Question about Ricoh Pro 1357EX
How do I change the waste toner bottle on a 1357ex
jaylex
  • 417 Answers
SOURCE: We removed the waste toner bottle and it won't reset the error message
You will need to vacuum all the toner out as in the machine there is a sensor that looks through the waste tank and checks that it is clear. You can also wash the tank out then install it and you will not have the problem.
Thanks J
Posted on Jan 28, 2008
SOURCE: can you resue a waste toner bottle
Change the waste toner bottle. :-)
Posted on May 14, 2009
SOURCE: how do I change the waste toner bottle for a ricoh sp c410?
Drill a 3/4" hole in lower left side of waste toner bottle. Waste toner is very fine and will get all over the place – you also may want a breathing mask. Take outside and dump waste in large ziplock bag and dispose properly. Put a large piece of shipping tape and cover hole. Put back into ricoh c410. This wi;; save you about $50 and less plastic in our landfills. SG
Posted on Jul 23, 2009
SOURCE: Waste toner is almost full on Ricoh aficio AP3800C
Open the main front cover and you will see the white plastic waste toner bottle on the left hand side halfway up. I lies on its side and you can see the bottom of it.
Slide it out gently keeping it level to avoid spilling all the waste toner.
Either replace with a fresh empty waste bottle or empty the bottle into a large plastic bag you can keep sealed with the bottle inside while you shake it.
You have a good chance of spilling the toner all over your clothes if you are not carefull and note that the waste toner IS HIGHLY INFLAMMABLE so no naked flames nearby!!
Posted on Aug 01, 2009
newport74
  • 58 Answers
SOURCE: how to replace waste toner bottle for Ricoh Aficio
1. Lift the original feed unit.
2. Lift the upper unit.
3. Right upper cover
4. Right cover [
5. Loosen the leaf spring and lift it.
6. Toner overflow sensor
7. Toner collection bottle
Once you have it out jsut dump it out (carefully) remove the sensor on the bottle and wipe clean reinstall the sensor re install the bottle and you should be good to go
Posted on Feb 27, 2010
Lexmark c 925 reset waste toner bottle
I don't know if you got an answer to this but I found it in the Menus>Supplies menu>Replace Supply and then tick yes for waste toner bottle replaced.
Mar 03, 2014 | Lexmark C925 X925 WASTE TONER BOTTLE
Waste toner box full message after changing the waste toner box
When you removed the waste toner bottle, there is a sensor inside the copier. When you remove the waste toner, look to the opening where the top of the waste bottle was, clean that area and return the bottle and turn the copier OFF then ON. Good Luck
May 04, 2013 | Canon Gpr23 Irc2880/2880i Black Copier...
WASTE TONER IS FULL ERROR
You have to empty out the waste toner bottle... The bottle is a milky white plastic and I believe it is right under the fuser unit. It should slid out toward you. Carefully dump the toner out of the bottle into a plastic garbage bag and re install the bottle and you are done....
Dec 07, 2012 | Ricoh 4506 Copier
I have a ricoh aficio MPC2050 copier V2295900860 and it is saying that the waste toner bottle is full and needs to changed how do i do this and where is the waste toner bottle located.
Hello!
Your machine have 2 waste bottles.
The bottle 1 is placed in the front door. (See the picture). You can empty it or replace it.
(is less expencive to empty it)
The secund waste bottle is in the left. See this picture
Now, you just need to make sure what waste bottle is mentioned in the display.
Hope this helps
Sep 12, 2011 | Ricoh Aficio 450 Copier
Error is E000019-0000
Let the front of the canon copier/image runner iR 3300 as a referrence, waste toner bottle is located under neath the small cover of size 15 cmsX 30 cms and this small cover is located at the extremely lower left corner of the copier/image runner iR3300.This small cover will fixed with one and only one screw at the upper/top right corner of the small cover. Un screw this small cover and remove the small cover along with the attached screw and kept aside. Under neath this small cover there will be a big plastic bottle which is called as the waste toner collection bottle. The capacity of this bottle may be 11/2 kgs to 2 kgs. When this waste toner bottle was filled up , a message will be appeared on the screen that ' replace the waste toner collection bottle'. Even after the this message the copier/image runner may work properly. If the message of error code E000019-0000 appeared on the screen this waste toner bottle may be filled completly. Then the coper will stops to work. Then gently remove this waste toner collection bottle slowly and empty the waste toner bottle which was filled up with waste toner within the plastic bag. Wash this waste toner bottle with soft water 2 or 3 times and there after with soft detergent washing powder , so that no stains of waste toner or any type of stains may be completly removed. Please don't try to remove the water particles with cloth or any thing Or don't try to remove the water particles with Hot hair dryer. After washing the waste toner bottle , dry this with the air coming from cealing fan or with cold hair dryer. After the waste toner bottle was completly dried withj the cold air replace the this bottle in the original place. Before replacing the waste toner bottle in its original position clean the place of waste toner base / holder -up , down, left & right with the clean and soft cloth which is under neath the small cover. Hurray ! your problem will be solved completly without any expenditure but you may expected to take time with patience.
Sep 22, 2010 | Canon (6981A002AA) for imagerunner 2200,...
Error message "check waste toner box". New cartridge just installed?
Check your waste toner box. At the side of the printer is a container for the extra toner to be stored. Everytime you change your cartridge you need to change the waste toner container. Carefully open side panel and remove waste toner bottle. There is a button you need to push do not force the bottle out.
Remove lid of new waste toner bottle and put into place and close side panel. Follow link for further details or use your setup guide that came with the printer on how to install the waste toner bottle.
http://usa.kyoceramita.com/americas/jsp/upload/resource/15865/0/2000D-3900D-4000DMLIIR1.1.pdf
Jun 08, 2010 | Kyocera FS-2000D Laser Printer
Where is the waste toner bottle located?
Remove the small cover on the lower left hand side( one screw only) and remove the waste toner bottle and emptied it ensure that bottle neck is not clouded with toner otherwise even the bottle is empty still it will detect waste toner is full .hope this will help
Jul 09, 2009 | Canon imageRUNNER 2000 Copier
I have Canon ir5075 and it asks me to change waste bottle. I empty the bottle. But do not know how to tell the printer that it is empty.
I am not familiar with this model but usually Canon waste bottle has:
1. Check if the waste toner botlle has some clear portion near the neck, (as in IRC3200) or other part of the bottle ,even the waste toner was removed but if this portion is still clouded by toner the sensor will still detect the waste is full
2. If the situation is not like this some Canon Ir machine needs to reset waste toner counter in the service program mode even the waste toner bottle was emptied
Jun 09, 2009 | Canon imageRUNNER 5000 Copier
Waste toner
to change the waste toner on your IR 5055, stand directly in front of machine and look on the right hand side of it where the power switch is a black button on right hand sdie at the back and you will see 4 screws and a metal plate that will come off the waste toner bottle is in there just empty it out and refit to machine all will work, now on your IRC3170 just undo front door and you will see a clear bottle just undo the black screw and take out the bottle and you will see a couple of little clear windows in the bottle make sure you take them out and clean them before you emtpy the bottle, this is where the machines shines a light through it to tell if the bottle is full or not so make sure you have them clean. refit the bottle and all will be ok
May 26, 2009 | Canon imageRUNNER C3170U Color Copier
Ricoh Pro 1357EX Logo
47 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
