Question about Campbell Hausfeld Garden
What is average going price for a new or used wobble pump for a Campbell Hausfeld PW2200V1LE. My 6.0 Briggs & Straton engine is in very good condition Reason I ask is a brand new pressure washer in my area is $225.00 - $250.00. I live in panhandle of Florida near Pensacola.
    Sergeant:
  • 402 Answers
Keep the briggs if your just gonna use it for yourself get the sjv axial pump 239.00 put it on your briggs.many retail stores use s disposable pump no sightglass or drainplug sjv has forged brass head no pot metal.
Posted on Aug 06, 2013
5 Suggested Answers
Monster80
  • 460 Answers
SOURCE: When trigger is engaged under pressure nothing happens.
Make sure all of the water is bleed out of it buy holding trigger down with motor not running until theres is not more bubbles or air that comes out..Make sure where the inlet for waters screen is not plugged..You may have to back flush washer to clean out or to unstick the pressure valve..Hope this helps you and have a great day
Posted on Apr 06, 2009
  • 5603 Answers
SOURCE: lose of pressure on Campbell washer
Usual cause is the pressure valve sticks closed and doesn't admit more water to be pumped. Usually needs new O RIngs and cleaning the bore... ABout a 15 minute job at most. Get an O Ring kit for it.
The valve is held shut when pressure on the output is high. When you open the trigger, the pressure drops and the valve opens letting more water come in from your garden hose.
The O RIngs dry out and bore gets dirty. Polish it with crocus cloth on a dowel rod. Lube the O Rings with lube intended for O RIngs.
Posted on May 08, 2010
Testimonial: "You hit the exact problem. After many discouraging information from repair people I got pump to repair in Springfield TN. He took back to shop - 10 minutes back with repair. Man what a releaf .. in a throw away, buy a new world. Thank you... you are great!"
SOURCE: What kind of oil do
The pump uses SAE20 or SAE 30 non-detergent motor oil that fills up about half way
The engine uses 10-W30 motor oil that comes a bit more than half-way up dip stick.
Do not turn washer on its side or upside down to drain oil, or oil will run into carburetor.
If you have problems starting:
read:
http://www.fixya.com/support/t6504468-craftsman_2700_psi_pressure_washer
Posted on Nov 09, 2010
heatman101
  • 43501 Answers
SOURCE: Campbell Hausfeld 1.6 Electric Pressure
There are many things that "could" be causing this....most likely after running for that long something got hot and melted/burnt up......
To find the problem, the only way to do it effectively will be to plug it in and the follow the power to see where the power stops at....there is a good chance that is in right in the wiring around the start switch....a connection that got hot and then loose and now not connecting anymore....
If you have power to the motor and it is not running then the motor has gone bad..
heatman101
Posted on Jun 18, 2011
Need to see a diagram of a campbell hausfeld clean power 37 unloader valve
Most all of the manuals for campbell hausfeld tools are found at www.chpower.com , just look for your model number. Also , campbell hausfeld does not make all their pressure washer pumps. Yours may be another brand. To find who makes yours look on ebay. Make search for {pressure washer pump only} and look for one that matches yours. Then look for that breakdown. Good lu ck.
Oct 12, 2017 | Campbell Hausfeld Air Tools & Compressors
I need to separate the pump from the 5.5hp gas engine
usually held in place by 4 alen key or hex bolts. sometimes very difficult toslide appart.
be sure to meassure shaft size as they are usually different size on each motor size graduation.
Aug 22, 2013 | Campbell Hausfeld Pressure Washer Gun -...
WL506201AJ Campbell air compressor. 4 gallon
The Campbell-Hausfeld breakdown of your compressor shows the part number for your compressor's pump is WL372001AL. If you go to www.ereplacementparts.com and do a part number search, you'll get a good breakdown of your pump with part numbers. The piston and cylinder come as a kit and it's the only way to get either part. You can get the parts you need there or use the part numbers to search the web to see if you can find better prices. That site has fair prices and their S&H isn't too bad either.
Feb 21, 2013 | Air Tools & Compressors
Can't find reed valve replacements for 1999 campbell hausfeld?
I am a C-H service center and using the model number VS5006 I got the following:
- Your Pump Part Number was originally VS260000KB, now it's VS260000SJ. That's the complete pump and suggested retail is $199.99.
- The valve kit for that pump is part number VS261000AJ. The kit includes all the gaskets, reed valves and valve plates between the head and cylinder, suggested retail is $33.80.
You can go to http://www.ereplacementparts.com/ and, using the model number VS5006, see a breakdown of your compressor or, using VS260000SJ, see a breakdown of the pump to make sure we're talking about the same air compressor and pump. The parts are available through them or you can use the part numbers to search other sites for better prices.
Feb 21, 2012 | Campbell Hausfeld 5HP 20 Gallon Single...
I am in need of prices of briggs and straton gas driven pump powered by a 5.5 hp engine
Hi , you did not say what country your in but a rough price for a new one is 900 dollars .
The link below is to a pump sales site
http://www.waterpumpsdirect.com/Briggs-&-Stratton-073017/p3185.html
Aug 08, 2010 | Coleman Powermate Premium Plus 6250W...
Lose of pressure on Campbell washer
May 08, 2010 | Campbell Hausfeld PW2102 Gas Pressure...
Need new pressure regulator for Campbell Hausfeld
their web site is chpower.com can order on line if not to old can check warranties also they can direct u to service location in ur area
Feb 01, 2010 | Campbell Hausfeld Air Tools & Compressors
Garden Logo
74 people viewed this question
Top Campbell Hausfeld Garden Experts
John Trevino
Mike Squire
Are you a Campbell Hausfeld Garden Expert? Answer questions, earn points and help others
