Question about Microsoft Xbox Console
Xbox controller thanks djyar. i have tried wired and wireless controllers. i even tried another xbox, one that worked on another tv, but not on this one. it has to be something in the connection or wiring. i also tried another game, it also didn't work correctly. just spun in circles. guess i'll take it in somewhere and see what's up with it. could it be my electrical outlet? i checked it and it reads ok. any other suggestions??
Wow me 2 but hay like blow the cables ends and it should work :) it worked for me good luk
Posted on Dec 18, 2007
SOURCE:
Touch buttons on x box 360 not working
If buttons of your controller is not working we need to check the ff: Wireless controller: 1. Check the wireless adapter if properly connected. 2. Reseat the wireless adapter. 3. Check if you are getting stable green lights in front of the xbox for connection notification. TIP: It will be better if your wireless adapter is the wireless-N adapter. 4. You can check other wireless device to connect to xbox to isolate adapter issues. 5. If adapter is failing, replacement is needed. Wired controller: 1. Controller needs to be checked. 2. Controller needs to be tried to a friends xbox. If working,port might be faulty. 3. If controller seems not to work with a different xbox.controller needs to be replaced. Thanks for choosing www.fixya.com
Dec 05, 2011 | Microsoft Video Game Consoles & Games
Just bought a used xbox 360 controller online. It is a wired controller. When i plug it in to the xbox I just get green blinking light
that means you have to many controllers registered to the system I have had this problem multiple times with my xbox if anything take a wireless controller or even a guitar hero or rock band guitar and take batteries out if that doesnt work then sync one of the controllers to a different xbox.
Aug 02, 2011 | Microsoft Xbox 360 Controller
How do i reactivate the wireless controller to my xbox 360
How to Configure an Xbox Controller Fotolia.com"> configure-xbox-controller-800x800.jpg Configure you Xbox controller.
The Xbox 360 utilizes two types of controllers: wired and wireless. Like most operations on a video game console, configuring a controller requires little effort. You can either plug the controller into a port on the Xbox 360, or sync a wireless controller using the console's built-in controls.
Difficulty:Easy Instructions
  1. Wired
    • 1 Connect the controller's cable to the in-line release cord. This cord prevents you from accidentally pulling the Xbox 360 along with your controller during game play.
    • 2 Insert the in-line release cord's USB plug into the USB port on the front of the console.
    • 3 Turn on the console to activate the controller automatically.
    Wireless
    • 1 Insert batteries in your wireless controller, if necessary.
    • 2 Hold down the "Guide" button on the controller.
    • 3 Push the Xbox 360's "Connect" button, located on the front of the console.
    • 4 Push the controller's "Connect" button to sync it with the Xbox 360.
Read more: How to Configure an Xbox Controller ' eHow.com http://www.ehow.com/how_7780486_configure-xbox-controller.html#ixzz1PRsAYmUA
here is a video on how to sync your wireless controller to your xbox360 console
http://www.youtube.com/watch?v=GpV-b1de2lM&feature=related
if you think this help please rate me sir thank you so much!!!
Jun 16, 2011 | Microsoft Xbox 360 Console
My madcatz xbox 360 controller will not connect to my compaq pc. The controller works and installs easily on my laptop. I have downloaded all necessary items from microsoft (xbox 360 controller for...
Vista has an issue with Xbox 360 controllers, let alone Madcatz copies. I would recommend buying an official wired controller for use with Vista. Alternatively you can you a Wireless Gaming Receiver specially designed for using Wireless Controllers on Windows based PC's.
Mar 21, 2011 | Microsoft Xbox 360 Controller
My Xbox 360 wont sync any of my wireless controllers and the powe
if your wireless controllers wont sync to your xbox, it could be one of 2 things.
assuming your batteries are fully charged, and that you're using a certified xbox controller, it could be that the controller itself. it is really rare that the wireless receiver inside the xbox itself, goes out, but soemtimes, it happens.
the easiest thing or you to do would be to either pick up an after market controller, or another certified controller, and see if they'll work. if you try other controllers, and they STILL dont work, verify that your system settings are correct, or are set to default, and make sure that your xbox isnt sitting close to something that could be interfering with the signal....like a wireless router for example
if this doesnt work, then it's a problem with the xbox, and you should send it back to the service repair center.
Sep 24, 2009 | Microsoft Xbox 360 Wireless Controller
Wired xbox 360 controller's constantly 'disconnect'
It sounds like it needs replaceing. Sometimes Radio shack has the wireless Xbox360 controllers on sale for 40$ and Gamestop sells used ones for around the same price. Also wireless is much better.
Sep 09, 2009 | Microsoft Xbox 360 Controller
Xbox 360 controller one wireless two wired
The port on the XBox has gone bad or there is dirt or something in the port. Use compressed air to blow out the port and see if it helps. If not the unit needs repair.,, try this out and see...
thank u rate me
Feb 10, 2009 | Microsoft Xbox 360 Controller
Xbox 360 wireless contoller won't sync with game console
If you're using an HDMI connection between the Xbox 360 and the TV, it might be that. When using HDMI, the Xbox won't boot up until it knows what the TV is capable of displaying. Although the controller will turn the console on, it won't sync with the console -- and it's not a controller or console problem, but just a symptom of the fact that the Xbox won't get to the point where controllers will sync until it can properly communicate with the TV. I'd recommend turning off the TV and the Xbox, disconnecting the HDMI cable and re-connecting it after making sure the contacts are clean. Then turn the Xbox back on first; you'll likely to see the same behavior. Finally, turn the TV back on. With it being switched back into HDMI mode, it just might "kick-start" the Xbox into a good communication link across HDMI. Hope that helps.
Jan 18, 2009 | Microsoft Xbox 360 Controller
360 wireless controller
Hey tavis,
Try this, make sure if you have any cord controllers, that they are unplugged.
Turn off the console.
Make sure the controller is off too.
Turn on the console, and then press the wireless sync button on the console itself.
Then, press the sync button the controller. This should def work for you.
If it still does not work, it sounds like something could be wrong with the system, since you say it works on a friends.
Is this the first time using a wireless controller on your 360?
Try using your friends wireless controller since it works for his, just to see what it does on yours.
-Chad
Dec 09, 2007 | Microsoft Xbox 360 Controller
Wireless Controller not connecting to console.
Hey guys,
I've had the same problem today. The controller wouldn't connect no matter what. The strange thing was I could still turn the console on using the controller, but afterwards it wouldn't do anything.
Now I think I found a solution, at least for my case. All I did was to remove the HDD (that thing on top of the console) and put it back in. Then I started the console again using the controller and it was instantly connected.:)
Now I just hope it stays this way.;)
Sep 20, 2007 | Microsoft Xbox 360 Controller
Microsoft Xbox Console Logo
24 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Ekse
Nathan Hamilton
Nathan Hamilton
Paul Castley
Paul Castley
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
