Question about NEC MultiSync FE991SB 19" CRT Monitor
Wavy like lines
Ok my dad got on my computer (no clue what he did) now my moniter has like wavey lines on left side of screen and everything has like outlines coming off of it what is the problem plz HELP!!
  • tw1st Aug 31, 2007
    umm its a compaq fs7600 im not good at computer thats just things on my moniter
    ok i guess its called shadowing/ghosting can u help me fix it plz!!!!!!!!!!!!
I SEE DOUBLE THE PICTURE AT THE TOP LEFT IS WAVEY
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded over.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 28, 2010 | Hitachi 53UWX10B 53" Rear Projection...
Wavy colored lines of captioning at all times, can't turn off
Try first unplugging the power cord for fifteen or twenty minutes , see if this can reset and fix the problem.
Sep 11, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Phillips 60" projection screen tv. Wavey lines at top and bottom of screen center is very blury and wavey almost looks like 3d. Audio is fine. How do i fix this
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs.
Jul 19, 2010 | Philips 60P8341 60" Rear Projection...
Vertical wavy line on moniter screen
Change the Resulation (HZ 60). or replace the LOT if monitor is old...
Jul 10, 2009 | Computers & Internet
Wavy Lines
some type of electrical feedback try upgrading your cables or tightening the ones you have. what might work best is a line conditioner i filters out any feedback you may be getting and cleans your power supply they cost from 50.00 and up best buy or circiut city both carry them or online as well
Jul 17, 2008 | Sony KP-53HS10 TV
Red wavey lines at bottom fo screen
Red wavy lines across my screen...model HCL4715W Samsung
Jul 11, 2008 | Televison & Video
Wavey lines
This may be a problem with the TV rather than the DVD. Usually wavy lines are caused by some of the AC signal leaking into the video signal. It is possible that the DVD player power supply is the source of this as well. Check the filter capacitors in the power supply of the DVD player first.
Dan
Dec 11, 2007 | Sony DAV-S500 System
Wavy Vertical Line
you have AC ripple getting into your horizontal output. you have a power supply problem in the monitor. take it to get it fixed.
Jun 26, 2006 | Gateway EV 700 17" CRT Monitor
Monitor problem
If still under warranty or if you have no electronic repair experience you should take the set back to the shop or to a repair person. Some of the solutions described below can be dangerous, TV's are very hazardous to service. Even when plugged out, TV's can store very high voltages. May need to check the caps in the G-2 supply circuit. Also you may have a CRT going flakey. Just a slight G2 level adjustment may suffice also. Good luck
May 19, 2006 | Compaq MV 540 15" CRT Monitor
NEC MultiSync FE991SB 19" CRT Monitor Logo
Top NEC Computers & Internet Experts
Steven Wander
Steven Wander
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
