Question about Cfm Klimaire KSWG009H113 Split System Air Conditioner
Ac won,t turn with remote - Cfm Klimaire KSWG009H113 Split System Air Conditioner
Sylvania 32 inch LC320ssx
It seems that the set itself changes inputs. Place it remote control away from the vicinity of the tV. and check. If it does the same, do a hard reset next. To make it a hard reset, unplug the TV from AC mains wall socket, and replug it back after 10 minutes or so. If these do not help you, be sure that the main system control memory IC to it is faulty and should be replaced.
Jun 05, 2013 | Televison & Video
No power
Hello, If the battery won't charge and the laptop won't turn on but the ac adapter works with other laptops, then the problem is the port where you plugin the ac adapter. Some of the laptops has it built in to the motherboard. So you might need to have it repaired by a technician. Or if the laptop is still in warranty, you might need to send it to the manufacturer to have it repaired or replaced. But if the laptop works without the battery, or it will turn on but the battery indicator is not lighting up, you're facing one of these problems. 1. The battery itself is dead. 2. the battery bay is loose 3. the battery itself is loose Hope this helps
http://www.chargerbuy.com/laptop-ac-adapter/toshiba-ac-adapters.html
Nov 10, 2012 | Toshiba Computers & Internet
2008 impala got in this evening and ac won't turn
Someone will need to check the fuse for the blower, then the blower motor and the resistor.
Aug 09, 2012 | Cars & Trucks
Friedrich AC turns on but won't run
Sounds like the inverter pcb, but may have lost gas. Get it checked by a tech
May 14, 2012 | Heating & Cooling
MY HD4208TIII=PDP IS STUCK ON STANDBY MODE. hOW DO I GET IT TO TURN ON?
Hello
Plug it out from AC mains, and let it be in that state overnight, and then check. OK.
Nov 10, 2011 | SVA-USA HD4208TIII-PDP 42 in. EDTV-Ready...
Netbook charging indicator light won't light and battery won't charge. AC adapter works on other computers
Hope this helps...
Sep 15, 2011 | Gateway LT2021u Netbook
Had a great working fan for years. A week ago the remote wouldn't tutrn the fan so I installed new batteries. Still no luck. Manually, it worked. Then I used the remote to change speeds while it was...
If the manually switch works it seams there is nothing wrong with the ac unit itself ...and it may be a poor contact on the remote (for the button that starts the fan ) ..If you think you can manage open the remote ..and clean with alcohol the contacts..both sides..on the main board..and the inside the rubber button contact ..and put it back ..and see if the function is working ...If it is not ..you will need a replacement in order to work ...My advice ..just to see if it is a remote issue ...try to find a somilar one ...(or a universal ) and see if it works before going and buy one ...cause even if it seam to work manually ..this is not excludes a strange malfunction in the infrared board of the ac .
Jul 24, 2011 | Heating & Cooling
My vizio e420vl turned itself off and won't turn back on. When i plug it in the vizio logo lights up amber but it won't do anything else.
There are at least two power supplies in any set with remote capabilities; one is on any time the set is plugged into AC and is supplying that indicator and the receiving circuit of the remote, otherwise it wouldn't turn on under normal conditions. The second power supply produces the needed service voltages used when the set is in use. This second supply is a common failure in many sets and it is generally traceable to poor design and the use of low-quality components of a certain type. Vizio may have a repair or exchange program through their service center. I would guess the cost will be between $50-$150 and you might remove the back panel of the set and look for a smaller board with larger-than-average parts on it and is related to the AC cord coming in. It should be fairly easy to remove and replace as these are often outsourced and just plugged into the rest of the set with dissimilar plugs making it simple to install and reinstall.
May 29, 2011 | Vizio E420VL 42 in. HD-Ready LCD TV
Cfm Klimaire KSWG009H113 Split System Air Conditioner Logo
Top Cfm Heating & Cooling Experts
Dan Webster
Dan Webster
David Payne
David Payne
Donni Steen
Are you a Cfm Heating and Cooling Expert? Answer questions, earn points and help others
