Question about Dell PowerEdge 2650 Server
Battery module is missing do not use write back mode
2011 Yamaha misses @ half to full throttle
Hi, Jay and the usual suspects are:
1. Severely discharged or a damaged battery, should have 12.5 volts or better and be able to pass a load test if necessary.
2. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
3. Spark plugs in bad condition or partially fouled.
4. Spark plug cables in bad condition and leaking check for spark leakage in the dark
5. Spark plug gap too close or too wide.
6. Faulty ignition coil, module, and or sensor.
7. Loose, dirty, or corroded ignition module connector at crankcase.
8. Faulty CKP or CMP, MAP, ETS, ATS, TPS, O2 sensor.
9. Dirty air filter.
10. Intake air leak.
11. Water, dirt, or rust in the fuel system.
12. Carburetor damaged, contaminated, sticky float, plugged jets.
13. Multiple carburetors out of sync.
14. Fuel filter clogged.
15. Old or contaminated fuel.
16. Fuel tank vent system plugged or carb vent line closed off.
17. Gas cap diaphragm valve faulty.
18. Vacuum line from intake manifold to fuel valve is broken, cracked, pinched, or missing.
19. Carburetor controls misadjusted.
20. Incorrect valve timing.
21. Valve springs floating, weak, or broken.
22. Damaged intake or exhaust valve.
23. Incompatible performance parts.
24. Control module may be in "LIMP" mode
25. Check for engine trouble codes.
Good luck and have a wonderful day.
Apr 28, 2017 | Yamaha Motorcycles
BMW E66 wont star,t fault code, 28D6 coding missing
28D6 HO-Protocol Failure coding missing means one of the modules is not communicating with the cars network that links all the modules. What symptoms do you have, cluster issues?.
Sep 01, 2016 | BMW Cars & Trucks
Low beams keep dimming while driving
Headlamps
The headlamp driver module (HDM) is an electronic module that provides electrical power to the vehicle low beam headlamps. The HDM is controlled by a pulse width modulated (PWM) ground signal from the body control module (BCM). The BCM determines the desired lamp intensity using the ambient light sensor, multifunction switch and the park brake switch as inputs. In general, the HDM will operate in 1 of 3 modes:
Reduced Intensity Mode: This mode is used by features that do not require or allow maximum low beam headlamp intensity such as daytime running lights (DRL) (nominal: 85% duty cycle).
Full Intensity Mode: This mode is used by features that require full low beam headlamp intensity such as low beam headlamp operation in manual or auto modes (nominal: 100% duty cycle).
Off Mode: This is the default mode of the system that will occur when none of the features described above are active. The BCM will deactivate its PWM output (0% duty cycle) during this mode.
The normal battery voltage input to the HDM must be between 6 and 16 volts DC to operate. Any deviation to these values could cause improper operation.
The ambient light sensor is a light sensitive transistor that varies its voltage signal to the body control module (BCM) in response to changes to the outside (ambient) light level.
You should have the modules scanned for codes first off. Not the engine control module .( BCM ) body control module , yes . That's the first thing I always do !
Could be a bad ambient light sensor or the headlamp driver module. You could check voltage at the battery with engine running, should be over 14 volts. If you don't deal with this sort of thing on a regular basis I'd take it to someone who does !
You
Jan 08, 2015 | 2003 Chevrolet Chevrolet TrailBlazer
1979 Honda CX 500 A misfires badly
Hi, Anonymous and the usual suspects are:
1. Severely discharged or a damaged battery should have 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a cursory reading of 12.5 volts or more but little or zero amperage the battery is faulty and must be replaced, AGM batteries fail in this scenario more so than lead acid batteries.
12. Carburetor contaminated, sticky float, plugged jets.
13. Carburetor vacuum diaphragm torn, cracked, not seated or installed improperly.
14. Multiple carburetors out of sync.
15. Fuel filter clogged.
16. Old or contaminated fuel.
17. Fuel tank vent system plugged or carb vent line closed off.
18. Gas cap diaphragm valve faulty.
19. Vacuum line from intake manifold to fuel valve is broken, cracked, pinched, or missing.
20. Carburetor controls misadjusted.
21. Incorrect valve timing.
22. Valve springs floating, weak, or broken.
23. Damaged intake or exhaust valve.
24. Incompatible performance parts.
25. Control module may be in "LIMP" mode
26. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Honda CX500 Ignition Problems Tech Corner Motorcycle Classics
http://robdavistelford.co.uk/webspace/cx500/wontgo
Honda CX500 Shop Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda CX500 CUSTOM Owner Manual
May 24, 2014 | 1979 Honda CX 500 A
Honda valkyrie misfire
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Power Fade
Random misfires GL1500
Honda GL1500 Service Manual
Honda GOLDWING GL1500 Owner Manual
Apr 03, 2014 | Honda F6 C Valkyrie Motorcycles
CHECK ENGINE LIGHT COMES ON AT START UP AND IDLE. NO ROUGH IDLE NO SYMPTOMS?????
