or, otherwise, those devices have their bluetooth radios turned off. <br /><br />5. Once it is in pairing mode, make the bluetooth application, on the device you want to pair it with, search for new devices. After a little while, your headset should appear on the device' screen. Select it and make it connect. If a pairing code (or PIN, or passkey, or pass code) is requested, enter either '0000' (four zeros, which happens to be the most commonly code chosen by manufacturers), or '1234', or '8888'.<br /><br />6. If the pairing process is successful, your headset will enter the stand-by mode. There might be some type of indication that a bluetooth headset is attached, on the device just paired with it too.<br /><br />7. You headset will stay in pairing mode for a couple of minutes only. If it happens to leave that mode before you are able to finish the procedure, turn your headset off and start it all over again.<br /><br />Hope these tips can be useful to you.<br /><br />Regards,<br />Carlos
on Nov 12, 2010 | Cell Phones
I can not pair my phillipson bluetooth #BCK08A to my blackberry curve. How do u pair them together?
Make sure you are in "pairing mode" by holding down the Multi Function Button (MFB) until the red and blue flashing alternately. When the device is off, holding down the MFB for about 5 secs will turn the device on; however, don't release the button and continue to hold until red and blue flashes. Then, you are in pairing mode.
May 06, 2011 | Philips Cell Phones
Pair bluetooth em227 with my phone
Be sure the the headset in in 'Pairing' mode.
When in pairing mode, the light should be flashing red and blue or have a steady blue.
The put most headsets in pairing mode, turn headset OFF, then hold the power button until it goes into pairing mode as discribed above. Then you can discover it with your phone. Pin (pass key) should be 0000 (4 Zeros) or try 1111, 1234, 9999
Mar 05, 2010 | Southern Telecom Emerson Bluetooth Headset...
How pair bluetooth Jabra vbt2050 with a blackberry storm 2
In order to pair a BlackBerry device with a Bluetooth device, the Bluetooth device must be in pairing mode. Most Bluetooth devices are not set to pairing mode by default. Therefore, refer to your Bluetooth device manual for instructions on how to set the device to pairing mode.
Mar 04, 2010 | RIM BlackBerry Storm2 9550 Smartphone
Need instructions on how to pair bluetooth motorola H710 with blackberry curve
Then you can discover it with your phone or PC. Pin (pass key) should be 0000 (4 Zeros) or try 1111, 1234, 9999
Dec 25, 2009 | Motorola Mobility H710 Bluetooth Headset
How do i pair my motorola H390 bluetooth on a katana
Nov 03, 2009 | Motorola Mobility H390 Bluetooth Headset
I am unable to pair my bluetooth with nokia 5310 music xpress
Oct 16, 2009 | Nokia Bluetooth Headset BH-207 Wireless...
I can't pair my motorola h681 bluetooth and my SGH -A837
Jun 08, 2009 | Motorola Mobility H550 - Bluetooth Headset...
Activate pairing mode
Holding down the multifunction button for eight seconds puts the unit in pairing mode and an LED lets you know the status of the headset. Flashing blue and red means the H4 is in pairing mode, flashing blue means it is paired and flashing red means the H4 needs charging.
Aug 10, 2008 | Cell Phones
Computers & Internet Logo
159 people viewed this question
David Payne
David Payne
