Question about DeLonghi Pinguino PAC-360 Air Conditioner
The air is not cold enough. - DeLonghi Pinguino PAC-360 Air Conditioner
Dodge caliber 2007 air conditioner blows out some cold air but not much have enough ferone in it was told might be sensor
If it is not blowing out enough cold air it appears you may be low on refrigerant. The latter will cause the compressor to short cycle with resultant warmer than normal output temps.
Aug 10, 2015 | Dodge Cars & Trucks
My new ac unit isnt blowing out cold enough
What's the temp been out side? If its over 95 degrees only expect you air to blow at about 75. It's an air conditioner not a cold air maker.
Sep 02, 2012 | 1986 Toyota Corolla 2 Door
Freezer not cold enough to keep food frozen. The door does not have a tight seal . It is a sidebyside , Jenn-Air model number JCD2289AEW.
The door magnet must be tightly seal, check the door gasket for some deformities. If there is, that really cause the freezer not to be cold enough. It would mean, the cold air is flow outside hence not penetrating the inside so the food and drink heat are not absorbed. You can adjust door gasket using screw driver.
Thanks for asking.
Jul 04, 2011 | Jenn-Air Refrigerators
What if the heater hose going in is hot and the heater hose coming out is cold.the heater will blow cold air
Possibly the heater core is 90% blocked. open enough to draw hot water in, (hose feels hot) but not enough volume to provide heat from very cold air, 10% hot water gets cold quick, coming from core..
Flush heater core in reverse direction - cold side in hot side out..
Just a theory..
Dec 14, 2010 | 2000 Chevrolet Silverado
I have two frigidaire a/c's. 1 is not cold enough
If the compressor's running and you're not getting cold air, then, you're low on refrigerant meaning you have a leak in unit,or a dirty condenser.
Aug 18, 2009 | Heating & Cooling
Freezer is cold emnough, it's the refrigerator
Hi..
If your refrigerator is not cold enough you need to check this
  • Check the temperature setting
  • Assure that there is enough room for air flow in the refrigerator or freezer
  • Check for air flow restrictions in vents
  • Test the temperature control
  • Clean the condensor coils
  • Check the door seals
  • Test the door switch
  • Test defrost heater
  • Test defrost timer
  • Test evaporator fan
  • Check for a clogged drain tube
  • Check for refrigerant leak
Hope it may helpful for you!!!
Regards
PCmania
Jul 13, 2009 | GE GSH25JFR Side by Side Refrigerator
The refridgerator has not been cold enough, the freezer is fine what should i do?
The refrigerator itself get cold air from the freezer. There is a small opening that lets air from the freezer to go to the refrigerator area. make sure the cold air from the freezer is getting there. Sometimes there might be a restriction on this vent therefore the refrigerator is not getting enough cold air from the freezer.
Jun 28, 2009 | Amana AFD2535DES French Door Refrigerator
Freezer not getting cold enough to freeze.
First culprit could be a refrigerant leak and needs to be charged. If the evaporator is frozen solid it won't push enough sub zero air to freeze. Call a trusted ac&or repair man
Sep 23, 2017 | Frigidaire Freezers
Freezer cold but not fridge
too much ice bulid up will stop enough cold air being blown into the fridge.Try turning it off letting all ice melt then turn it back on again and set thermostat at a lower temp.There may be ice you can't see.
Aug 05, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
DeLonghi Pinguino PAC-360 Air Conditioner Logo
24 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Michael Youngman
Michael Youngman
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
