Question about Kenmore HE2 Plus Front Load Washer
Kenmore he2 plus model 110.47532602 power turns on, select cycle, press start button and the washer turns off. have changed the drain pump and ccu board already.
110.4753 error code f01
I found this on the WEB-In reference to your Kenmore HE washer, model number 110.4753:
F-01 Error code
EEPROM ERROR
PUMP DRIVE ERROR
, or a
MAIN RELAY ERROR
EEPROM ERROR
: A communication error between the
Central Control Unit
(CCU) and the
EEPROM
onboard the
CCU
occurred.
PUMP DRIVE ERROR
: The pump driver fails to operate
MAIN RELAY ERROR
: One of the main relays is not working properly
Mar 31, 2014 | Kenmore HE2 Plus Front Load Washer
He2 plus front load washer keeps showing f21 error code i cleared the drain pump filter and it still displays the error code f21 how do i check to see if the pump is not working
Hi
CCU/Touchpad/LED assembly error (f21)
This error occurs if the touchpad/DED assembly is not able to transmit/receive data to/from the central control unit (CCU)
1. Check the touchpad/LED assembly by selecting different cycles and changing the modifiers and options available to confirm the touchpad/LED is responding 2. Unplug washer or disconnect power for five minutes. This will reset the CCU, and may reactivate the communication if the damage isn't severing. 3. Check Wire Harness connectors to the touchpad/LED assembly and Central Control Unit (CCU).
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Aug 05, 2011 | Kenmore HE2 Plus Front Load Washer
Sd code
Hi
Thanks for using FixYa. Error 5d or Sd means too much detergent was used. Try the following procedure---
Run the unit through a RINSE/SPIN cycle.
Run a NORMAL cycle without adding any detergent.
This should clear the unit of the excess detergent. If still the problem persists, then please check the following things--
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the drain pump, pressure switch, and Central Control Unit (CCU).
4. Check/clean drain pump filter of foreign objects.
5. Plug in washer or reconnect power.
6. Check drain pump.
7. Check the pressure switch.
8. Verify CCU operation by running a Diagnostic Test or any cycle.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 20, 2010 | Kenmore HE2 Plus Front Load Washer
Water pump to drain water activates but doesn't drain water from machine
Hi, Make the following check: 1. Unplug washer or disconnect power. 2. Check wire harness connections. 3. Check drain pump. 4. Check drain pump motor. 5. Check that the drain hose and drain pump filter are clear of foreign objects. 6. Plug in washer or reconnect power. 7. Verify CCU operation by running a Diagnostic Test or any cycle.
Apr 11, 2010 | Kenmore HE2 Plus Front Load Washer
F1 error on Kenmore he2 plus model 4619790225122
F01 - There may be an internal problem with the control, attempt a Hard Reset.
Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
* Unplug or turn the circuit breaker off for 30 seconds.
* Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
* Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
* Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
The F01 generally indicates a failed electronic machine control board.
This error code can sometimes be caused by a glitch or power surge through the electrical lines.
You may be able to clear this code by unplugging the washer for 5 minutes.
If the code returns after plugging the washer back in, then the electronic machine control board will need to be replaced.
The procedure for accessing and replacing this control board is shown in this image...
http://media.fotki.com/1_p,wkwdftgtbkdgfrwxgtqsskgwtqkq,vi/ksrttqdqrxkssrqtgsd/1/1303472/5961857/image12917img-or.jpg
Be sure to unplug the washer before accessing internal components.
When you access the control board, I recommend transferring the wires from the old control board to the new replacement control board one connection at a time.
Once you have all of the wires transferred, remove the old control board and mount the new control board in the washer.
Reassemble and test the washer.
The "F01" error code indicates a communication error between the Central Control Unit (CCU) and the EEPROM onboard the CCU.
The "F01" can also be displayed if the onboard "Pump Driver" fails to activate.
Generally in order to correct this failure will require replacing the CCU.
There is no way to test and verify if the control board has failed.
The technical data sheet basically states to replace the CCU.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Feb 09, 2010 | Kenmore HE2 Plus Front Load Washer
Kenmore he2 plus washing
CCU/Touchpad/LED assembly error(f21)
1. Check the touchpad/LED assembly by selecting different cycles and changing the modifiers and options available to confirm the touchpad/LED is responding 2. Unplug washer or disconnect power for five minutes. this will reset the CCU, and may reactivate the commmunication if the damage isnt sever. 3. Check Wire Harness connectors to the touchpad/LED assembly and Central Control Unit (CCU)
Replace failed component.
Sep 18, 2009 | Washing Machines
Code 5d comes on and it stops running
5d means the follow; possible causes * If too much detergent was used -Run the unit thrugh a RING/SPIN cycle. -Run a NORMAL cycle with out adding detergent. PROCEDURE * This should clear the unit of execess detergent. 1.- Check the draing hose and male sre it is not plugged or ****. 2 Unplug washer or disconnect power. 3.-Check wires harness connections to the drain pump, pressure switch, and center Cotrol Unit (CCU). 4.- Check/clean drain pump filter of foreign objects. 5-Plug in washer or reconect power. 6.- Check draing pump. 7.- Check the pressure switch. 8.- Verify CCU operation bu running a Diagnostic Test or any cycle. "Was this helpful?"
May 11, 2009 | Kenmore HE2 Plus Front Load Washer
ERROR CODE F33 AND 5D
5d possible causes * If too much detergent was used -Run the unit thrugh a RING/SPIN cycle. -Run a NORMAL cycle with out adding detergent. PROCEDURE * This should clear the unit of execess detergent. 1.- Check the draing hose and male sre it is not plugged or ****. 2 Unplug washer or disconnect power. 3.-Check wires harness connections to the drain pump, pressure switch, and center Cotrol Unit (CCU). 4.- Check/clean drain pump filter of foreign objects. 5-Plug in washer or reconect power. 6.- Check draing pump. 7.- Check the pressure switch. 8.- Verify CCU operation bu running a Diagnostic Test or any cycle. F33 MUST be fix by a technition Service ONLY am sorry about this inconvenient. "Was this helpful?"
No manual ...no power- how do I work this machine? I'm able to lock/unlock it
THIS IS THE ONLY THING YOU CAN DO
Check that the unit is plugged into a working outlet and for
blown fuses.
This must be done by a THECHNICIAN SPETIALIST
Check continuity of line cord and line fi lter.
Check harness connections to CCU.
Check the touch-pad/LED assembly by selecting different
cycles and changing the modifi ers and options available to
confi rm the touch-pad/LED is responding.
Unplug the harness to UI and check with a DVM or VOM on
Connector UIP3 if correct voltage is present.
Pin 1: -5V
Pin 2: 0V (connection to Line or neutral is present in
normal operation).
Pin 3: -12V
If voltage not present and CCU is powered correctly (line
cord and linefi lter has continuity) the CCU is broken.
Disassemble the UI and check harness to UI and
Interconnection on UI between Center and Right Board.
Was this helpful?
May 09, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore HE2 Plus Front Load Washer Logo
69 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
