Question about Garden
My DLT 3000 has a Honda 16.5 hp v twin engine, my problem is when engine warms up it starts to spit and pop running on one cylinder and the unburned gas smell is bad. Today I was trying to mow poping along and it quite running. After cooling a bit it started again but popping, I got it to my garage an when I turned off the key it would not shut off, had to bog it down to stop the motor. Any help would be great.
  • 143 Answers
SOURCE: have a 20 HP twin cylinder briggs engine on Yard Machine mower.
Sounds like it might be the air breather filter, remove it and see if it works
Posted on May 16, 2009
  • 109 Answers
SOURCE: have a 20 HP twin cylinder KOHLER engine on CRAFTSMAN mower.
If you are able...have someone do a compression check on the engine. Usually if a mower is loosing power and it is a twin cylinder engine, one of the headgaskets may be blown.
Posted on May 28, 2009
wadembly
  • 448 Answers
SOURCE: bog when trying to mow
you are cutting to much grass & it isn't kicking it out fast enough out of deck which will bog it down it might help if you clean out the bottom of the deck & also dont cut really low if grass is really tall also cutting wet grass will aslo cause the bogging if i can further help e-mail me wade at wadembly@aol.com
Posted on Jun 28, 2009
nova2nv
  • 197 Answers
SOURCE: John Deere,1995 LX188,will just shut off while
Fuel cap vent may be plugged.Little hole in the center of cap.
Posted on Nov 14, 2009
  • 95 Answers
SOURCE: 42' Poulan 20 hp-I was mowing & there was a
Check compression, should be over 90psi to start. And check spark. The loud pop I am going to assume came from the exhaust, which if you lost spark would cause excess gas to ignite. Causes of no spark, bad coil, or defective and or damaged safty swith.
Posted on Mar 14, 2010
22hp briggs and stratton intek v-twin model number 470577-0284-e1
to much fuel either the needle valve is stuck or the float is bad tear apart the carb acid dip and clean take float submerge in gas for 20 min pull out shake next to ear if you hear liquid inside its bad
Jul 04, 2012 | Briggs & Stratton Briggs Stratton Intek V...
What is the engine Number for a Craftsman DLT 3000 Honda 16.5 HP Overhead cam V-twin,,,Need to replace the carb..
Don't know but the carb part number is stamped on the carb. Take a look. Good luck.
Apr 19, 2012 | Garden
I have a Craftsman DLT 3000 Honda 16.5 HP Overhead Cam V-Twin 42" deck.....It will start but will not move...its locked up...I had done all things to make this go...any suggestions
The drive pulleys do have Shear pins where they go on the shafts. These pins do shear off once in a while. With your machine turned off try to turn pulleys by hand . If they turn easily then these could be broken. Just a thought. Try turning your drive wheels by hand with tractor in gear as the drive wheels have safety pins as well. The pins are inside the wheels or pulleys and you have to remove them to insert the pins.
Aug 31, 2011 | Craftsman Garden
I have a craftsman Dlt 3000 riding mower with a 20hp kohler v twin . engine starts and runs for 5 seconds and shuts off
no model # on my DLT3000. Replaced rear fender a few years ago where the model # used to be. I can't get the right parts w/o model #. It was by my dad sometime between '04 and '07. It's red w/42" cut, 20hp koler pro motor.
Sep 18, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
2004 v twin 16 hp 500hours on it runs but spits fuel throught carb when giving gas runs like its missing on one cylinder replaced carb, plugs, fuel filter, it has 120 lbs of compression in each cylinder...
You should take one of the heads off and look at the valves. You may have deposits building up no the valves.
120 pounds compression sounds pretty good for a six year old engine with 500 hours on it. It probably started life at 9 to 1 and now is around 8 to 1.
May 05, 2010 | Briggs & Stratton Briggs Stratton Intek V...
18 Hp V-Twin quits after warm up - will restart but only runs with choke fully engaged
i have the same issue and trying to figure it out so I appreciate being part of this conversation,
May 05, 2010 | Briggs & Stratton Briggs Stratton Vanguard...
27 hp v twin on exmark z mower, sometimes when starting does not have to be warm happens ive noticed when cold in morning, hit the key and spins like no compression will pop out of the exhaust muffler hit...
hi
remove both exhaust mufflers and clean them of carbon deposit.pay attention at the screens from there(if they exists).try again start the engine
regards savumihai71
Dec 14, 2009 | Kohler CH25 PA-CH730-0040 Command Gasoline...
Subaru legacy gt twin hard to start on a warm day
Hi, have the same problem with my 1995 legacy gt twin turbo and the problem lyes with the ecu temp switch, it sound's like the ecu thinks the engine needs more fuel to start and run
Sep 09, 2009 | 1996 Subaru Legacy
Briggs and Stratton 16 hp v twin..replaced con rod and piston
Needle and seat not functioning ... float stuck or trash in needle and seat of carb.
Jul 08, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Garden Logo
113 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