Have you pulled the error codes?
1- Turn Ignition switch to OFF & Run/Stop switch is to Run.
2- Push odometer reset button in & hold.
3- Turn ignition switch to Ignition and release odometer reset button. Background lighting sould illuminate, speedometer needle should sweep its full range and indicator lamps (battery, security, low fuel, check engine and cruise) should illuminate. The word "diag" should then appear.
4 - Push the odometer reset button once and you will see the selection menu "PSSPt" with the first P flashing.
5 - Each letter represents an area of the diagnostics module. The module that is flashing is the one you are going to check. To move from one letter (module) to the next, you push the odometer reset button one time. (from P to S to SP to t and back to P, etc.)
P = ECM/ICM (Electronic Control Module [EFI] / Ignition Control Module [Carbureted])
S = TSM/TSSM (Turn Signal/ Turn Signal Security Module)
SP = speedometer
T = tachometer
6 - To get the DTC within an area of diagnostics, push and hold the odometer reset button in for 5 seconds and release. If there are any DTC's the code will be displayed or the word "none" will appear if there are no DTC's. Push the odometer reset button again to view additional codes if they exist.
7 - Record the codes.
8 - If DTC's are not to be cleared, Press and release the odometer reset button. Part number of module will be displayed.
NOTE: To determine if a code is current or historic, clear the displayed code by pushing in and holding the odometer reset button ( longer than 5 seconds) until 'clear' comes up. Release the odometer reset button. Turn OFF the ignition switch. Run your bike and shut it down then recheck the DTC's again by repeating steps 1 to 9. If the code is current it will reappear.
9 - Press and release the odometer reset button to continue to the next module.
10 - Turn Ignition switch to OFF.
What do the codes mean?
DTC FAULT CONDITION MODULE
"BUS Er" (TSM/HFSM) Serial Data Open/High
B0563 Battery Voltage High (TSM/TSSM)
B1004 Fuel Level Sending Unit Low (Instruments)
B1005 Fuel Level Sending Unit High/Open (Instruments)
B1006 Accessory Line Overvoltage (Instruments)
B1007 Ignition Line Overvoltage (Instruments)
B1008 Reset Switch Closed (Instruments)
B1121 Turn Signal Will Not Flash (HFSM)
B1122 Right Turn Signal Open (TSM)
B1123 Left Turn Signal Short-to-Ground (HFSM)
B1124 Right Turn Signal Short-to-Ground (HFSM)
B1125 Left Turn Signal Short-to-Voltage (HFSM)
B1126 Right Turn Signal Short-to-Voltage (HFSM)
B1134 Starter Output High ((TSM/TSSM)
B1135 Accelerometer Fault ((TSM/TSSM)
B1136 Accelerometer Tip-Over Self Test (HFSM)
B1141 Ignition Switch Open/Low (HFSM) ONLY
B1141 Turn signals Will Not Flash (TSM) ONLY
B1142 Internal Fault (HFSM)
B1143 Security Antenna Short-to-Ground (HFSM)
B1144 Security Antenna Short-to-Battery (HFSM)
B1145 Security Antenna Open (HFSM)
B1151 Sidecar BAS Low ((TSM/TSSM)
B1152 Sidecar BAS High ((TSM/TSSM)
B1153 Sidecar BAS Out of Range ((TSM/TSSM)
B1154 Clutch Switch Short-to-Ground (TSM/HFSM)
B1155 Neutral Switch Short-to-Ground (TSMHFSM)
B2006 Radio Switches Shorted/Stuck (Audio)
B2007 Handlebar (Audio) Switch Shorted High(Audio)
Handlebar Mode Switch Shorted High(Audio)
Handlebar PTT/Squelch Switch Shorted High(Audio)
B2008 Handlebar (Audio) Switch Shorted Low(Audio)
Handlebar Mode Switch Shorted Low(Audio)
Handlebar PTT/Squelch Switch Shorted Low(Audio)
B2009 Handlebar (Audio) Switch Stuck or Open(Audio)
Handlebar Mode Switch Stuck or Open(Audio)
Handlebar PTT/Squelch Switch Stuck or Open(Audio)
B2010 Passenger (Audio)/PTT Switch Shorted High(Audio)
Passenger Mode Switch Shorted High(Audio)
B2011 Passenger (Audio)/PTT Switch Shorted Low(Audio)
Passenger Mode Switch Shorted Low(Audio)
B2012 Passenger (Audio)/PTT Switch Shorted Stuck or Open(Audio)
Passenger Mode Switch Shorted Stuck or Open(Audio)
