Question about Kitchen Ranges
GE stove had to be moved. When plugged back in F-1 kept flashing. Prior to moving oven was heating less efficiently.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • 102,366 Answers
What model GE stove?
Posted on Jul 31, 2013
  • 183 Answers
SOURCE: Tappan Gas Range Oven Will Not Light
probable displaced burner assembly, faulty flame failure device or blocked burner or jet. Regards Engineer
Posted on Jul 28, 2007
IrishDruid
  • 2712 Answers
SOURCE: Our GE Profile Oven is not heating up (stove works)
Please check here for possible troubleshooting steps:
http://www.repairclinic.com/0088_13_1.asp#Level1_2
Hope that helps! Should you have any further questions,please feel free to post them here.
P.S. - If you find that the solution/answerI provided led you to, or resulted in a fix, please close the ticket with a FixYa!rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on Oct 04, 2008
jumptrout51
  • 3361 Answers
SOURCE: GE Profile gas range - stove works, oven doesn't heat
Set the oven for bake. Wait a couple minutes and look in the oven. If you see a orange glow the ignitor is working, but, may need to be replaced.
If you see no orange glow the ignitor definitely needs to be replaced.
Posted on Feb 21, 2009
leroyal
  • 2120 Answers
SOURCE: Oven won't heat. No gas smell. Broiler and stove work.
Bad oven control circuit board. Look up on eBay
  • 14 Answers
SOURCE: I have a GE XL44 gas stove/oven. We did some
gas valve regulator or clogged line
Posted on Sep 03, 2009
Why does my oven does not work but top burners are good
Not sure but newer stoves have 4 wires 2 110 and 1 ground and 1 neutral. Older stoves had 2 110 and only 1 ground. The oven sometimes used the ground a sa neutral for little motors, displays, etc. make sure that the third wire on your plug has a good ground and see if that helps
Jul 16, 2014 | GE Stove / Oven / RanCooktop Assembly -...
I cannot open the oven door to my GE oven. I had to move a lever from left to right. After cleaning, I moved it back to the position it should be in (while not cleaning) but the oven door is still...
Most of these self-cleaning stoves have to cool down before the door can be opened. This is a safety feature. Has the oven completely cooled down? If so you could try unplugging it wait 15 second and plug it back in. This might reset the lock.
Feb 28, 2011 | Ovens
Smell gas
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
bbv
Jul 30, 2010 | Whirlpool GS445LELS Gas Kitchen Range
Reset clock and oven light came on flashing
THERE IS A PROBLE WITH THE ERC (CLOCK) NOT TO SURE IF I WOULD USE IT EITHER. THE PART IS EASY TO CHANGE JUST TURN POWER OFF AT THE BREAKER FIRST. YOU CAN FIND THIS PART HERE.
http://www.searspartsdirect.com/partsdirec
Apr 22, 2010 | GE Profile JTP18 Electric Single Oven
We have a GE gas oven/stove top and the stove top is lighting as well as the broiler but we can not get the oven to heat up. What do you suggest we try?
i just moved and our stove in the new place doesnt bake things right. it seems that the top coil doesnt come on. its very difficult to bake anything. seems to come up to temp for pre heating, but only the bottom coil comes on. If you put it on broil, then the top coil gets hot. that works fine. tired of burning pizzas and biscuits. can anyone help with a cheap fix? dont have alot of cash.
Nov 12, 2009 | GE Ovens
GE Spectra model JBP78COB1CC
ok Jim - to answer your first question, you can still use the oven but it will be less efficient and will probably not operate at the temperature you set it at.
Yes you can replace the glass yourself. ?You will need the right glass for your model of stove and the installation kit to go with it.
You can purchase these at a website such as www.repairclinic.com
Feb 02, 2009 | GE Spectra JBP78 Electric Kitchen Range
Ge oven codes
F2 means your oven temp got too high. At least, that's what the control boards thinks. More than likely you have a bad oven sensor or bad wire to it or a bad connection somewhere between the board and sensor.
Dec 29, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Fan assisted oven
Like a clothes dryer.. simply applying heat and not moving the air will be less efficient than moving the air so the same principal applies in an oven..
Oct 03, 2008 | Ovens
F1 error code on comp screen of wall oven
The solution is people to find yourselves a better website-this one is full of problems and no solutions!!!
Jul 25, 2008 | Kitchen Ranges
GE Spectra range
All of the items you mention that do work, are 120 volt items.
All the items that do NOT work are 220 volt items.
Sounds like you have a voltage problem, you will need to use a meter to check if you have 220 volts a/c to the outlet the stove plugs into. Take care when doing the following, you will be around live voltage and could get hurt. If you are uncomfortable working with a live circuit best to call someone in to do it for you. Check for 220v at the outlet for the stove (where the stove plugs into), if you have it there, go to where the cord attaches to the stove and check at that point. You should have either a 3 or 4 wire cord on the stove, On the rear of the stove there is a terminal block that the cord is fastened to. Between RED and BLACK you should have 220v, between RED and WHITE and BLACK and WHITE you should see 120v. Another thing to check is that the nuts holding the wires from the cord to the terminal block on the stove are turned down tight. A loose connection there will give you the same problem you have as well.
Jan 07, 2008 | GE Spectra JBP78 Electric Kitchen Range
Kitchen Ranges Logo
14 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
