Question about Plumbing
How can I fix our Hansgrohe Swing C pressure balance valve so that the handle does not loosen?
Very soon after installation, the handle on our Hansgrohe Swing C pressure balance valve started to loosen, so it is difficult to control the water temperature. Our contractor has tightened the inside screw several times, yet the problem immediately recurs. We have managed to live with this problem, yet now must rent our home (due to unemployment) and therefore need it to finally work properly. Is this a common problem and, if so, please advise how to *permanently* fix it.
  • 49 Answers
SOURCE: grohe trim pressure balance valve
i looked at it and there might be a press in cap with a screw underneath where the grohe label is. there also may be a set screw around the shoulder of the handle where an allen hex wrench fits to losen its clamp on the stem. also.......some handles just snap on and just pull off with some tugging and wiggling them just right.
Posted on Jan 23, 2009
  • 299 Answers
SOURCE: Hansgrohe 06358620 shower not hot enough
Remove the handle by loosening the screw near the bottom. You should see a plastic ring, probably green, that is the hot water safety. Adjust it so that the handle will turn further for more hot water. It most likely pulls out, then turn it left, reinsert and reattach the handle.
Posted on Apr 28, 2010
Testimonial: "Thank you so much for your help! Will try it out - your instructions are clear and sound do-able! "
  • 83 Answers
SOURCE: Our Kohler Fairfax kitchen faucet 12176 has a
was the base installed under the faucet..is there a single hole in granite...faucets usually come with a long base to cover the holes in sink..or with one round ring for granite installation..which the faucet should be mounted on..
Posted on Nov 22, 2010
woobie dog
  • 1273 Answers
SOURCE: hansgrohe single handle bathroom faucet handle is
Look under the lever for an allen screw.
--W/D--
Posted on Jan 21, 2011
jyackle5
  • 8197 Answers
SOURCE: Hello, I've got an old
You can get a replacement valve for your faucet by calling speakman at (800) 537-2107
Posted on Aug 16, 2011
Adjust handle stop on Metro high arc
Is it possible that you have installed the faucet incorrectly . Loosen it off and turn 90 degrees facing you so that one way is cold the other way hot.
May 08, 2013 | Hansgrohe Metro E Single Handle Deck Mount...
Hansgrohe axor faucet jammed
On this model the escutcheons will turn counter clockwise and the whole handle will lift off as one unit. In some cases water deposits can cause the handle to stick and you may need to use CLR to lossen the deposits. In some other cases installers will put the handle on first and then tighten the valve to the deck. This causes the handle to be too tight to the deck and can strip the handle fixation. Try loosening the the valve set below the handle and see if the handle is easier to remove once the valve is loosened. If you need further help feel free to contact me at Hansgrohe Technical Services at 1-800-334-0455. Press 2 for Tech and ask for David Scarborough.
Sep 16, 2012 | Hansgrohe 31063001 Metris S Widespread...
How to adjust water pressure
To adjust the pressure on this type of valve you simply rotate the handle counter clockwise from the off position. As you rotate the handle it will increase the volume as you increase the temperature. Feel free to contact me at Hansgrohe. David Scarborough 1-800-334-0455.
May 06, 2012 | Hansgrohe 06358620 Pressure Balance Valve...
Rebuild Hansgrohe equilibrium pressure balance valve
This can most likely be resolved by replacing the cartridge. Turning off the hot and cold water to the unit is a must to replace the cartridge. If you need assistance with part numbers, breakdowns or instructions feel free to call me at 1-800-334-0455.
Apr 13, 2012 | Plumbing
We have a moen legend 3175 one handle with pressure balancing valve. how do you get the handle off
There is a hex head allen screw on the underside of the handle. Loosen it and gently pull out on handle while tapping on handle body with non-marring tool Thank you.
Dec 20, 2010 | Moen 3175 Legend One Handle Shower Faucet...
Apr 26, 2010 | Hansgrohe 06358620 Pressure Balance Valve...
How do you set up pressure balance in shower tap? Turn off any tap upstairs and it makes a noise now.
That is air in the lines you need to bleed system turn off water open highest faucet and lowest let system drain and then turn off lowest and turn water on slowly so air bleeds out the highest faucet when system is full bleed all faucets out for 5 minutes each it can take a couple of days for air to dissapate from system
Nov 08, 2009 | Hansgrohe 06358620 Pressure Balance Valve...
Hansgrohe concealed thermostatic mixer ref no 1537418
check for sediment in your valve body... sometimes sediment can build up particularly in hot water pipes and that can cause the pressure balancing function of the valve to limit total hot water and therefore you cant get it hot enough... here is a link to what I think is the proper valve and the instructions for installing it... you'll want to follow the instructions for flushing and pressure testing... if you have good pressure at the thermo body then you might try adjusting the hot limit stop also covered in the document linked below...
http://www.hansgrohe-usa.com/JP/hrgh0264.pdf
Hope theat helps...
Oct 25, 2008 | Hansgrohe Plumbing
Plumbing Logo
Top Plumbing Experts
Paul Carew
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
