Question about Clavia Nord Stage 88 EX
How do I open up a Clavia Nord Stage 88 EX in order to repair a broken key?
2 Suggested Answers
  • 5603 Answers
SOURCE: Clavia Nord Stage EX88 dir. in active monitor
It is VERY easy to send to high a level to speakers.
A few important things:
ALL interconnected equipment MUST be powered from a single point. This avoids ground loops that can set up feedback. Powering monitorss at one end of a room from a receptacle and the synth at the other end of the room is inviting trouble.
REMEMBER that audio sent to the speakers that is causing the damage MAY be well above one's hearing range!
Use BALANCED audio lines where possible. CHECK that in's and out's are compatible, for instance both BALANCED TRS.
Use PROPER cables for interconnecting. Using plain stereo TRS cables for interconnecting TRS balanced lines is a NO-NO... they are cheaper but invite trouble.
If in close proximity to radio transmitters, interference can be a problem due to rectification of the radio signals that can create frequencies beyond the hearing range that can damage speakers.
The starting point is a post mortem on a failed speaker to look for damage.
The Behringer definitely requires a TRS or XLR input. I searched for a user manual online for the Nord but was unable to find one to verify they have a balanced output to run to the monitors.
There is a possibility that a filter in the NORD is NOT working, allowing digitizing noise to be presented on the output audio causing overloading of the tweeter speakers. The best way to check that is with an oscilloscope if you have access to one.
I would turn down the high eq on any active speaker to reduce the signal to the tweeter as an interim step.
Posted on Apr 30, 2010
Head set jack broken off in hole
I would unscrew the case to fix it only if it is out of warranty. Take it back to the dealer. Casio gives 3 years or 5 years warranty depending on the country.
Mar 16, 2014 | Casio Privia Px-130 Px130 88 Key Digital...
A key can't raise up
The unit will have to be opened and the key restored to the normal position. Most have a spring, sometimes a leaf type that holds the key up and locked in. When opening the unit care must be used as there are ribbon cables between the halves of the cover.
Aug 16, 2011 | Casio Privia Px-130 Px130 88 Key Digital...
After transport the keyboard,half of the keyboard below c4 not work.
Probably a cable has come loose inside the unit. The keys are scanned by the internal processor as a matrix of two contacts per key. Often the keyboard is divided into two sections.
You will need to have it repaired or if you are electronically adept, open the case and look for obvious problem.
Mar 17, 2011 | Kurzweil SP3X 88-Key Stage Piano
Hi there, I have a Nord Stage EX 76 and played a gig on friday night outdoors. I have set the keyboard up and now one or two of the notes occasionally sound much louder than they should. The problem...
What has happened is that one of the contacts on those notes is not working properly. Each key has two contacts. One makes before the other as the key is pressed. The processor MEASURES the time between those as you hit the key to read the VELOCITY you have hit the key with. This velocity is often used for loudness on many voices such as the piano. These contacts are USUALLY conductive rubber pills suspended in silicone rubber "domes". One can disassemble the key area and clean BOTH the black rubber pills and the circuit traces they are pressed against using Q Tips and ONLY 99% isoprophyl alcohol to restore proper operation
One needs to be very careful when disassembling unit as there are many tender ribbon cables and connectors. Best to have clear work area and two people to "control" the halves of the shell while opening..
Nov 07, 2010 | Clavia Nord Stage 88 - Digital Stage Piano...
The after touch sensitivity on the Nord Stage EX 88 seems to be very low and I need to press down very hard to make the sound that I want with it. Please help.
Here is a link to their support where you can download the latest operating system, manual etc.:http://www.clavia.se/main.asp?tm=Support Consider joining the forum. There are always helpful members who quite likely have experienced some of the same problems. You didn't mention if that happens when you play piano, organ or synth as the setting changes you make can affect each differently. Here is a link to the download page for Windows:http://www.nordkeyboards.com/main.asp?tm=Downloads&cldwn=Nord_Stage_EX&osdwn=osw Here is the one for Mac:http://www.nordkeyboards.com/main.asp?tm=Downloads&cldwn=Nord_Stage_EX&osdwn=osx Pages 61 and 62 of the manual are good starting places. Aftertouch can be assigned to different functions. You will need to read Morph Assign also on page 60. Page 33 explains Velocity Sensitivity which is different from Aftertouch. If the Aftertouch is not giving you enough control over a parameter, try using the Wheel or a pedal for that parameter instead. Here is a link to the manual:http://www.nordkeyboards.com/downloads/manuals/nord%20stage/Nord%20Stage%20EX%20Manual%20v6.x%20%28eng%29.pdf The Factory Reset function is on page 68.
Aug 24, 2010 | Clavia Nord Stage 88 - Digital Stage Piano...
Nord keys not making sound
This will have the weighted keys.
The contacts for the dead keys are dirty and have to be cleaned. This type keyboard is NOT DIY unless you are adept at electronics. The actual contacts are accessable after a lot of dis-assembly.
They are conductive rubber that is pressed against circuit traces on circuit board.
Use ONLY 99% isoprophyl alcohol and QTips to clean both the contact and the circuit traces they press against. Clean ALL the contacts when you have the unit open as others are sure to become inoperative as well.
Jul 20, 2010 | Clavia Nord Stage 88 - Digital Stage Piano...
Clavia Nord Stage EX88 dir. in active monitor damage the speakers (tweeter) ? Happened twice with active monitors: Peavey Impulse P1020 and Behringer B-300 Peter ;-)
Apr 29, 2010 | Clavia Nord Stage 88 - Digital Stage Piano...
When I plug the sustain pedal in, it remains on sustain (regardless of whether I push the pedal or not, so it's not the polarity that's a problem)
Try testing your switch for function by testing it with a volt ohm meter to make sure the cord and switch are functional. In this case if it is the recommended foot switch it will be momentary on or off. That is if you are using your meter to test across the plug, when you press down you should have no resistance displayed if there was resistance when you connected the probes or resistance displayed if there was none when you originally connected the probes. If the switch is good, your problem is internal to the keyboard and you will have to troubleshoot the circuit on the board. Another possibility is the solder joint has failed where the sustain pedal jack is mounted or the jack itself has failed.
Jan 24, 2010 | Clavia Nord Stage 88 - Digital Stage Piano...
One of the buttons is sticking on my Nord Stage (the amp button). How can I fix it?
FROM DOCTOR FIX . SPRAY WITH WD 40. THEN CLEAN UP WITH A PAPER TOWEL, ALL SPRAY.
WD 40 IS NOT A OIL, IT IS A STRIPPER.
Jul 07, 2009 | Clavia Nord Stage 88 - Digital Stage Piano...
Clavia Nord Stage 88 EX Logo
46 people viewed this question
Top Clavia Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Clavia Music Expert? Answer questions, earn points and help others
