Question about Health & Beauty
Hi Ive got a Jiajue 150cc outlaw scooter and it has blown both front headlights & the parker light bulbs have gone black. Ive put in 2 new light bulbs for headlights & they still wont work, is there a trick to this?
  • 29 Answers
SOURCE: volvo v40 main beam light wont work
its the switch unit itself
Posted on Mar 19, 2009
goofduck
  • 490 Answers
SOURCE: Headlight wont work, doesn't seem to be the bulb
no it will not
it sounds like the bulb is bad
clean the corrosion with a small wire brush
and try a new bulb
Posted on Apr 13, 2009
  • 4088 Answers
SOURCE: headlight on my jmstar scooter will not come on
Operate the dimmer switch--does one beam come on? Check inside the headlight shell and examine the wiring from the lamp socket into the handlebar and main harness wiring. If individual connectors, check that the colors match at each connector. If you can't find any problem, then the wiring is mis-connected. Make sure the lamp socket is connected to ground.
Posted on Sep 08, 2009
nedkelly900
  • 345 Answers
SOURCE: Znen Scooter Headlight keeps burning out!!!!
sounds like you have too much voltage coming out from your battery, mabey a faulty regulator. The easiest way to test this, is to get a multi - meter, and check the volage output at the battery, with the engine running, at idle should read about 12.5 - 13 volts. Then rev the bike up, and seeif the reading changes, it should not go more than 13.8 or 14 volts max. If it does, then i say you have a faulty regulator/ rectifier.
Posted on May 03, 2010
  • 311 Answers
SOURCE: my headlight keeps burning out on my znen tommy
hi,sounds like your voltage regulater has failed,it is supplying to much voltage to the bulb and causing it to burn out,if you dont have a voltmeter take the bike to a garage and check the voltage ,with the bike running at about 2500rpm,the meter shouldnt read more than about14.2-15.0v,if it does,that means it is faulty,hope this helps...cheers
My headlight blew and now my TaoTao 50cc has no lights whatsoever what would cause that
Hi, Bill if your headlight is not working, only one beam works, keeps burning out, blinking, or is dim the first thing you need to check is the headlight bulb for damaged filaments then check your light circuit fuse, then check your head light bulb socket ground wire for a clean tight connection, that being said the usual suspects are:
1. Faulty ground or power supply wire to headlight bulb socket.
2. Worn down solder contacts or loose fit of the bulb base in the socket due to vibration.
3. Worn, chaffed, or broken wires in the light circuit.
4. Corroded, broken, or loose pins/sockets in wire connectors.
5. Faulty hi/lo beam switch.
6. Faulty ignition switch.
7. Fuse is good but no continuity on both sides.
8. Faulty wiring between battery positive and headlight bulb socket.
9. Weak charging alternator/generator.
10. Faulty voltage regulator/rectifier ground or overcharging.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
HEAD LIGHT BULBS BURNING OUT
Why is my Tao Tao scooter headlight shorting out
http://www.family-motorsports.net/GY6-50cc-150cc.pdf
https://taotaopartsdirect.myshopify.com/collections/thunder-50
TaoTao ATM50 A1 Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Apr 28, 2017 | Motorcycles
Why won't my headlights dash lights and TAIL LIGHTS come back on??? I tried the REGULATOR, not the problem it just stopped on its own. It's a 150cc Jonway scooter
Hi, Crystal you may have a blown fuse or faulty lighting coil for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Jonway, despair not, for a mere $10 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Jonway 150 no lights
Lights aren working HELP Scooter Doc Forum
What to troubleshoot when the headlight isn working scooters
Gy6 50cc 150cc Scooter Repair service Manual Download Manuals Technical
Jun 05, 2016 | Jonway Motorcycles
Have a PRO F-Sports 4 Stroke 150cc Scooter. Headlights don't work. All other lights are ok.
Hi, Dan if your headlight is not working the first thing to check is the headlight bulb for damaged filaments then check your light circuit fuse, that being said the usual suspects are:
1. Faulty ground or power supply to headlight bulb socket.
2. Faulty hi/lo beam switch.
3. Faulty ignition switch.
4. Fuse is good but no continuity on both sides.
5. Faulty wiring between battery positive and headlight bulb socket.
Good luck and have nice a day.
Aug 10, 2015 | Motorcycles
Head light not working I see two brown wires are hanging
Hi, Anonymous if your headlight is not working the first thing to check is the headlight bulb for damaged filaments then check your light circuit fuse, that being said the usual suspects are:
For more information about your issue, please visit the websites below. Good luck and have nice a day.
Taotao ATM150 Evo scooter headlight troubleshooting and bulb replacement
How To Replace Headlight On Jonway Scooter
DOWNLOAD Bajaj Pulsar DTSi DTS UG 180 Service Repair Workshop Manual...
http://www.marutibajaj.com/pdf/Pulsar%20180%20ug3.pdf
http://ondoc.logand.com/d/1735/pdf
Apr 24, 2014 | 2007 Bajaj Avenger 180 DTSi
My headlights is not working on my polaris 4x4 magnum 4 wheeler is there a fuse box anywhere how can i fix my headlights please help?
Possible blown bulb. If yours is like mine then you can remove the lens in front to access the bulb. If the unit is still under warranty do not touch it. Contact the place you purchased it and have them replace it. There may be a reason that the bulb blew out that a simple bulb cannot correct.
Mar 22, 2014 | Pride New Mobility Legend 4 Wheel Scooter
2005 Honda Activa headlight dim
Hi, Anonymous if your headlight is not working, only one beam works, keeps burning out, blinking, dim or surges from bright to dim to bright the first thing you need to check is the headlight bulb for damaged filaments then check your light circuit fuse, then check your head light bulb socket ground wire for a clean tight connection, that being said the usual suspects are:
3. Worn, chafed, or broken wires in the light circuit.
8. Faulty headlight relay.
9. Faulty wiring between battery positive and headlight bulb socket.
10. Weak charging alternator/generator/lighting coil
11. Faulty voltage regulator/rectifier ground or overcharging.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
http://www.instructables.com/id/Make-your-Scooter-Motorcycle-Headlight-Brighter-by
one headlight EXTREMELY dim Honda Civic Forum
http://www.partsfish.com/page/oem-parts-for-honda
Honda activa 2009 Owner Manual
Jan 22, 2014 | 2005 Honda Activa
My headlight keeps burning out on my znen tommy 150cc scooter every few days i have to put a new bulb in WTF?
May 03, 2010 | 2007 TN'G Low Boy 150
Both headlights do not come on (regular or daytime running lights) but the high beams do work
you have blown the head light fuse or the bulbs beacaue hi beam a seprate bulbs and the parkers to
Aug 02, 2008 | Toyota Corolla Cars & Trucks
Health & Beauty Logo
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
