Question about Health & Beauty
How do I fix a right motor fault on a Jazzy Elite 614 HD. I have checked all of the trouble shooting suggestions with no luck
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 346 Answers
Hello Steve,download as a PDF File to read with an Adobe Reader:SHOPRIDER SERVICE MANUAL 2007 1-800-743-0772 .It is 36 pages,19 - 36 is all about wheelchairs,i am sure this will help you.Have a nice day & hope you get mobile soon,Colin.
Posted on Jul 31, 2013
3 Suggested Answers
  • 692 Answers
SOURCE: i need directions to unlock
kari with the jazzy try turning the power on and immediately push the horn button twice I think this will take it out of sleep or lock out mode. If that doesn't work turn the power on and immediately push the joystick forward until you hear a beep then immediately push it to the rear until you hear another beep then release it to the center. Good Luck Hope this helps
Posted on Oct 29, 2010
  • 63 Answers
SOURCE: My husband has a Jazzy
Hi,Im going to have say no your chair has the four small wheels and the two big wheels.The big wheels are your drive wheels and the only have two kinds of tread street which is a smooth tread and knobby tread ,he may have knobby tires they come standered on the 614 .The four little tire are basic as well and cannot be changed out they only made that type.
Sorry about that hope I was of some help.
Posted on Jan 20, 2011
Jazzy 614 HD. Motor runs but the wheel does not turn
hi T. Phelps, sounds like the coupler situated between the motor and gearbox is broken etc.
Regards
Rob
Jan 31, 2016 | Pride Jazzy 614 Hd JAZZY 614HD
Right wheel turns slower than left one causing chair to turn right only?
hi Robert, normally this is because of the motor on the left hand side either needs new brushes or the brake is not freeing 100% , at worse it is a joystick fault ... check the joystick connections.. and the connections to the left hand side motor
Regards
Rob
Oct 28, 2015 | Pride Jazzy 614 Hd JAZZY 614HD
Speed fluctuating on controller. goes from slow to fast without me touching controller on pride jazzy 614 hd battery powered chair
Your controller is dirty. Unfortunately, the unit is sealed and you therefore can do other than replace the unit. I suggest monster scooter parts at Jazzy 614 HD Parts The cost is high at $377.00. If you were really into fixing electronics it is possible to take the unit apart and clean the joystick, but that is a stop gap measure until you get your new joystick. Let me know if you need instructions on tearing the joystick apart and I will help if I can.
Jul 22, 2014 | Pride Jazzy 614 Hd JAZZY 614HD
What does a jazzy 614 power chair 9 flashing wrenches need?
hi, that is the code for a brake fault , check the wiring to the brakes located on top of the motors...
Regards
Rob
www.gewizrepairs.co.uk
Jul 05, 2014 | Pride Jazzy 614 Hd JAZZY 614HD
Left brake fault may not be engaged.
Each motor has a brake system attached to them. One of them isn't working and is sending a fault signal to the controller. It needs to be serviced.
Jan 26, 2014 | Pride Jazzy 614 Hd JAZZY 614HD
What is a left brake fault?
hi, the brake on top of the motor on the left hand side ...
Regards
Rob
Code 5 error
There are several different controllers used on this model. The most common is the PG Drives models. If you have 5 bars flashing on a PG Drives joystick this indicates an issue with the right motor. There is a known issue with the Pride motors in that the wire inside the insulation breaks, causing and open and the fault code. Check the motor with a meter at the connector. If it reads over 2 ohms or infinity then you need the right motor replaced... or rebuilt.
Jul 12, 2013 | Pride Jazzy 614 Hd JAZZY 614HD
I have a Jazzy 614 HD scooter. The right tire seems to skip and not get traction
The newer Pride Jazzy and Quantum series are known for motor failure where the wires become broken inside the wire insulation at the wire entrance to the motor housing - so the break can not be seen. It starts as a shutter and is intermittent.
(The motor wire's gauge / strand count is too low for the repeated flexing when the motor articulates during acceleration and deceleration)
Eventually the break completely and you are stuck.
If the chair is less than 18 months old take it back to the dealer and demand a warranty replacement. If they don't fix it then contact your State Attorney General regarding elder and disabled abuse. Seriously!
Mar 16, 2013 | Pride Jazzy 614 Hd JAZZY 614HD
My Power Chair is flashin three code
hi, if it 's stays three pause three then the error "Left Motor wiring fault" , now I suggest you remove the lead from the controller and refit check the connections are clean and tight.
Regards
Feb 17, 2013 | Pride Mobility Pride Jazzy 614 HD
Blinking yellow wrench light on pride jazzy 614 HD
Your version has a Dynamic Controls model controller and joystick.
Unplug the charger and engage the motor/brake lever so the chair is no longer in free-wheel mode (con't push by hand)
Turn the chair off, wait 5 seconds, turn the chair back.
If chair still does not run and your wrench is flashing you have a problem. Count the wrench flashes - the flash count indicates the error detected. 3, 4, 5, and 6 flashes indicate and error with the motors.
3=Left motor fault
4=Right motor fault
5=Left brake fault (may not be engaged)
6=Right brake fault (may not be engaged)
Any other fault code usually means the electronics or wiring is bad and not worth fixing.
Jan 06, 2013 | Pride Jazzy 614 Hd JAZZY 614HD
Health & Beauty Logo
66 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
