Question about Pondmaster Garden
PondMaster 500 GPH Model 5 pump will not start after power outage?
4 Suggested Answers
  • 10865 Answers
SOURCE: shaft fell out of Pondmaster 700 Gph pump.
DANNER MANUFACTURING, INC. 160 Oval Drive Islandia, N.Y. 11749-1489 Phone: (631) 234-5261 Fax: (631) 234-4778 e-mail: Sales@dannermfg.com
Posted on May 06, 2009
gotgeek2
  • 565 Answers
SOURCE: my pondmaster pump model 18 will not start back up
Usually when those pumps start doing that the impeller needs to be cleaned. Just remove the impeller housing with a phillips screwdriver and carefully pull out the impeller. I use an aquarium tubing brush to clean the impeller. A bottle brush will work too. Be very careful when you re- insert the impeller back into the housing, as the strong magnetic force will slam it back in if you aren't holding on to it with a good grip. Try to avoid that.
It's also possible that the impeller is going bad and needs replaced (probably about $40 for that pump). Sometimes the bushings wear out too.
Check inside the motor housing for scoring, not good. The only cure for scoring is to replace the pump.
I
Posted on Jul 10, 2009
  • 634 Answers
SOURCE: My Pondmaster Mag 3600gph pump quit working too
welcome to pond life they rarely last more than 1 to 2 years
Posted on Jul 17, 2009
Pump works but not enough power for proper lift
I can believe that. Measure your lift, then look at the data sheet to figure out what your output should be. If I have the correct one it is rated at: 950 GPH Maximum Flow with a 12'10" Shut-Off. Try: http://info.dannermfg.com/dw1/pdf/pondmaster_catalog.pdf
that has a lot of information.
Sep 15, 2013 | Pondmaster Magnetic Drive Utility Pump for...
I just bought the Pondmaster 260 pump from Overstock. There are NO instructions in the kit. Do you have a manual I could download on line? Thank you. Ellen Goodell
The manual is located on the Pondmaster site in PDF format: http://www.pondmaster.com/instructionsheets/ZG098.PDF
If you need the program to view it the reader is free at: http://www.adobe.com/products/acrobat.html
May 12, 2011 | Pondmaster PM 250 gph Mag Pump Pump 250...
Do you submerge this pump?
Yes, at least enough for 2 inches over the pump.
Apr 03, 2011 | Pondmaster 140 GPH Magnetic Drive Utility...
Jun 27, 2009 | Danner Pond Pondmaster 500 Gph Mag - Drive...
Shaft fell out of Pondmaster 700 Gph pump.
May 06, 2009 | Danner Pond Pondmaster 700 Gph Mag - Drive...
What is involved in changing water pump 2000 300m
remove the upper radiator support panel, remove the engine front covers, remove timing belt (should be replaced when replacing water pump). You will need a large bench vise to compress the timing belt tensioner. Book says to remove the crank pulley but you can get by without doing it. Be sure to wash all of the spilled coolant out of the timing belt area as coolant tends to do nasty things to timing belts.
Mar 06, 2009 | Danner Pond Pondmaster 500 Gph Mag - Drive...
Is power to the pump insides; if the best thing is to re place it; I couldn't repair my same pump.
Oct 31, 2008 | Danner Pond Pondmaster 500 Gph Mag - Drive...
Garden Logo
46 people viewed this question
Top Pondmaster Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Pondmaster Garden Expert? Answer questions, earn points and help others
