Question about 1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch
I have a 1995 chevy K1500 5.7L V8, I started the engine at nine oclock but did not drive it, an hour later I went to leave but my truck would not start, I realized that my fuel pump was not pumping so I bought a new fuel pump then realized the wires going to the pump were not hot (black/white and grey wire.) but the wire goin to the float was hot (pink wire.) Question 1. what would make these wires not get any electricity to them... I ran a wire from the fuse box to the fuel pump, I can get fuel to the motor that way but my injectors aren't opening, like there not getting any electricity to them either. Question 2. what would cause my injectors not to get any electricity.
    Top Expert:
  • Chevrolet Master
  • 12,223 Answers
1) the wires can break for to get electricity. 2) or loose wires or bad contacts 2) injector loose wires or bad contacts, or corroded.
The best way you can use the VOM, for continuity to each wires.
God bless you
Posted on Jul 30, 2013
3 Suggested Answers
SOURCE: My 98 chevy 1500 w/t 4.6l wont start, it turns
check the coolant temp sensor with scanner i bet it reads 40 degrees below to much fuel part is 12.77 at parts store
Posted on Apr 25, 2010
cool78259
  • 228 Answers
SOURCE: 6.5 turbo diesel wont start
check the high pressure oil switch next to the glow plug controller. if the switch is bad you will not get any fuel to your injector pump. unplug the molex and jump it out. this will bypass the switch. if it runs, just buy another high pressure oil switch. good luck!
Posted on Jul 26, 2010
Firing order diagram and timing degrees 1989 gmc 1500 series 350 engine
    How to set ignition timing 88-95 GM fullsize truck Silverado ...
    ? 10:56
    https://www.youtube.com/watch?v=y5NuS-G-cKI
    Dec 5, 2013 - Uploaded by Ghetto Wagon
    I thought the parts when the engine was running would come out better, but its just too loud. ... How to set ...
    1995 GMC Sierra V8 5.7 Distributor Timing - YouTube
    ? 3:14
    https://www.youtube.com/watch?v=mK5N5mCmyok
    Jul 28, 2013 - Uploaded by sprek2
    I had to time a distibutor on a 1995 GMC Sierra V8 5.7L and was having trouble finding the wire that you have ...
    Info on V8 Engine Firing Order - Offroaders.com
    www.offroaders.com/tech/V8-engine-firing-order.htm
    Firing Order of Most Domestic V8 Engines by Diagram.
    Chevy Engine Firing Orders 283, 327, 350, 400, 427, 454 ...
    www.mre-books.com/chevy/engines/firing_order.html
    At this site you can find the firing orders for Chevrolet engines. ... 1987-1989 ... 283, 302, 307, 350, 396, 400 and 454 Engines Firing Order, 307 Engine Firing ...Missing: degrees images for Firing order diagram and timing degrees
Jan 06, 2016 | GMC Cars & Trucks
Just changed spark plug wires, distributor cap and rotor in my 1995 chevy truck 1500. Not is doesn't start. Maybe I switched wires when replacing old wires??
firing order on chevy v8 is 1-8-4-3-6-5-7-2 number one cyl is ft left of engine left side being 1-3-5-7 from ft to rear 2-4-6-8 right side ft to rear
Aug 31, 2013 | 1995 Chevrolet K2500
How to fix the trailblazer 2004 4.2l engine timing chain
Its the same as a chevy v8 pull radeator fan water pump lower crank pully loosen oil pan bolts align timing marks crank mark at 12 oclock cam cshaft mark at 6 oclock replace with new gears and chain timing cover gasket crank seal and water pump gaskets
Jun 26, 2011 | 2004 Chevrolet TrailBlazer
I have a forestville wall clock with the pull down weights. when it chimes it is behind in time. example nine oclock chimes seven oclock, it is a made in germany clock but what year i do not know. there...
Stop the pendulum of the clock exactly at any even hour. Lets say at 6.00. While clock is steady and not working, pull off the minute and hour hands off the pinion, but do not brake them. You have to pull without any twisting action. This will leave pinions exactly in place they were when you stopped the clock. When it is done - push the hour hand back onto the pinion and make sure it is pointing at 4 (not 6, as it was when you stopped the clock). When hour hand is back in place and pointing at 4, push back minute hand as it was when you pulled it off - pointing at 12. Make sure hands will not catch when passing each other (you can bend them slightly if needed). Now swing pendulum to start the clock and adjust time (clockwise only). Never adjust time when clock is chiming. Rate me, plz.
Feb 02, 2010 | Watches
Car won't start, wait 15 min. will start but kinda backfires.
possible ignition coil pack breaking down...unit cools off them fires plugs again...fuel pressure is a concern also ..possible failing fuel pump
Jun 25, 2009 | 1995 Chevrolet Caprice Classic
1995 Buick Lesabre: security blinks and car will not start
If the starter is turning the engine, try re-setting the security system (leave key on till light stops blinking.) If the starter does not turn, you may have some success in re-setting system, if not you need to check battery voltage and voltages in starter system till you find the problem...can be something as simple as a bad connection at the battery. If you need help with further testing, just ask.
Jun 08, 2009 | 1995 Buick LeSabre
Truck won't start something to do with Anti-Theft tried removing positive cqble to reset alarm nothing, possible wire off Anti Theft Unit Truck drove fine parked for one hour and went to leave, the en
not positive but look in owner manual for a fuel pump reset button i had this problem at one time and that fixed it it is usualy under the dash area somewhere on the drivers side or in a kick panel (decorative cover on the side firewalls inside the cab)....good luck i hope this helps!
May 04, 2009 | 1993 Ford F150 SuperCab
Chevy lumina 1995 van
I have a 96 Chevy Lumina with an electric sliding side door. A few weeks ago we started having problems with it. I went to work and when I got ready to leave it would not start. I had to have it jumped. Got home and let it set over the Thanksgiving weekend. Went to start it the Mon/Tues after and nothing. Let it set another week and still nothing. We jumped it again and it took 15 minutes to get enough of a charge in the battery to get it started. Took it to a battery store and they checked the battery and said that was the problem. We replaced the battery (it wasn't that old) and went home. A few days later it wouldn't start again. Could this problem have anything to do with the electric slinding door? if so, any suggetions on how to fix it?
Feb 03, 2009 | 1995 Chevrolet Lumina Apv
1999 Chevy Blazer won't start in cold weather?
sounds like spider injectors there like $450 alone mine did that last winter looking at easy 700 to fix
Jan 26, 2009 | 1999 Chevrolet Blazer
1995 Chrysler Concorde
the alarm is activating when he locks it and for some reason the key or fob isnt deactivating it..check the disarm switches in the door
Aug 11, 2008 | 1995 Chrysler Concorde
1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch Logo
78 people viewed this question
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Mike
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
