Question about JVC HD-55GC86 OEM TV Lamp
N/P N/S . JVC HD55GC86, red lite comes on & it goes off immediately.
    Top Expert:
  • JVC Master
  • 12,223 Answers
Test this steps and fix it. God bless you
Lamp Problems
Rear-Projection TVs have a lamp, which picks up the picture and projects it on the TV screen. A burned-out or connected lamps are two of the most common problems for Rear-Projection TVs. First, you will want to confirm the bulb is still good. If the bulb is bad then then replace it immediately. Second consult your user manual and verify the lamp and lamp cover are installed properly. Most Rear-Projection TVs have warning light which notify you when there are lamp problems. Again consult the user's manual to see what each light means.
Overheating
Temperature is a common reason why many Rear-projection TVs do not perform well when they get to hot. You may start to see your TV shutting down automatically when it overheats. Here are a couple of things you can do to prevent overheating. First make certain any TV ventilation ports are free and clear of debris and dust. Second make sure the TV has enough room for airflow. Third, the temperature in the room should be around 72 degrees. Due to the high degree of heat generated by a rear-projection TVs, it is not advisable to watch TV on a hot days when you don't run the air condition. This could cause damage to your TV.
Configuration Problems
Improperly configuring TV setting can cause problems. Verify the TV settings are set correctly. First, brightness and contrast should not be set to high or to low because this can cause poor picture images. Second, adjust the color on the TV when the picture displays colors poorly. Third, if you are having sound issues then check to make sure the volume is not muted or turn down all the way.
Reset component settings. Usually, the problems you encounter with a projection TV may be resolved through the resetting to its factory settings. If you experience inaccuracies in the color, reset the television's PerfectTint/PerfectColor capabilities. Simply press the Menu tab and then highlight "Perfect Color" using your right key arrow. After this, press "Enter" and then "Reset" in order to reset to factory settings. If you have audio / video problems (VCR or DVD player), simply press "Menu" and highlight the "Reset" option.
Posted on Jul 31, 2013
JVC HD55GC86 n/p n/s the red lite comes on and it goes off inmediately,some body work on it before me,any suggestions? I would appreciate your help.
test this steps and fix it. God bless you
  • Use your remote control. The first step is to inspect the batteries of the remote control and see if they are functioning. If its power button starts to blink several times once you turned it on, then the batteries need to be replaced. See to it that your remote control is used within about 20 feet from the television. Make sure also that nothing blocks the space between the remote control and the receiver.
  • Check the fan. Once the television is turned off, it is just normal for its fan to become louder. A projection TV actually depends on its lamp, which requires cooling so that it will not prematurely burn out. If the room where your TV is placed is very hot, the fan would also continue to run.
  • Replace projection lamp. To properly do this, make sure that the lamp's bulb has cooled down and the TV is unplugged. Carefully remove the cover of the lamp's compartment using your screwdriver (Phillips-head). Unscrew the sealed part of the lamp that can be found at the television's rear part. Take away the old lamp cartridge and then insert a new one. Seal the lamp with screws, replace its cover and then screw tightly.
    • Reset component settings. Usually, the problems you encounter with a projection TV may be resolved through the resetting to its factory settings. If you experience inaccuracies in the color, reset the television's PerfectTint/PerfectColor capabilities. Simply press the Menu tab and then highlight "Perfect Color" using your right key arrow. After this, press "Enter" and then "Reset" in order to reset to factory settings. If you have audio / video problems (VCR or DVD player), simply press "Menu" and highlight the "Reset" option.
    Reset television controls. In case you cannot fix your TV via its component settings, there are other ways of resetting. Just select "Menu", key in "1, 2, 3", and then press "Enter." In doing this, the TV's manufacturer's specifications will all be restored. If your TV's power system does not function, you should perform a complete system reset. You can do this by clicking on Reset System button located at the TV's control panel. Your television will be turned off and then a green light (LED) will quickly flash for approximately one minute. Once the light has stopped flashing, your TV should immediately turn on.
  • However if the problem persist you have problem with the power supply, see the video attached.
  • God bless you
Jul 30, 2013 | JVC HD-55GC86 OEM TV Lamp
Jvc 61" hdtv shuts itself off
I am amazed how many people post questions with no model number, about a hundred different sixty one inch JVC sets exist, for a answer or help please provide the full model number.
Dec 15, 2012 | JVC Televison & Video
The picture comes for 2 secs on the screen and immediately goes to stand by and red LED Sony bravia standby mode blinks 8 times
the picture comes for 2 secs on the screen and immediately goes to stand by and red LED Sony bravia standby mode blinks 8 times
Nov 19, 2010 | Televison & Video
My screen doesnt come on and one red lite is on the main board. help pls.
HELP I CANT FIGURE OUT HOW 2 CHANGE MY JVC FLAT SCREEN BACK 2 FULL SCREEN MY SON DID IT AND I CANT GET IT BACK
Apr 15, 2010 | Hitachi 46F510 46" Projection HDTV
Green lite comes on for about 2 to 3 seconds then shuts down red lite pulses
If the back was off the board on the left is your Ysus board. It will have a cable plugged into the right side of the board from the signal board. Unplug the the Ysus board. If it stays on without a picture change both Y and Z sustain boards. If this helps let me know.
Oct 15, 2008 | Philips 42FD9932 42 in. Plasma Television
Freezer Temp Alarm
Temp alarm come on, yet temp (fan blowing and cold air) working. Turn the temp control just a notch up and immediately the temp lite goes out. Later it will start up again. It seems the freezer is working fine, just the temp moritoring system is malfuncting.
Sep 06, 2008 | Freezers
No power
why didnt you hook it up to your wiring harness and were is the red wire hooked up the yellow is the memory wire make sure you have a good ground
Feb 09, 2008 | JVC Sirius KD-G300 CD Player
JVC HD-55GC86 OEM TV Lamp Logo
Top JVC Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
