Even bought new batteries for headphones. No luck. I did attach the white and red cables to the matching ones in the front panel of TV.
    Habit-Forming:
  • 37 Answers
These are wireless headphones, I'm assuming?
Posted on Oct 22, 2013
5 Suggested Answers
SOURCE: acoustic research aw722
poop in a bucket
Posted on May 10, 2008
SOURCE: innovage wireless headphones/how to connect to TV?
I have a plasma, and found when I plugged my HDR65 to back of the plasma audio out, it worked fine. does this help?
Posted on Jan 18, 2009
SOURCE: just bought the brookstone wireless tv headphones.
I had the same problem with Brookstone wireless headset the only solution I found was plug in the red and white connectors to your cable box it works perfectly that way. Just make sure the red cable connector from the transmitter is connected to right red input connector on the box. I have a Comcast cable box. Now I need a solution for them on my PS3?
Posted on Dec 28, 2011
I have a HT Z220 Samsung home cinema and a new tv (LG M2352) I've connected it via the satelite box or cable receiver so have surround sound but is there a way I can attach my laptop to the surround...
Get a mp3 player adapter, it will have a headphone jack on one end and the red and white cables on the other end. Plug into the headphone jack on your computer, and plug the red and white jacks into the Aux input on the receiver. I didn't look at the link, but most receivers have a Aux input on them. That should solve your problem.
Aug 22, 2013 | Audio Players & Recorders
Have just purchased Toshiba 32kv500b tv and as there is only one scary socket don,t know how to attach a dvd player can you help with this problem please?
Connect the cables from your dvd player to the connections on the side, not the back, of the tv. If you are using component cables, match the colors in the 3 top ones (YPbPr) and the red and white go down into R&L just above the headphone jack. If you are using composite the plug the yellow just above the R&L connections.
Jul 06, 2011 | Televison & Video
I have a LG 19LE3300 television and i whant to be able to connect an Infra red headphone while being able to listen by the speakers at the same time. actually when i connect the hearphone it disconnect...
First you need to make a test to adjust your headphones wireless system..
.pls follow the step below:
  • "Connect the headphone base" TO " headphones output of TV" with 3.5mm stereo headphone jack cable (than Tv should mute ) Infra red headphone pilot lamp should flicker in parallel to voice coming from TV
  • Infra red headphone should have a rotary adjustment on it.. "Volume" adjustment
  • while TV talking , when you sit in front of the Infra red headphone (it works point-to-point ) you will hear the voice of TV, than adjust volume properly...Thats it..now lets go to second step..
  • Your headphone's Base should either "3.5mm stereo headphone jack" or "RCA Stereo jacks" or "bot"h..After completion of this test ,I recommend you to switch / use "RCA Audio output plugs-white/Red cable " on the back of TV instead of TV's headphone output ,since it mutes the whole sound..RCA output plugs of TV work independently from the TV's master volume control..of course you need RCA cable to connect this..
Hope this helps!..if more help requires pls let me know.
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for me to continue f
or Helping out the Community :)
Jun 30, 2011 | Televison & Video
Were can i plug my cordless head phone's in?do i need the yellow&red cable's?
You need the audio cable with RED (RIGHT channel) and WHITE (Left channel) RCA plugs at one end, the other end will have to match the Headphone base unit input jack which can be RCA or miniphone jack.
The cordless headphone base unit can get the audio signal from the TV headphone output jack or from the RED and WHITE RCA audio line out on the back of the TV.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Jun 09, 2011 | Televison & Video
Want to connect pc speakers and subwoofer to lg37lc55 tv unfortunaly it doesnt have an earphone 3.5 connection point. My other smaller tv does, the speakers and subwoofer consist of a white and red audio...
Your TV should have an AUDIO OUTPUT other than optic..at least " Headphones" output..
You can connect TV audio output with a RCA cable.
white and red audio jack....
since SUB has both RCA and "3,5mm Headphone female Jack"..here are the options;
** you need to buy a cable one end 3,5mm MALE headphone jack and the other end 2xRCA stereo (or 1x RCA for mono or you may need "Y cable " ) to be connected to your TV...
** or 2x RCA
white and red audio jack and connect from your TV..
**" "Headphones" output to SUB with 3,5 male-to-male cable ( the least recommended)
And you need to connect front,centre and rear speakers to your SUB as well...
Take care and if it succeeds please Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
May 19, 2011 | LG 42LH40 LCD TV
How do i connect a DVD player?
Use three RCA cables, yellow, white and red to connect DVD player to TV as shown in the diagram below. Connect yellow to yellow and white to white. Connect red to red. Select on the TV, the A/V input where the DVD is connected using the TV remote control. Power on TV and DVD, place a disc in tray of DVD player and press PLAY.
Mar 28, 2011 | Toshiba 22AV600U 22 in. LCD TV
Just bought the brookstone wireless tv headphones. I have a Westinghouse 40 inch lcd tv. I plugged in the rca red/white into the audio out and I don't get any sound into the headphones?
May 09, 2010 | Brookstone Surround Sound Earbuds...
After having my dish network upgraded to HD and installed, i notice on my tv now that the green and red colors are not there, predominant on channels like ESPN that use these colors most. I._E.: football...
Sounds like one of the cables got plugged in wrong.
Look at the back of the HD box and there should be a cable with 5 ends on it (Green,Blue,Red, White and Red).
Often times a flashlight can help make sure you see the colors clearly.
The Green,Blue and one of the Reds is for video. The White and other red are for Audio.
When you unplug the connector the connection it is attached to is also colored. Check to make sure the colors on the cord match the color they are connected to at the box.
The most common mistakes connecting these cables are:
1) Crossing the Green and the Blue cables.
2) Connecting the Red Audio cable to the Red Video connection.
If all of the connections match the correct colors find the same cable where it plugs into the back of the TV and check these connections that they are correct.
When you find and move the cable to the correct connection this should clear up your color and you can begin to enjoy your new toys....
Good Luck....
Jan 15, 2010 | Panasonic CT-34WX54 34" TV
Just need to know where to plug in the red, green and blue cords
The red-blue-green outputs of the cable box are COMPONENT video, and the yellow-white-red inputs on the tv are COMPOSITE video. Although the words sound almost alike and the connectors look similar, they are incompatible signals. You'll need to change either the cable box or the tv so they match. Maybe this would be a good way to rationalize getting that new home theater system! Or maybe call your tv cable company and ask for a different box with composite video output. Once the cable box matches the tv, you don't necessarily need to change the cables. If the connectors fit, go ahead and use the cables you have.
Jul 15, 2008 | Quasar SP-3235 32" TV
Acoustic research aw722
No need to plug into the back jacks on the TV or change the out put of the tv audio source to the Front jacks
Dec 29, 2007 | Acoustic Research AW-721 Consumer...
61 people viewed this question
 Grubhead
Grubhead
