Question about NEC PlasmaSync 42MP3 42 in. Television
NEC plasmaSync 61mp1
I changed the blown fuse but the green light flashes 3 times then the red once. I do not have the remote. The screen does not light up. The fans run for about 4 seconds and shut down the light start flashing
  • 2 more comments
  • Anonymous Nov 22, 2007
    no remote--tv will turn on and in 2 seconds turn off--green to red and I hear a pop. changed the plug--changed the surge protector--help??
  • Domino Man Aug 31, 2008
    Same problem powers up... light is green for about a minute but screen is not on.  Light starts blinking 3 times green 1 time red and repeats...   Please help...
  • tezzauno Oct 23, 2008
    I have the same problem in that the green light comes on and i hear a click as if the screen wants to start but after about 30 seconds the green light goes off and the red light flashes, after a while the green light comes on again, another click is heard and then the red light flashes again and this continues with no picture. It is as if the screen wants to start but something is stopping it. i had it repaired 18 months ago which cost £450 and don't know if it's worth me repairing again.
  • aburns342 Mar 24, 2009
    I have a 61 inch NEC Plasmasync 61mp1. I turned it off and now, all of a sudden, it will not turn on. The indicator light blinks red/green. Unplugged, hard switch power button don't fix the problem.
    Genius:
  • 1,153 Answers
This sounds like the engine or the lamps are bad.
Posted on Sep 04, 2007
61mp1 nec plasma keeps shutting down after 5 minutes, when switch on picture ok
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Mar 23, 2016 | NEC PlasmaSync 61MP1 61 in. Television
NEC plasmaSync 61mp1 problems
Here is the link for the user manual if you need it; http://www.necdisplay.com/Documents/UserManuals/PX-61XM1A_MAN_2ed.pdf Check page 54 of the manual (61 of the pdf) right at the bottom. The lights you have indicate that either the power supply citcuit, the screen, or one or more fans have been damaged. If you are sure all the fans work, then the power supply is the only repairable posssibility. replacing the screen is not worth it. The fact that the fuse blew but doesn't blow again makes me suspect one of the transformers or capacitors in the power supply has blown, causing the short that blew the fuse, but also then melted the short so it no longer blows the fuse. If you have a multimeter, and ideally an ESR meter, with a good photo of the power supply unit we can hopefully talk you through what to check - otherwise get a repair shop to look at the power supply. Hope this helps :)
Aug 31, 2007 | NEC PlasmaSync 61MP1 61 in. Television
Cannot get it to change input on NEC
You may have the child lock enabled on the front panel, visit the NEC website to download the owner's manual to your television, search the manual document for the text "child" and there should be a two button simultaneous depression to disable the child lock feature. Check eBay for a remote control if needed.
Dec 22, 2013 | NEC PlasmaSync 61MP1 61 in. Television
Monitor displays half screen sometimes and goes back to full screen later. Some days you get the full screen but today it is half screen one time and then full screen another time. It finally quit...
The monitor have problem in vertical section of the board.Maybe the vertical output or any parts around the vertical ic is loose connection circuit,what we called,cold solder so its better to resolder the board at the vertical section.
Jul 11, 2011 | NEC PlasmaSync 61MP1 61 in. Television
The screen remained totally black and the italian nec sayd there is non way to fix it
Everything is "Fixable".
I suspect that if there is no light at all, (in a dark room, nothing) then the high voltage is missing, 125Volts or so. All Plasma screens work on a similar principal; power to make the gas flash to produce UV light and a processor producing the strikes of light. If there is light then the upscaler is not working and that will be panel changing as I doubt their engineers will understand how it is fixed.
That is the only two options that I am aware of. Which includes the power supply of course as that is where the voltages come from.
Dec 23, 2010 | NEC PlasmaSync 61MP1 61 in. Television
NEC Plasmasync 61mp1 - won't turn on
Its the power supply board. If you cant get the whole board, check your transistors theyre most likely FSXXX-X (part #). Replacing them should solve the problem. And they're only about a dollar each so youll save a bunch too but it requires a little more work.
Mar 24, 2009 | NEC PlasmaSync 42MP3 42 in. Television
61MP1 turns off after 5-10 minutes
Ryan
I have a 61MP1 that wont turn on. I get the green flashing light to signal power but nothing happens with the plasma. You seem to know a fair bit. A guy in UK said he'd supply a new power board for $500 but wants my old one in return. Sounds like it might be something I can fix here. Any suggestions. Barry
Aug 02, 2008 | NEC PlasmaSync 61MP1 61 in. Television
Broken plasma broken 61
I need one too
bigbad@optonline.net
Nov 06, 2007 | NEC PlasmaSync 61MP1 61 in. Television
NEC PlasmaSync 42MP3 42 in. Television Logo
279 people viewed this question
Top NEC Televison & Video Experts
Kyle Steven OHare
Kyle Steven OHare
Jaime Hernandez
Are you a NEC Televison and Video Expert? Answer questions, earn points and help others
