Question about Garden
Exmark kubota deseil engine 33 hp water cooled its over heating I did all the trouble shooting and still having a problem
5 Suggested Answers
short shadey
  • 421 Answers
SOURCE: coolant fan
check to be sure the lower hose is hot and you have good heat when this happens, if not your thermostat is stuck change this. if its hot there is a fan themo switch located on the radiator that may be suspect please advise good luck -jeff be sure to rate this !
Posted on Sep 05, 2008
  • 1738 Answers
SOURCE: cooling mode all the time, does not try to heat
Make sure your vent is clean going outside of your house.
Posted on Dec 21, 2009
  • 161 Answers
SOURCE: The water will not heat up. How can I trouble
the last time I looked at heaters for jacuzzi tubs they are designed to keep the water at the temperature you filled the tub and not heat up the water from cold to hot.
Posted on Apr 04, 2010
meinverstand
  • 181 Answers
SOURCE: need spark plug part# and
Here are the plugs you need, pre-gapped to .035
http://www.rcpw.com/rc12yc-spark-plugs/130119.html
Posted on May 04, 2011
Hydraulics are not working on my GF 1800 Kubota lawn mower
Check for fluid level and operation of master cylinder.
Sep 02, 2017 | Kubota Garden
Cooling fan is acting strange car is heating some when idling how can I trouble shoot or fix
It is normal for a temperature gauge to fluctuate when the car idles, you will notice 20 to 50 degrees bounce. As long as it is not going into the red or blowing steam don't worry about it.
Oct 26, 2015 | Cars & Trucks
How many horsepower does a kubota tractor B8200 has / what year was it made
It was made between 1983 and 1990
Kubota B8200 Power:
Engine (gross): 19 hp [14.2 kW]
PTO (claimed): 16 hp [11.9 kW] (gear)
14.5 hp [10.8 kW] (hydro)
You can find more breathtaking information about this tractor at
http://www.tractordata.com/farm-tractors/001/2/7/1274-kubota-b8200.html
Apr 29, 2015 | Kubota Garden
17 hp kubota burns out right side spark plug in in an hour, not filed just dead will not work on the other side if switched after burned out. What can cause that?
Hi Robert:
Sounds like you've some trouble shooting to do. Try starting by installing new spark plugs in all cylinders. Find a project and run the machine for an hour or so. Let it cool off, then pull the spark plugs. Keep track of which one is from each cylinder. There are some excellent charts available that show what is going on in an engine from the appearance of the plug. OILY & Fouled is usually bad rings, SOOTY black can be too rich a mixture, Too lean can make the tip look almost melted. Enjoy the chase!
Mar 03, 2015 | Kubota Garden
Check list for answers to my Montero overheating...
Methods to trouble shoot
(1) check thermostat device. if thermostat is stuck - not working half the water used in cooling system is missing once engine heats up which can lead to over heating. (may need mechanic to check this)
(2) check radiator has water in it . if it is low there may be a leak in cooling system somewhere check rubber hose and radiator are not leaking.
(3) check fan belt is engaging fan in front of radiator
(4) if electric fan check if fan activates once car has heated up
(5) check oil level of engine on dip stick. If low oil add some oil and re check oil dip stick. DO NOT PUT whole oil pack in (don't laugh I know someone who did this and has to go to mechanic and get oil removed)
(6) if rubber hoses blow off connectors then you may have a broken head gasket seal. A pressure test of the radiator will confirm this.
(7) Possible water pump failure. Check by taking cap off radiator and run engine see if water is flowing in radiator and test if water is heating up in the radiator. Remember to put cap back on radiator when finishing test.
(8) check if bubbles or oil are in radiator water this could indicate a blown head gasket problem also.
Oct 20, 2014 | Mitsubishi Montero Cars & Trucks
Kubota wiring diagram
pull each switch and jump it if started found bad switch
Aug 28, 2014 | Kubota Garden
Can not find model or serial number
sounds like the machine being from an auction may be STOLEN!!!! since it has no tags, or identification.
Jun 22, 2013 | Garden
Over heating
what engine is in the car should be 3.8 liter you must have a thermostat in to keep it from over heating it will get hotter and hotter if you don't you diden't say if you were boiling over pressure was forcing out the water all makes a bid differnce in trouble shooting cooling system need more info on this one sorry
Jan 21, 2013 | 2002 Pontiac Grand Prix
Exmark electric clutch problem
one side of the connector gong to the clutch needs to be a ground
Aug 21, 2012 | Encore EXMARK LAWN MOWER HEAVYDUTY STEEL...
Garden Logo
18 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
