SOURCE: BMW 528I smokes on start up
telemachas is totally correct with this type of car,also when pulling one of these engines apart i also found a lot of wear on the piston ring groves ,although rings were good the pistons themselves needed renewing .This would cause oil to be pumped into combustion chambers on initial start up.Problem was the cost of parts was more than the car was worth so customer bought another car as this one had been inported from germany and was so rusty as well it was just a scrapper and worst of all it had no air con
SOURCE: 97 bmw 528i
unfortunately, it sounds like you need a new transmission 200k is very good, you may try to find a rebuilt one.
SOURCE: how to unlock right passenger door while door closed 97 bmw 528i
pop the door panel loose near the door lock actuator is at top of door;break the cover off of the door lock actuator.manually turn the actuator worm gear out of double lock with a screwdriver and pull the inside handle; not the easiest thing to do...good luck
SOURCE: I have 97 BMW 528i. Car would not start about a
have your charging system checked to make sure alternator is charging to specs, also make sure no light are left on, (trunk light ,glove box mirror light.it sounds like you may have a draw somewhere, may be alternator or something is on, hope this is helpful.
SOURCE: 97 BMW 528I NEED DRIVE BELT DIAGRAM
My sincere apologies for the delayed response.
I am personally going back to answer your unanswered questions.
I do not know if you still need this information, but I am going ahead and answering it anyway. You may want to Print the Diagrams for future use.
CLICK on the following LINK. It has the Belt Diagrams you will need.
If you would: Before Clicking: Let me know if this helped you, or if you have any additional information or questions. Feel Free to contact me at FixYa.com!
Again my apologies...
http://www.2carpros.com/car_repair_information/year/1997/make/bmw/model/528i/1997_bmw_528i_drive_belt_routing_diagram.htm
