Question about Maytag Washing Machines
Maytag Model A104 Washer
Trying to find out how much water is used during both the 'partial load' and 'full load' settings - owner's manual is long gone...
the dr
  • 447 Answers
SOURCE: Maytag Washer, Model # MAH4000AWW (Neptune - front loader) appr. 4 yrs old
Hi john, There is a blue cover that i am suspecting you are missing from the softener/bleach dispenser. It fits over the two tubes in the dispenser and it siphons the water out. It is part number 22002266. Also the machine has a water filled balance ring. It is normal to hear sounds of water when the tub is turned. If you can see water in the spinner its a different story.
Posted on Nov 24, 2007
aborcass
  • 2651 Answers
SOURCE: Torn bellow on Maytag front load washer
there is a spring style clamp holding it to the front panel simply peel back slightly and "pop" it off, then holding it to the inner tub is a screw style clamp, depending on yr of production, either a 5/32 scrwe or a phillips, holding it in the 2 oclock position, release clamp andreinstall boot, it might take some time to get to fit backaround hte tub but itll bo, you gotta walk it on in spots ( like changing a tireon the bikes as a kid) itlll strectch over the rim and fit, just have to work it
Posted on Dec 03, 2008
SOURCE: Maytag Legacy washer MAV408DAWW loud noise, dumped all water
Tub bearings and seal have failed. My SAV405DAWW just started with the loud grinding and I am now in the process of finding out if I can fix it myself. Kurt
Posted on Jan 13, 2009
milten1
  • 1304 Answers
SOURCE: Maytag Neptune Front Load Washer Model MAH4000AWW low last spin
two problems here,
your shaft seal is running on its last leg
the sound is unmistakeable and always described the same...
the water issue, you probably have a trickle leak through the cold water valve
the mixing valve is quite an easy repair, but I would have to say with all honesty, it probably time for a new machine
the hub seal is a tub replacment call
2 hrs of labor if hes good
and the tub runs around 500.00 dollars
sory for the bad news
Posted on Oct 10, 2009
SOURCE: I have a maytag Atlantis washer - 7 years old, it
I have a Maytag Atlantis top load washer which leaks in the rear right hand corner under the discharge hose, how do I take the machine apart to get to the problem.
Posted on Feb 06, 2010
Maytag centennial washer not working properly in Normal cycle. After it shuts off there is still water in the bottom of the tub. I can move the dial to another setting such as Casual cycle or Heavy Duty...
We have the same problem. The Normal cycle still works, but after the final spin cycle, water is again added (1 gal est.) and the machine stops. Problem occurred after washing an old 25 x 30 inch rug which partially disentegrated when washed. We were seeing particles of the rug in subsequent wash cycles during drain into laundry tub. Don't know if something is plugged in the washer or if it is something else. In another load after the rug wash, the top of the washer was lifted during the wash cycle. The water problem occurred immediately after lifting the lid as the wash load went through remaining cycles. Maybe this affected the timer? Maytag customer service suggested unplugging power cord to re-set timer. This didn't make any difference. We need a technician to tell us if this is a timer problem or something else?
Oct 03, 2011 | Maytag Centennial 3.2 cu. ft. SuperSize...
During a cross-country move, several heavy items were loaded on top of the door of my Neptune top-load washer; now the water jets at the back of the machine are misaligned with the door and water sprays...
Give it a try you might beable to bend it back. See the pic below. Grab the Service Manual it with help you with
disassembly.
Google this; Neptune TL Washer FAV6800AWW
This is a DIY Appliance repair forum and you can get the Service Manual and repair support at that site..
In the Sticky: Neptune TL Washer FAV6800AWW 5 post down you will find a link to the Service Manual. You absolutely need the Service Manual to DIY issues with the machine. It's not the best SM but will get you started. I also have repair post in that sticky to help with the most common issues that I have helped owners with. I'm an owner of a FAV6800AWW top load machine.
Good luck.
Apr 15, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Just trying to find out drum capacity of my maytag heavy duty super capacity 7 cycle washer. Please help
Check the tag where you find the model and serial number, they often list it there. Your owners manual should tell you as well. You might have to call whirlpool (maytag), I cannot find the capacity listed on the tech info. Good luck.
Sep 23, 2010 | Maytag LAT2600A Top Load Washer
I have a Maytag Atlantis MAV6200AWW. The washer
hi
the solenoid on the cold water is gone down or it is not fed with electric
Jan 29, 2018 | Maytag Atlantis MAV6451 Top Load Washer
Cold water pours in during final spin
There is something clogging your pump, dismantle it to clear it. Plug off the wall socket mains first.
Jan 15, 2009 | GE WDSR2080D Top Load Washer
My Maytag front loading washer does not fully rinse cloths MAH8700A. I purchased this washer about 6 months ago. I usually wash small loads but have noticed it doesnt matter what size load. When first...
Is the drain path free-flowing? That is, does the water eject freely during spin/rinse? Maybe there's a restriction in the line, or it's too high above the washer.
Feb 25, 2007 | Maytag MAH8700A Front Load Washer
Washing Machines Logo
101 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
