Question about Canon PIXMA MP460 All-In-One InkJet Printer
MP460 printer--problem w/ envelopes
Trying to custom print return address on envelope... printer makes long ink stain at edge of envelope before printing log and address... they look awful!!
  • Fourintow Aug 31, 2007
    I should have left more info in my question... The ink stain only appears on an envelope. It does not appear when printing it on regular paper...
    It seems the envelope is getting abused b/c of it's thickness... ?? And it only happens on the corner where the envelope is being fed through the feeder.
    Sergeant:
  • 390 Answers
You seem to have clogged nozzles/printhead. Take out cartridges, do a thorough clean down where cartridges sit, the printhead, even the roller as well. Run your printers own cleaning maintenance before you do it manually with cleaning solution. Problem should be gone when you reinsert cartridges. Don't froget to reset ink levels and cartridges. good luck!!!
Posted on Aug 31, 2007
  • Geraldine Watts Sep 01, 2007
    Oh, sorry fourintow, i was assuming all printing affected. Ok, in that case You need to tell the printer in the printer property settings when you print (paper quality settings etc or similar) what you are printing (ie envelope) otherwise your poor printer assumes it is default printing plain white normal thickness paper and cannot cope. Try this. Hope it works for you.
SOURCE:
Ink spots on envelopes
Hi rebecca,
Go To Below official Hp Printer Forum Page For Your problem And Solve Your Problem Black ink stains envelopes when printing HP Support Forum 955951
Feb 24, 2014 | Canon PIXMA MX340 Wireless Office...
Envelope jam HP Officejet 8500
Try to print envelope through Microsoft Word
Steps:-
1) Click Tools , click Letters and Mailings and then click Envelopes and Labels .
2) Type the Delivery and Return address information.
3) Click Options .
4) On the Envelope Options tab, set the following options:-
  • Envelope size : set to match the loaded envelopes.
  • US only : if desired, select the Delivery point barcode to make it easier for mail sorting machinery to correctly route the envelope.
  • Return address : for Size 10 envelopes only, set the Return Address position .8 inch in the From left section.
5) Select the Printing Options tab and verify that the following settings are selected:
  • Select the Feed Method option that shows the envelope on the far right side with the short edge first.
  • Select Face down .
  • Examine the selected feed method image and verify that the envelope flap is on the left side of the envelope. If it is on the right, select or deselect Clockwise rotation.
6) Click OK and then click Print .
As envelop can not feed correctly every time, it depends on the weight, flap design, paper type and other factors & cause jam, To prevent those you can do.
  • Print envelopes at a higher quality setting so envelope is pulled through the unit more slowly. e.g:- Switch fast to slow mode or slow to best mode.
  • Tuck the flap inside the envelope before loading it into the printer.
Have a nice day...don't forget to rate the solution.
Feb 20, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
How do I print addresses on #10 envelopes?
    1. Click Tools on the menu bar in Microsoft Word, and then do one of the following:
    2. Word 2000: Click Envelopes and Labels .
    • Word XP: Click Letters and Mailings , and then click Envelopes and Labels .
    1. Type the Delivery and Return address information.
    2. Click Options .
    1. On the Envelope Options tab, set the following options:
    2. Envelope size : set to match the loaded envelopes.
    • S. only: if you want to, select the Delivery point barcode to make it easier for mail sorting machinery to correctly route the envelope.
    • Return address: for Size 10 envelopes only, set the Return Address position to .8 inch in the From left section.
    • Click the Printing Options tab and verify that the following settings are selected:
      • Select the Feed Method option that shows the envelope on the far right side with the short edge first. For example, in the graphic below, the fourth image shows the envelope in the correct position.
      • Examine the selected feed method image and verify that the envelope flap is on the left side of the envelope. If it is to the right, select or clear Clockwise rotation .
      • Click OK , and then click Print .
  • Jul 22, 2009 | HP Officejet 5610 All-In-One InkJet...
    Printing small envelopes
    In Word 2007, use the Mailing > Envelopes > Options section.
    In 2003 I think it was under Tools > Envelopes & Mailings > Options.
    There you'll be able to specify if the manual feed is top first or edge first, to the left, centered, or to the right, and how far over and down to place the address and return address.
    After a few adjustment runs, it works great.
    Jun 09, 2009 | Dell 5110cn Laser Printer
    Epson Stylus NX400 While printing envelopes, I keep getting a black ink blot on the bottom right hand corner of the envelopes. It happens to about every 1 out of 4 envelopes. I printed the return addr
    Envelopes can give all sorts of problems Back corner is flicking up. Try rolling the envelopes in the opposite direction to the "bowing" as they have been through machine once.
    Apr 22, 2009 | Epson Stylus NX400 InkJet Printer
    Printing return address on custom size envelope
    this is done in the word processor application. when you select eh envelops. you are given the choice of return address, barcode, and what type of envelop.
    Mar 07, 2008 | Kyocera Mita KM-2050 Printer
    Envelope printing
    You need to insert the envelope in the manual feed area and open the exit door at the back this allows the envelope to go straight through the printer hopefully limiting creasing. Check the envelope settings in windows make sure that you are using the correct size and feed selection.
    Thanks J
    Feb 03, 2008 | Brother HL-2040 Laser Printer
    Envelope Printing
    What are you printing from? Word?
    Oct 05, 2007 | Kyocera Mita KM-3035 All-In-One Laser...
    Printing return address on #10 24lb regular envelope
    Are you free hand addressing or are you using "Word - envelopes and labels" tool. It should be goof free. If you are, check the pull down rollers on that end of the printer for damage or contamination. When you lift up the cover like you're installing a new cartridge, you should see the black rollers. Clean them with a q-tip and alcohol, wiping across while rolling it with your finger. If you're not using Word, pull down the tools tab and select letters and mailings, then envelopes and labels.
    Jun 29, 2007 | HP PSC 1510 All-In-One InkJet Printer
    Dell A920 won't print envelopes
    I have(had) the same problem using the Dell A920 printer on a Dell compunter running XP. After spending a hour trying to find a solution on the internet, I finally found a solution on my own. When ready to print a envelope. Go to File/Print Click Properties button In lower right hand corner, check "Print Color Image in Black and White" box Click OK button Click OK in print pop up When finished, repeat to uncheck "Print Color Image in Black and White" box to allow for color printing.
    Dec 02, 2006 | Dell A920 InkJet Printer
    Canon PIXMA  MP460 All-In-One InkJet Printer Logo
    211 people viewed this question
    Clive
    Clive
    old marine
    old marine
    Ekse
