Question about HP Hewlett Packard LaserJet 5200 Printer
How do I clean the printer?
Hi, The only link I can find on HP and other resources for cleaning a printer (which is causing streaks) is to do it on the printer menu and print out a cleaning sheet. This worked a bit, and the printer isn't too streaky, but I want to clean it manually. How do I do this?
yooperbud
  • 8637 Answers
SOURCE: Streaks on photo sensitive drum HP laserjet 5MP
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 28, 2009
SOURCE: STREAK LEFT ON RIGHTHAND SIDE OF PRINTED PAGE
Fuser sleeve is contaminated and needs replacing - cheaper to replace the printer.
Posted on Apr 17, 2009
Joed911
  • 4338 Answers
SOURCE: HP J5680 is printing and scanning vertical gray stripes
The fix is on this link:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00704831&cc=za&lc=en&dlc=en&product=3301296
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Posted on May 03, 2009
yboyandrei
  • 828 Answers
SOURCE: HP CP1700 prints wrong colors with streaky
your printer heads is built-in in your cartridge.... if that printer prints wrong colors your using refill ink....
Posted on Jun 16, 2009
nalin_elliot
  • 224 Answers
SOURCE: HP officejet Pro 7580 problems with streaking
Clean the electrical contacts on the printhead and inside the product The ink nozzles on the printheads might clog if they are exposed to air for more than a few minutes or if the product is not used for long periods of time. Follow these steps to clean the electrical contacts on the printheads. CAUTION: Follow these steps carefully to avoid damaging the sensitive electrical components.
  1. Make sure that the product is turned on.
  2. Open the top cover of the product.
  3. Press and hold the OK button for five seconds. The carriage moves to the left side of the product and stops. Release the OK button.
  4. Wait until the carriage is idle and silent.
  5. Unplug the product power cord from the electrical outlet.
    NOTE: Do not turn the product off by pressing the Power button (c01346625.gif ). This causes the carriage to move out of reach.
  6. Lift the printhead latch. Figure 1: Lift the printhead latch c01448109.gif
  7. Lift the handle on the printhead that the error message indicates is missing or damaged, and then pull the printhead out of its slot. Figure 2: Lift the handle and remove the printhead c01448110.gif
  8. Use a dry, soft, lint-free cloth to remove any ink from the electrical contacts on the printhead.
    1. Wipe the electrical contacts with the swab until no ink residue remains, and then wipe the electrical contacts with a fresh cloth to dry them and remove lint.
    2. After the electrical contacts on the printhead are clean and dry, place the printhead on a sheet of paper or a paper towel. Make sure that the ink nozzles face up and do not touch the paper.
    3. Use a fresh, dry, soft, lint-free cloth to clean the electrical contacts inside the product. Figure 4: Clean the electrical contacts inside the product c01448112.gif
    4. Allow at least five minutes for the contacts to dry. Check the contacts for lint or debris, and then dry or clean the contacts again if needed.
    5. Plug the product power cord into the electrical outlet.
    6. Press the Power button (c01346625.gif ) to turn on the product. 'Printhead missing or damaged, replace the printhead' displays on the control panel.
    7. Insert the printhead into its color-coded slot. Press down firmly on the printhead to make sure the electrical contacts touch.
    8. Pull the printhead latch all the way forward, and then press down firmly to engage the latch.
      NOTE: You might have to press firmly to engage the latch. If the error message indicates that both printheads are missing or damaged, repeat the steps in this procedure to clean the other printhead.
    9. Close the top cover of the product. The product restarts and then prints an alignment page.
    10. Click on setup on the printer select tools and select clean printhead.
    11. inside the printer clean the metal carriage rod,rollers and that is it (clean with moist cotton swab)
Posted on Jun 23, 2009
Ink streaks
Ink streaks are usually caused by a buildup of died in on the print heads. There are two print heads in that unit. Remove one at a time and look for build up - clean it if you find any. Once you finish cleaning both print heads you will need to do a print head cleaning routine in the HP software to clear out any in clogging the print nozzles.
Oct 01, 2012 | HP Officejet 6500 Wireless All-in-One...
How do I fix a dark streak down center of scanned document on HP laser jet 3330
Lines and streaks are usually caused by ink or trash blocking the scanner pickup. You need to open the top of the scanner and clean the scanner glass. Here is a link to a guide that shows where to look for something blocking the sensor.
http://www.ccl-la.com/blog/index.php/lines-on-scanned-or-copies-pages/
May 07, 2012 | HP LaserJet 3330 All-In-One Printer
I have an hp LaserJet 3015 PCL-6 all in one printer, copier & fax. When I use the copy function, there is a black streak running down the length of the copied paper. I tried replacing the toner...
Clean the thin glass strip that sits to the left of the flat bed glass.
That is the glass used when the ADF is being utilized.
There is dirt on it causing the black streak.
Oct 11, 2011 | HP LaserJet 3015 All-In-One Printer
HP 4650dn printer, two problems: 1) color streaks on the print out 2) black color a bit gray, and turn a a bit white when superimposed on other colors (except yellow)
Please use the Print Quality Troubleshooting Tool for your printer's model at the following link:
http://h10039.www1.hp.com/cpso-support-new/pq/4650/home.html
This will take you through a step-by-step process to diagnose the cause of the problems you have & correct them.
Feel free to let me know if you need any further assistance.
Dec 17, 2010 | HP LaserJet 4650 Color Printer
What can I do if my printer is printing with streaks of white on my document.
Clean your printer head and nozzle with printer utility software. Hope it would solve your problem, if not, change black cartridge. Thanks.
Sep 29, 2009 | HP PSC 2175 All-In-One InkJet Printer
Where are the printheads so that I may clean them to avoid photo streaking?
Hp in cartridge.
3 causes:
Empty
Left to long in hot dry environment
Incompatible 3rd party refill.
They are at bottom of cartridge and you can try to get them going with a few moist cotton swabs.
If you got 3rd party junk refill, forget it.
The head is that rectangular metal looking plate
Apr 15, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Cleaning of the printer
If the fuser is causing the streaks, then you should replace the fuser. There is no cleaning to fix it. However, there are other things that can cause streaking; toner cartridges, tranfer belt.
Apr 07, 2009 | HP Color LaserJet 2600n Printer
Gettig streak from top to bottom of page
HI,
it seems that the printer head is the problem you can try to clean it so can also include the roller.
thanks,
Mar 21, 2009 | HP Color LaserJet 2600n Printer
Streaks when scanning and the glass needs cleaned how do I get in to clean the glass on the underside
Here's a link to the instructions for opening the top of the scanner:
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c00553775&dlc=en&product=90809
BG
Oct 04, 2008 | HP PSC 2175 All-In-One InkJet Printer
HP 7410 streaks when using auto document feeder to make copies
the document feeder of that unit have its own scanner glass. try opening the document feeder and clean the scanner glass with a lint free cloth that is moist with water and also clean the rollers of the document feeder
Aug 13, 2008 | HP OfficeJet 6210 All-In-One InkJet...
HP Hewlett Packard LaserJet 5200 Printer Logo
mukhtar21 shaikh
mukhtar21 shaikh
