Question about Hansgrohe 32070821 Talis S Single-Hole High Swing Spout Bath Faucet Brushed
Hansgrohe retroaktiv thermobalance II shower control low hot water flow even with shower head removed.
4 Suggested Answers
  • 148 Answers
SOURCE: '99 Hansgrohe Aktiva Family Set. All heads & controls are leaking
the temp control knobs have little plastic tabs over the hot and cold handles. To remove them take a flat blade screw driver( small with sharp head) or a small pen knife( cover drain with a wash cloth
and pop the tabs off
Take a medium size phillips screw driver and tighten the screw
Put tab back o and you are done
If they work loos again remov e tabs, screws put loctite ( You can get a small tube for m ace or hd) screw threads and tighten
Temp control knob either has same tab or has a hex type of set screw or has a large lock nut
use a channel lock pliars over nut ( protect chrome finish by putting washcloth over then put wrench over cloth
You mentioned heads I am assuming shower head you need to use an adjuatible wrench to turn the nut (at head) and a vice rip or chanel locks over washcloth around the eustaceon ( chrome pipe coming out of wall
If you have teflon tape put that on the threads of showr head and tighten
Best of luck to you!
Posted on Jan 04, 2009
  • 50 Answers
SOURCE: hansgrohe concealed thermostatic mixer ref no 1537418
check for sediment in your valve body... sometimes sediment can build up particularly in hot water pipes and that can cause the pressure balancing function of the valve to limit total hot water and therefore you cant get it hot enough... here is a link to what I think is the proper valve and the instructions for installing it... you'll want to follow the instructions for flushing and pressure testing... if you have good pressure at the thermo body then you might try adjusting the hot limit stop also covered in the document linked below...
http://www.hansgrohe-usa.com/JP/hrgh0264.pdf
Hope theat helps...
Posted on Jan 05, 2009
  • 299 Answers
SOURCE: Hansgrohe 06358620 shower not hot enough
Remove the handle by loosening the screw near the bottom. You should see a plastic ring, probably green, that is the hot water safety. Adjust it so that the handle will turn further for more hot water. It most likely pulls out, then turn it left, reinsert and reattach the handle.
Posted on Apr 28, 2010
Testimonial: "Thank you so much for your help! Will try it out - your instructions are clear and sound do-able! "
The water flow from my triton electric shower does not stop even after unit is switched off
28487001 is not an electronic shower head made by Hansgrohe. It is an overhead shower head that has no electronic parts. Triton is a completely different company. If you have an electronic shower system by Triton you will need to contact Triton. If you have a Hansgrohe product feel free to contact Hansgrohe at 1-800-334-0455.
Apr 13, 2013 | Hansgrohe Showerhead Shower Power ...
I need a water restricter
Most manufacturers of faucets and shower heads install flow restriction devices at the factory when building the products. These devices are proprietary in most cases and are made to be difficult to remove and in some cases removal will damge the product. There may be some after market flow restriction devices that are made to be installed between the shower arm and shower head but I am unaware of any specific models or brands. If you need help with any Hansgrohe products feel free to contact Technical services at 1-800-334-0455.
Mar 29, 2013 | Hansgrohe Home
Hansgrohe PB shower cartridge (brand new) passing water thru cold side with valve turned off. Six-year old cartridge replaced the other day. Removed side filters and cleaned. O-rings ok. Applied silicon...
What is the model number of the unit in question? What color was the old cartridge in the valve and the new cartridge that you replaced it with? If no model number do you have any pictures of this valve/trim in question? It could be that you got the wrong replacement cartridge or something is not properly aligned within the valve. Feel free to contact me direct at Hansgrohe. I'd be happy to help. 1-800-334-0455. Press 2 for tech and ask for David. Or email me at david.scarborough@hansgrohe.com
Jan 07, 2013 | Hansgrohe Plumbing
Hansgrohe shower head water leaking out of connector
Is it a Grohe or Hansgrohe shower head? If it is a Hansgrohe shower head the first thing to check is if the self sealing filter gasket is installed at the connection to the shower arm. Hansgrohe shower heads have a black self sealing filter gasket in the head that some people remove assuming it is a flow restriction device. It is only a filter and does not restrict flow unless clogged with debris. Next make sure the flow restriction device below the filter gasket is still installed. On some models removing the flow restrictor will cause water to be expressed from the air injection ports near the pivot ball. Feel free to contact me at Hansgrohe. 1-800-334-0455. Press 2 for Technical and ask for David Scarborough
Aug 20, 2012 | Grohe Home
To adjust hotter
Your shower has been installed for a while and you are noticing the dial must be turned further and further to the hotter settings to get a normal shower - In this case the filter on the hot inlet is getting clogged with debris. Refer to the cleaning instructions in the manual that came with your shower, or contact Hansgrohe USA by calling 800-334-0455 for the documents.
If your installation is brand new or old, debris on the filter is the number one cause of this problem. You can test it by noticing if there is a drop in pressure when you dial to a hot setting as opposed to the cold setting. The drop in pressure indicates dirt on the filter where water has a tougher time getting through.
Filters on a shower valve may seem strange to US consumers. Your old two handle valve system woul run for years without needing servicing. Now you have filters to deal with. These filters, like any filter need to be cleaned periodically and the frequency depends on the quality of your water supply system.
The real benifit, is that the filters protect your smart valve and the shower head from malfunctioning due to debris.
Aug 31, 2011 | Hansgrohe 06642000 Chrome Solaris Single...
The water coming out in the shower from a Hansgrohe ThermoBalance I control is a little too hot on the coolest setting.When the center temperature control is turned to the clockwise stop position which...
pull the handle off and there is a black dial you can pull out and readjust on the shaft of the cartridge that will allow you to have cooler and hotter settings. it's black plastic and has little splines on it . the more you go one way the hotter it gets and the same the other way gets cooler
Jul 17, 2009 | Hansgrohe Home
Adjusting water temp
Behind the handle there is usually a scald gaurd on the newer faucets. You can adjust it from there. If your not sure, follow this link and download the installation instructions to your faucet. There you will find how to adjust it step by step. http://www.hansgrohe-usa.com/us_en
Mar 05, 2009 | Hansgrohe Thermo II Rough-In Valve Chrome...
Insufficient hot water from Gledhill pulsacoil 2000
changing the shower head will not do anything.to do what you want,you would need more BTU's or a bigger unit to supply more water,someone may be hogging the water also.
Feb 25, 2009 | Hansgrohe Axor Hansgrohe Starck Shower...
Hansgrohe 32070821 Talis S Single-Hole High Swing Spout Bath Faucet Brushed Logo
Top Hansgrohe Plumbing Experts
Andrew Bugbee
Ian Lulham
Ian Lulham
Level 1 Expert
ray gallant
Are you a Hansgrohe Plumbing Expert? Answer questions, earn points and help others