B2013 Sidecar Switches Shorted High(Audio)
B2014 Sidecar Switches Shorted Low(Audio)
B2015 Sidecar Switches Shorted Stuck or Open(Audio)
B2016 Front Speakers Shorted(Audio)
B2017 Front Speakers Open(Audio)
B2018 Front Speakers Shorted to Ground(Audio)
B2019 Front Speakers Shorted to Battery(Audio)
B2020 Rear Speakers Shorted(Audio)
B2021 Rear Speakers Open(Audio)
B2022 Rear Speakers Shorted to Ground(Audio)
B2023 Rear Speakers Shorted to Battery(Audio)
B2024 Sidecar Speakers Shorted(Audio)
B2025 Sidecar Speakers Open(Audio)
B2026 Sidecar Speakers Shorted to Ground(Audio)
B2027 Sidecar Speakers Shorted to Battery(Audio)
P0107 Map Sensor Open/Low (EFI)
P0108 Map Sensor High (EFI)
P0112 IAT Sensor Voltage Low (EFI)
P0113 IAT Sensor Voltage Open/High (EFI)
P0117 ET Sensor Voltage Low (EFI)
P0118 ET Sensor Voltage Open/High (EFI)
P0122 TP Sensor Open/Low (EFI)
P0123 TP Sensor High (EFI)
P0131 Front O2 Sensor Low (EFI)
P0132 Front O2 Sensor High (EFI)
P0134 Front O2 Sensor Open/Not Responding (EFI)
P0151 Rear O2 Sensor Low (EFI)
P0152 Rear O2 Sensor High (EFI)
P0154 Rear O2 Sensor Open/Not Responding (EFI)
P0261 Front Injector Open/Low (EFI)
P0262 Front Injector High (EFI)
P0263 Rear Injector Open/Low (EFI)
P0264 Rear Injector High (EFI)
P0373 CKP Sensor Intermittent (EFI)
P0374 CKP Sensor Synch Error (EFI)
P0501 VSS Low (EFI)
P0502 VSS High/Open (EFI)
P0505 Loss of Idle Sped Control (EFI)
P0562 Battery Voltage Low (EFI)
P0563 Battery Voltage High (EFI)
P0603 ECM EEPROM Error (EFI)
P0605 ECM Flash Error (EFI)
P0661 Active Intake Solenoid Open (EFI)
P0662 Active Intake High/Shorted (EFI)
P1001 System Relay Coil Open/Low (EFI)
P1002 System relay Coil High/Shorted (EFI)
P1003 System relay Contacts Open (EFI)
P1004 System Relay Contacts Closed (EFI)
P1009 Incorrect Password (EFI)
P1010 Missing Password (EFI)
P1351 Front Ignition Open/Low (EFI)
P1352 Front Ignition Coil High/Shorted (EFI)
P1353 Front Cylinder No Combustion (EFI)
P1354 Rear Ignition Coil Open/Low (EFI)
P1355 Rear Ignition Coil High/Shorted (EFI)
P1356 Rear Cylinder No Combustion (EFI)
P1357 Intermittent Secondary Front (EFI)
P1358 Intermittent Secondary Rear (EFI)
P1475 Exhaust Actuator Position Error (EFI)
P1477 Exhaust Actuator Open/Low (EFI)
P1478 Exhaust Actuator Shorted (EFI)
U1016 Loss of ICM/ECM Serial Data (Instruments)
U1016 Loss of Serial Data(Audio)
U1016 Loss of ECM Serial Data (TSM/HFSM))
U1064 Loss of (TSM/TSSM) Serial Data (EFI)
U1064 Loss of (TSM/TSSM/HFSM) Serial Data (Instruments)
U1097 Loss of Speedometer Serial data (EFI)
U1255 Missing Message at Speedometer (EFI)
U1255 Serial Data Error/Missing Message (EFI)
U1255 Serial Data Error/Missing Message (Instruments)
U1255 Serial Data Error/Missing Message (TSM/TSSM/HSFM)
U1300 Serial Data Low (EFI)
U1300 Serial Data Low (Instruments)
U1300, U1301 Stalls, then Starts(Audio)
U1300 Serial Data Low (TSM/HFSM)
U1301 Serial Data Open/High (EFI)
U1301 Serial Data Open/High (Instruments)
U1301 Serial Data Open/High (TSM/TSSM)
U1302 Infotainment BUS Shorted Low/High(Audio)
U1306 Infotainment BUS Lost Communications with Hands free Phone Module(Audio)
U1307 Infotainment BUS Lost Communications with CB Module(Audio)
U1313 Infotainment BUS Lost Communications with XM Module(Audio)
U1314 Infotainment BUS Lost Communications with Navigation Module(Audio)
U1317 Infotainment BUS Lost Communications with High Output Amplifier(Audio)
Jan 31, 2014 | 2007 Harley Davidson FXDB Dyna Street Bob
Dell Poweredge 2650 error battery module is missing do not use write back mode
There are disconnects between the power modules and the circuitry within the interstice devices contained within the modular adapter. Failure to negate to consumption and communicating protocol as per the advanced module attached to the formulations concept board, only further damaging the battery module as per the mode block notification process.
