Question about Mitsubishi Televison & Video
No picture only sound and shuts off like its on a timer
    Top Expert:
  • Mitsubishi Master
  • 12,223 Answers
Make this test and fix it. God bless you
Reset component settings. Usually, the problems you encounter with a projection TV may be resolved through the resetting to its factory settings. If you experience inaccuracies in the color, reset the television's PerfectTint/PerfectColor capabilities. Simply press the Menu tab and then highlight "Perfect Color" using your right key arrow. After this, press "Enter" and then "Reset" in order to reset to factory settings. If you have audio / video problems (VCR or DVD player), simply press "Menu" and highlight the "Reset" option.
Posted on Jul 31, 2013
How do i fix a non responsive tv set?
Do the ballast first. That should get the picture back. The main board controls everything else.
Oct 08, 2016 | Televison & Video
Kodak digital frame shuts off after 5 to 15 seconds
This sounds like a setting issue on the photo frame. You should check for a timer for screen time on the frames menu.
Jan 02, 2014 | Photography
My Samsung DLP tv Model HLP6163w/xaa shuts down , the two green and timer red ligts fliker
l need some information here:
Does it work at all or fail upon trying to turn it on?
When was Lamp replaced last and have you inspected the lamp?
Have you or do you hear any high pitched whine or grinding sound or even a loud fan like sound?
Dec 06, 2012 | Samsung Televison & Video
Turn on the TV and only Timer light is on , no sound & picture
after holding down the menu and device the led will blink a two digit error code such as 3 blinks pause then 4 blinks then repeat that sequence a couple of times. Need that blink code to help let you know whats going on. The 34 code means lamp abnormality which translates to the power Pwb capacitors have most likely failed.
Jan 23, 2009 | Mitsubishi WD-52525 52" Rear Projection...
VS-50609 no picture no sound
Seems to be the power button is stuck on the tv itself
Jun 24, 2008 | Mitsubishi VS-50609 50" Rear Projection...
No picture no sound
Probably, the selftest fails while turning on. If this is the case, press input&menu buttons at the same time for 5 seconds, then the green led will start to blink. Let me know how many times the led blinks.
Regards
Mar 01, 2008 | Mitsubishi VS-50609 50" Rear Projection...
Beep
The Polaroid Fun! Digital 320 camera is programmed to shut off automatically after a few minutes if it is not being used. This helps to conserve battery power. When the camera shuts itself off, it will make a continual beeping sound. To use the camera after it has shut off, simply push the shutter button or self-timer button to take a picture. If you are not going to use your camera, turn the power switch to OFF. The camera will also beep in rapid sequence after you press the self-timer button. The camera will continue to beep in faster sequence until a picture is taken (approximately 10 seconds). A final long beep signals that a picture has been taken. NOTE: It is normal for the camera to beep while downloading photos to a computer.
Sep 14, 2005 | Polaroid PhotoMax Fun 320 Digital Camera
Televison & Video Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
