Question about GE Dishwashers
Model#GLD4456ROOCS Washer goes thru cycle but will nt pump out water
  • 12 Answers
SOURCE: will not pump out dirty water
Is it hooked to a garbage disp. If so make sure the knock out is out. Then if you can use a volt meter. take off the 2 screws at the bottom of the unit on the left side is your drain pump. take off the 2 wires put your meter on ac and put your leads on the wires then run it in a cxl cycle. (the cxl will depend on your unit you will press two buttons @ the same time and hold it it will light up 2(2min))
if you get 110 you have a bad pump........
Posted on Dec 23, 2007
IFIXALL
  • 868 Answers
SOURCE: kenmore dishwasher model 665
check for a clog at the water valve under the dishwasher.Remove lower panel of D/W(dishwasher)Shut off power supply to D/W.Remove the water supply line from your water valve(its most likely mounted underneath to the left side of frame.After removing this ,very slowely turn water back on just enough to determine if you have a clogged line. Let me know when you are there.
Posted on May 21, 2008
SOURCE: dish washer that does not pump out the water on it"s final cycle
I had this same problem and after having the repairman over to our house several times and having the circuit board changed, I figured it out on my own...
It turns out that the pressure created from the steam during the water heating stage (HO) was pushing on the door latch just enough to prevent the motor from running properly. Because the door wasn't latched completely, the water wouldn't drain and the dishwasher would go to the "Drying" cycle without ever pumping the water out of the basin.
I adjusted the levelling on the DW and that helped, but I'm still not sure that the problem is fixed. We may need a new latch assembly.
To test this, when the DW stops running at any time, push on the door. If the motor kicks back on, this is the problem.
Posted on Feb 20, 2009
localwonder
  • 6784 Answers
SOURCE: water into washer
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
Posted on Jun 11, 2009
  • 457 Answers
SOURCE: my whirlpool dishwasher is not getting any water
sounds like a bad water valve you can disconnect wires ohms it out with a meter and see if its good or not . your looking for continuity. go to searspartsdirect .ocm to see price for part and they will ship
Posted on Mar 04, 2010
Testimonial: "thank you so much.this will save us from being overcharged for maybe doing more than we need...hopefully the repair person will be honest.U R #1 EADIE"
I have a kenmore 80 series washer that goes thru all the cycles except that it doesn't drain after rinsing and this is my serial and model number if you need it: mod20852990 ser4549516
does it drain after the wash cycle before therinse cycle? if not there are usually 2 belt on the bottom of the washer, one is for the aggitator the other for the water pump. check to see if the belt is still attached and also take the drain hose down to floor level to see if the water gravity feeds out, if it does not pour out then your pump would likely be clogged from lint.
Apr 24, 2012 | Kenmore Washing Machines
Washer won't drain.
My washer fills up with water and goes thru the wash cycle but when it's time to drain, it just sits there and clicks.
Oct 17, 2009 | Tecnik TKL9260 Front Load Washer
Washer doesn't run all the way thru cycles. It's
Removed hose connecting to water pump at tub. Removed clog (ink pen, coins, etc). Replaced and ran washer. Ran through all cycles - no leaking, no pausing of cycles. Problem is resolved.
Oct 01, 2009 | GE Energy Star 3.7 IEC Cu. Ft. Front Load...
When it gets to the rinse cycle, water is coming out of the hose into the sink not allowing it to fill, but their is a continuous dribble of water coming out of the hose into the washer, so whatever goes...
maybe your diverter valve at the pump is stuck open. Its a lilttle red box looking thing under the waasher by the pump. That little red box looking thing is you wax motor that has a plunger hooked up to a small looking piece. That wax motor moves the pluger in and out depending what cycle it is on. So im thinkng that went bad maybe and has the valve stuck open and thge water that is trying to fill is passing thru the pump and thru the drain hose. When the water fills its supposed to be closed tha way it contains all the water when it fills and wont let any get thru pass the pump and thru the drain hose.
Aug 05, 2009 | Fisher and Paykel GWL11 Top Load Washer
Washer will not discharge water after wash or rinse cycle
Pump failure. Unit probably has something stuck in pump....the washer eats the socks not the dryer. suggest shope vac to get water out, and then remove hose from pump and check to see if its clear.
Jun 08, 2009 | Kenmore Washing Machines
AWT5108 no spin
The motor is bad and you should replace the motor. To do this and order it you can go to
whirlpool.com and type in the model number and get he part
Feb 08, 2009 | Whirlpool AWT5108 Top Load Washer
Loud noise
it sounds like you have something stuck under the agitator thats causing a rubbing noise when it goes to spin or agitate.maybe a penny or something like that
Dec 28, 2008 | Frigidaire GLTF2940ES Front Load Washer
Whirlpool Washer not going thru cycle
IF YOUR MACINE WONT PUT WATER IN IT WHEN YOU TURN IT ON ITS THE WATER INLET VALVE IN BACK WHERE YOU HOOK UP THE WATER. IF THE WATER GOES IN WHEN YOU TURN IT ON THEN ITS MORE LIKELY TO BE YOUR LID SWITCH. YOU CAN GET EITHER OF THE PARTS AT YOUR LOCAL APPLIANCE DEALER OR EASILY ON LINE. JUST HAVE YOUR MODEL NUMBER HANDY. GLAD TO BE OF SERVICE.
Nov 03, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Dishwashers Logo
24 people viewed this question
Top GE Dishwashers Experts
Mike
Garth Jackson
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
