Question about Balboa Instruments Duplex Digital Panel 2 Pump
Heater element has a good test,gfi trips ,instantly but remove one leg and it stays on
  • Balboa Instr... Master
  • 1,631 Answers
Bad element
Posted on May 27, 2014
LG Refrigerator LSC27931ST trips GFI. Unplugged a plug with Black, Brown , Blue and purple wires feeding the water solenoids and defrost heater. Power stayed on. Help
If power is still staying on how can it be tripping the GFI? Dead short somewhere and no power should be coming into the unit since the GFI is the house source.
May 08, 2017 | Cars & Trucks
Emerald Vantage Hot Tub Dead
if your GFI trips soon after the spa goes through the purge cycle then you need a new heater.
Yes the heater can develop a dead short and it causes the GFI to trip when power is sent to the heater.
Rod @ US Parts Center .com
Apr 30, 2013 | Rule 1800 H53SP-24 Swimming Pool Cover...
I have a rheem 40 gal electric water heater. The GFI on the tank keeps popping do you know what could be causing this
10-23-12
Your tank has a GFCI circuit breaker?
Maybe you mean ECO reset button located on upper thermostat?
If GFCI circuit breaker is tripping, turn power off, open covers inspect for burned parts, and test elements. Copy following link for troubleshoot walk-thru:
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#trip-breaker
If ECO reset button is tripping, then replace both thermostats, and test elements.
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
http://waterheatertimer.org/How-to-test-water-heater-element.html
Oct 22, 2012 | Water Heaters
Frigidaire GLRS264ZA refrigerator keeps blowing GFI circuit
The fan and defrost heater are run off the same relay on the board. When on defrost, the fan stops. when the fan starts, the defrost heater is switched off, Sounds like the neutral to the board may be shorting. If you have the ability, try powering the evaporator fan from the compressor relay, disconnecting from the board entirely. To see if this will work, just take a temporary wire to the fan when disconnected and see if it trips while running.
Aug 07, 2012 | Refrigerators
I have a freeflow legend hot tub. the gfi was tripping and i found the heating element was bad. i replaced the heater element now when i power up the tub a circuit breaker trips on the board and nothing...
It sounds like there may be a short in it causing the breaker to trip. I would disconnect the wires from the new element, tape them up and test for the problem again. If it still trips it is not related to the heater element. If it still trips it is not related to the heater element and therefore additional diagnostics need to be used to find out what is is wrong.
Sep 04, 2011 | Pool & Spa
The water heater (Reliance Elec 501) does not turn on, This happened on the same day that our whole apartment lost power due to tripped main switch.n I reset main but water heater does not respond,...
Two-element water heater is 240Volts.
No hot water means: ECO reset button tripped, upper element bad, upper thermostat bad, or 240Volts is not reaching water heater.
Circuit breaker can be delivering power on one leg of the 240V circuit, so water heater appears to have electricity but is only receiving 120V.
Test for 240volts across top two screws on upper thermostat.
Look for loose wires and burned connections.
Push in reset button real hard.
Replace both upper and lower thermostats.
Remove wires and test upper element for continuity.
Open following links for do-it-yourself troubleshoot walk-thru:
http://waterheatertimer.org/B220C.html
http://waterheatertimer.org/How-to-troubleshoot-electric-water-heater.html
http://waterheatertimer.org/Test-electricity-to-water-heater.html
Aug 21, 2011 | RELIANCE ELECTRIC WATER HEATER
Replaced bottom element and both thermosats. the reset button tripped what would cause this to happen
Reset trips when upper thermostat senses high heat event over 150 degrees F.
High heat can be caused by:
1) Element shorted to ground through center of element. Thermostats turn off one leg of 240V circuit. Elements always have 120V available. If element is shorted to ground, it might not trip breaker, and continues to heat using one leg of 240 with circuit completed to ground wire.
Test elements:
http://waterheatertimer.org/How-to-wire-EH40-hot-water-heater-timer.html#120-240
2) Insulation and cover not put back over thermostat. Thermostat exposed to cool air, misreads temperature causing element to continue heating.
3) Thermostat sticking in ON position. I usually replace both thermostats at same time to save another trip.
4) Shorted wire or loose wire at or near upper thermostat. Check that screws are very tight against copper wire.
5) One suspect can be eliminated is 240Volt power to heater.
Your heater circuit is good.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 18, 2011 | Rheem Water Heaters
Colman Spa trips GFI what is most common problem? GFI test good. Pump disconnected still trips, is heater most likely? Can you replace only heater? thanks
this should be simple ...
1.shut off the power
2.disconnect wires to heating element
3. turn power back on and see if it works if so replace heating element 45-95 dollars
if it still trips unplug all the cables from the pumps blower ozonators and see if it runs now,,,, if so plug each cable back (one at a time) until it trips again.if it trips that the problem pump etc.
99 percent of the the time its not the gfi its a device that is wet or shorted out ..Try everything else before replacing the gfi
Dec 31, 2010 | Balboa Instruments BALBOA 30kW HEATER ASSY...
Keeps tripping gfi upon turning switch on. ruled out burner plate after disconnecting wire. element looks to be in one peace and no wires are exposed for dead short. anyone ever encounter same problem?
Hello. I have seen the tank heater not blown, however, it has a high resistance to ground through the water, replace it, and all is fine. You would need a good multimeter to test this problem, there must be a small crack in the sheath of the element, and is able to bleed a little leakage through the water, not enough for a normal outlet, but a gfi, no good.
Hope this helps, and thank you.
Mar 01, 2009 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
Balboa Instruments Duplex Digital Panel 2 Pump Logo
64 people viewed this question
Top Balboa Instruments Garden Experts
Ian Kime
Ian Kime
Paul Stonecypher
Paul Stonecypher
Level 1 Expert
Mister Danger
Are you a Balboa Instruments Garden Expert? Answer questions, earn points and help others
