Question about Calypso 32" 720p 60hz Led-lcd Hdtv Clp-32le110
Calypso tv screen goes black randomly - Calypso 32" 720p 60hz Led-lcd Hdtv Clp-32le110
Montior goes black i turn off the monitor and turn it back on i can do about 2 things and screen goes black again repeat this as many times as i want. Gateway FHX2300 monitor
My monitor has been switching connections on me randomly. Hit the menu button. The one to the left of the power butter when facing the screen. Hit the left arrow twice then hit the menu button again. This will open up the screen where you can choose one of three inputs. I'm going to assume that it is on the incorrect input so use the arrow keys highlight what input you are using and the hit menu button again and your screen should return to normal. Mine only does this randomly when it goes into screen saver, hibernate or sleep. I don't know how to permanently get it to stop doing it though.
Aug 23, 2010 | Gateway FHX2300 LCD TV
Half the tv screen goes black randomly,then returns to normal
The Tuner signal board have problems.The board CPU,Chip,have intermitten short.When the chip is completely dead.The tv will get only LED light indicator power only,will not get tv signal pictures.
Apr 12, 2010 | LG 42LC2D 42 in. LCD HDTV
LG 52SX4D turns off randomly.
My Lg 52"tv turn off and on
Apr 29, 2009 | Televison & Video
Screen goes black randomly during use and tv shuts off
check your capacitors cp150 114 120 if any of them is puffed up on top it is bad replace all 3 cap. 2200uf 1`6v and two 220uf 35v. also resolder FBT pinns.
Feb 02, 2009 | RCA HD52W59 HDTV Projection Television
Sony Wega 27in Randomly Has Block Box Appear On Screen
this means the TV having picture upper part of the screen. problem may be -15 V to vertical deflection ic suddenly gose off and system control gose to stand-by mode resolder vertical out ic , -15 v supply line from the fly back and system control .
Jan 15, 2009 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Screen randomly goes black and then comes back on
If this happens on all disks then the unit is dying a slow *****. Get ready for the DAY it goes completely.
Sep 07, 2017 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
TV Screen goes black
all tv has built in tuner inside,search for variables for inner tuner.when the signal is not fix naturally it goes black and white or destorted/blurred.
Oct 17, 2008 | Akai Televison & Video
Screen 1/2 black with random caption in middle side
CHANGE CAPTIONS SETTING YOU HAVE IT ON TEXT1 TURN OFF THIS SETTING. IN YOUR SETUP MENU
Aug 16, 2007 | Sanyo DS24205 24" TV
Calypso 32" 720p 60hz Led-lcd Hdtv Clp-32le110 Logo
49 people viewed this question
Top Calypso Computers & Internet Experts
David Payne
David Payne
Are you a Calypso Computer and Internet Expert? Answer questions, earn points and help others