Jul 31, 2013 | Computers & Internet
05 chevy uplander intermittent no crank
when turning the key to start and all the lights go off indicates a battery problem
could be dirty terminals and battery posts ( have to be shiny clean) and tight, bad ground wire to engine or bad cells in battery
it needs 12 volts to run the lights but when the starter is engaged the volts drop to below 6 volts , the lights go out
Apr 20, 2017 | Cars & Trucks
My Casio watch Battery was just changed now I can
mcdevito75 here, Return to where the battery was changed, for adjustments.
Jul 12, 2010 | Casio Watches
Ford 2005 4x4 problem.
2-Speed Torque-On-Demand (TOD) Operation
The automatic 4-wheel drive (A4WD) system is a 2-speed torque-on-demand (TOD) operation that utilizes the following components:
  • Transfer case
  • 4-wheel drive (4WD) control module (integral to the powertrain control module [PCM])
  • Mode select switch (MSS)
  • Gearmotor encoder assembly (part of the transfer case shift motor)
  • Transfer case shift motor
  • Shift motor sense plate (part of the gearmotor encoder assembly)
Principles of Operation
Transfer Case Shift Motor The externally mounted transfer case shift motor, located at the rear of the transfer case, turns the shift cam assembly. As the shift cam assembly turns, it positions the reduction shift fork for desired transfer case operation. An integral position sensor in the shift motor provides shift motor position information to the 4WD control module.
Mode Select Switch (MSS) The push button MSS, mounted on the instrument panel, allows the operator to select the 4x4 Auto, 4x4 High, and 4x4 Low transfer case operating modes. The indicator light, on the instrument cluster push button, will illuminate only when the 4x4 Low position is engaged.
Visual Inspection Chart Mechanical Electrical
  • Axle shafts and CV joints
  • Driveshaft and universal joints
  • Fluid leaks
  • Matching tire sizes
  • Battery junction box (BJB) fuses:
    • 8 (30A)
    • 17 (5A)
    • 18 (20A)
  • Central junction box (CJB) fuses:
    • 12 (5A)
    • 24 (15A)
  • 4x4 module (PCM)
  • Wiring harness
  • Gearmotor encoder contact plate
  • Connector(s)
  • Circuitry
  • Mode indication switch (MSS)
  1. If an obvious cause for an observed or reported concern is found, correct the cause (if possible) before proceeding to the next step.
  1. If the concern is not visually evident, connect the diagnostic tool to the data link connector and select the vehicle to be tested from the diagnostic tool menu. If the diagnostic tool does not communicate with the vehicle:
    • check that the program card is correctly installed.
    • check the connections to the vehicle.
    • check the ignition switch position.
  1. If the diagnostic tool still does not communicate with the vehicle, refer to the diagnostic tool operating manual.
  1. Carry out the diagnostic tool data link test. If the diagnostic tool responds with:
    • CAN circuit fault; all electronic control units no response/not equipped, refer to Section 418-00 .
    • No response/not equipped for 4WD module (PCM), Go To Pinpoint Test G .
    • System passed, retrieve and record the continuous diagnostic trouble codes (DTCs), erase the continuous DTCs and carry out the 4WD module (PCM) self test.
