Question about Toro Garden
Toro time cutter ss5000 zero turn. Drive belt keeps slipping off and under the back pulley and stalls the motor and tears the belt. Tried new belt same failure. Two belts bit the dust.
  • 86 Answers
SOURCE: belts slipping and breaking
If you are putting on the mtd belts and installing them right then you need to check bearings in variable speed pulley Also check idler and that no other pulley has been bent from installation.
Posted on May 16, 2009
  • 37 Answers
SOURCE: Drive belt comes off the rear pulley.
Hi, this is a easy solution. on your drive pulley, there should be three belt keepers to keep the belt from coming off. ( belt keeper is a 1/4" dia. rod that goes over the pulley)
Posted on Nov 22, 2008
  • 376 Answers
SOURCE: need to find illustration of mower deck drive belt
Posted on Jun 01, 2009
  • 32 Answers
SOURCE: John Deere F620 zero turn mower
you probably have the belt on wrong, check your manual to see if you have it on right.
Posted on Jun 21, 2009
  • 1111 Answers
SOURCE: G-110 deck belt keeps jumping off pulleys
check for a broken belt tension er or maybe grass clippings under belt area, check for a broken or loose pulley bearing, even a bent shaft on the deck.
Posted on Aug 07, 2009
Timecutter ss5000 loses power
check for rusted or failing bearings on the cutter shafts
Oct 02, 2016 | Toro TimeCutter SS5000 zero turn mower
Need drive belt pattern for Toro SS5000. My mower keeps throwing the drive belt.
LOOK AT THE DECK OF A UNIT AT THE TORO DEALER AND SHOOT A PICTURE OF THE BELT.
Jun 18, 2015 | Toro Garden
Pto will not work on ss4235
could be the switch, pto assy, fuse, broken wire. belt off the pulley. take your pick
Jun 18, 2015 | Toro Mowers - Time Cutter SS4235 42""...
Why does motor try to stall after cutting for 30 or more minutes? Acts like it is running out of gas but has full tank.
check your gas cap
then check the fuel lines, if they are soft or spongy, replace
then check for spark
in this order
Aug 20, 2014 | Toro Zero Turn TimeCutter SS Series SS5000...
My toro time cutter zero turn dies when you put it in neutral...its a SS5000
what do you mean 'neutral'?
The time cutter is hydraulic drive. There is no neutral.
Please elaborate.....
May 06, 2014 | Garden
I have a Toro LX466 riding mower. The drive belt
How to replace the drive belt on a Toro LX466 Lawn Tractor
1. Jack up the front of the mower-place a couple of blocks under the front wheels (retaining wall blocks from your flower bed work great). Block the back wheels so the mower won't roll off the front blocks.
  1. Remove the battery and battery compartment from under the seat. You can now see the cooling fan blade under the seat. The belt runs from the pulley directly under the fan to the front of the tractor.
  2. Lower the mower deck to its lowest position. Remove the deck hanger rod from the slots in the front of the mower deck.
  3. Remove the metal rod guard below the engine pulley. It's held in place on one side with a bolt, and the other side with a cotter pin.
  4. Take a large pair of channel lock pliers (about 18 in long work great) and clamp them down directly on the engine pulley, but not so tightly you distort the pulley.
  5. Remove the bolt from the pulley. It's a right-handed bolt, so turn it counter-clockwise to remove.
  6. Slide the pulley down the shaft until you can work the belt off. If the belt is too tight, then remove the spring from the idler pulley under the tractor. It's hooked on a bolt near the side of the tractor. You can remove it by grabbing the end of the spring with a pair of needle-nose vise-grips and slipping the end off the bolt. Then remove the old belt from the tractor.
  7. Take a new belt (preferably Kevlar) and start at the back of the tractor (with the pulley under the cooling fan) and thread it through to the front of the tractor. The flat side of the belt rests against the idler pulley with the flat sides.
  8. Work the belt over the engine pulley and slide it back on the shaft. Tighten the bolt on the engine pulley hand tight. Then check the belt to make sure it hasn't slipped out of the groove on the cooling fan pulley.
  9. Clamp the engine pulley with the channel lock pliers and tighten the bolt.
  10. Make sure the belt is routed correctly on the idler pulleys. If you had to remove the spring on the idler pulley, replace it. You can do this by grabbing it with the needle-nose vise-grips and placing it on the bolt-make sure it's above the washer. Then remove the vise-grips and gently pry it over with a small screwdriver until it slips into place.
  11. Replace the metal guard below the engine pulley. Hook the mower deck back onto the deck hanger. Replace the battery compartment and battery. Unblock the mower.
Jun 15, 2010 | Toro LX466 22HP Lawn Tractor 13RT61RH244
I need to tighten the belt, it keeps slipping while walking on it
Unplug unit then remove motor shroud then do the following: If the problem is in the drive belt, either the drive belt will stop when stalled or the front roller will stop when stalled. If the motor, drive belt, and front roller continue to turn when the walking belt is stalled, the problem is with the walking belt slipping on the front roller. If the drive belt continues to turn but the front roller stalls, you may have a broken front roller pulley.
1) Adjusting the running belt if the problem: If the walking belt slips when walked on, UNPLUG THE POWER CORD. Using the hex key, turn both idler roller bolts clockwise, 1/4 of a turn. When the walking belt is correctly tightened, you should be able to lift each edge of the walking belt 2 to 3 in. off the walking platform. Be careful to keep the walking belt centered.Then, plug in the power cord, insert the key, and carefully walk on the treadmill for a few minutes. Repeat until the walking belt is properly tightened.
2) Adjusting Drive belt: Find the motor mounts. Many motors in Icon treadmills have a main pivot joint in which a bolt runs the full length of the motor mount. This bolt will require loosening to provide maximum adjustability. Some models have a single jack bolt and others have an auto tensioner. Single jack bolts are the easiest to adjust.
May 14, 2010 | Proform 860 Competitor Treadmill
Traction Belt (new) continues to slip off of drive plate.
Sounds like you may need to replace the pulley as well. It has likely worn out of specification.
I recommend that you contact your nearest authorized service center, or contact Toro directly for assistance.
I trust this information proves useful.
Oct 02, 2009 | Agri-Fab Agri - Fab Snow Blower - 42"
Garden Logo
553 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