  1. If the DTCs retrieved are related to the concern, go to the 4WD Control Module (PCM) Diagnostic Trouble Code (DTC) Index to continue diagnostics. 4WD Control Module (PCM) Diagnostic Trouble Code (DTC) Index
    DTC Description Source Action B1317 Battery Voltage HIGH 4WD Module (PCM) REFER to Section 414-00 . B1318 Battery Voltage LOW 4WD Module (PCM) REFER to Section 414-00 . B1319 Driver Door Ajar Circuit Failure 4WD Module (PCM) Go To Pinpoint Test M . B1322 Driver Door Ajar Circuit Short To Ground 4WD Module (PCM) Go To Pinpoint Test M . B1342 ECU is Defective 4WD Module (PCM) CLEAR the DTCs. REPEAT the 4x4 module (PCM) self test. If DTC B1342 is retrieved, INSTALL a new 4x4 module (PCM). REFER to Section 303-14 . CLEAR the DTCs. REPEAT the self test. B1483 Brake Pedal Input Circuit Failure 4WD Module (PCM) Go To Pinpoint Test M . B1485 Brake Pedal Input Short to Battery 4WD Module (PCM) Go To Pinpoint Test M . C1729 Transfer Case Unable to Transition Between 4H and 4L 4WD Module (PCM) Go To Pinpoint Test K . C1970 4WD Low Mode Switch LED Short to Battery 4WD Module (PCM) Go To Pinpoint Test K . C1971 4WD Low Mode Switch LED Circuit Failure 4WD Module (PCM) Go To Pinpoint Test K . P1707 Transfer Case NEUTRAL or PARK/NEUTRAL Indication Circuit 4WD Module (PCM) Go To Pinpoint Test M . P1812 Transmission 4-Wheel Drive Mode Select Circuit Failure 4WD Module (PCM) Go To Pinpoint Test K . P1815 Transmission 4-Wheel Drive Mode Select Short Circuit to Ground 4WD Module (PCM) Go To Pinpoint Test K . P1816 Transmission NEUTRAL Safety Switch Circuit Failure 4WD Module (PCM) Go To Pinpoint Test M . P1819 Transmission NEUTRAL Safety Switch Circuit Short to Ground 4WD Module (PCM) Go To Pinpoint Test M . P1820 Transfer Case Clockwise Shift Relay Coil Circuit Failure 4WD Module (PCM) Go To Pinpoint Test K . P1822 Transfer Case Clockwise Shift Relay Coil Circuit Short To Battery 4WD Module (PCM) Go To Pinpoint Test K . P1824 4-Wheel Drive Clutch Relay Circuit Failure 4WD Module (PCM) Go To Pinpoint Test H . P1826 4-Wheel Drive Low Clutch Relay Short Circuit to Battery 4WD Module (PCM) Go To Pinpoint Test H . P1827 4-Wheel Drive Low Clutch Relay Short Circuit to Ground 4WD Module (PCM) Go To Pinpoint Test H . P1828 Transfer Case Counterclockwise Shift Relay Coil Circuit Failure 4WD Module (PCM) Go To Pinpoint Test K . P1830 Transfer Case Counterclockwise Shift Relay Coil Circuit Short To Battery 4WD Module (PCM) Go To Pinpoint Test K . P1849 Transfer Case Contact Plate A Short Circuit to Ground 4WD Module (PCM) Go To Pinpoint Test K . P1853 Transfer Case Contact Plate B Short Circuit to Ground 4WD Module (PCM) Go To Pinpoint Test K . P1857 Transfer Case Contact Plate C Short Circuit to Ground 4WD Module (PCM) Go To Pinpoint Test K . P1861 Transfer Case Contact Plate D Short Circuit to Ground 4WD Module (PCM) Go To Pinpoint Test K . P1867 Transfer Case Contact Plate General Circuit Failure 4WD Module (PCM) Go To Pinpoint Test K . P1891 Transfer Case Contact Plate Ground Return Open Circuit 4WD Module (PCM) Go To Pinpoint Test K . U1900 CAN Communication BUS Fault 4WD Module (PCM) REFER to Section 418-00 . U2023 External Node Fault 4WD Module (PCM) REFER to Section 418-00 . U2051 One Or More Calibration Files Missing/Corrupt 4WD Module (PCM) Reprogram/Reflash the 4x4 module. REFER to Section 418-00 . - For All Other DTCs 4WD Module (PCM) REFER to Section 418-00 .
  2. Your best bet mite be to take it to a qualified repair shop !
May 30, 2017 | 2005 Ford Explorer
Dell PowerEdge 2650 Server Logo
479 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
