Question about Sewing Machines
When I sew I get 3 really pretty stitches then the needle thread winds around the bobbin casing and binds up.
  • Sewing Machines Master
  • 7,365 Answers
You might try a new needle,, one that is for the fabric and thread
make sure the bobbin is inserted correctly into the bobbin casing
if you try the suggestions and they don't help,, then the sewing machine needs to be checked..
Posted on Jul 31, 2013
RickE1
  • 202 Answers
SOURCE: upper thread getting tangled in the bobbin
Always remember T-N-T. Thread, Needle, Tension. Assuming its threaded properly, is the needle all the way in and facing the right direction? These symptoms also suggest the bobbin may be in the bobbincase upside down thus turning in the wrong direction. Hope this helps.
Posted on Aug 23, 2007
bargainbox
  • 1388 Answers
SOURCE: Euro-Pro 7133 - Thread is getting stuck underneath
Make sure you clean up all the oil......it is not a universal cure all contrary to opinion....
Now, down to business..........
Ensure the presser foot is firm enough for the fabric you are using and that it will not just pull through easily by hand with the foot and feeddogs together (as the needle ascends), or things will not proceed, and you will be stitching in the same spot.
Generally a setting of 3 seems to work for general purposes, but if you are using very light or very heavy fabric, a sample is always a good idea before you start in earnest....also match the needle to the work for best results.
Ensure that all is clean and free of lint jams....now for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tesion to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your
projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with
a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to
disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
back properly.
FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....no case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistant diameter with good thread, and less compensating to be done by your tension plates and less thread breaks !
If you want any more help with this, just post back here, or, drop a line through the "Contact Us" page at www.bargainbox.com.au
Posted on Feb 25, 2008
  • 4 Answers
SOURCE: singer quantum sewing machine won't pick up bobbin thread
Try changing your needle
Posted on Dec 13, 2008
SOURCE: while sewing the bobbin case moves, wheel locks up, needle locks
Im not sure if this will help but thought I would pass it along. My Pfaff 6122 tells me to check bobbin for thread unrolling clockwise before you place it back in the machine. I had mine turned to un roll counter clockwise, this is wrong, the bobbin will fall out when you pull on the thread while you are holding it in your hand. You may just keep putting it in backwards. Hope this works for you. J.R.
Posted on Feb 05, 2009
bugoy31
  • 1238 Answers
SOURCE: Stitch tension problem - bobbin
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Posted on Jun 17, 2011
Fy5318 breaking thread on multiple layers of material, how to adjust?
either the thread is old, or the tension is to tight.
or there is a bind some where in the line layout.
you mite goto there website and look under FAQ section for other help
or
www.youtube.com/sewing/canvas/material/
www.youtube.com/fy5318/multiple/layers/of/material/setup/
www.ask.com/sewing/multiple/layers/of/material/and/setups/
Sep 17, 2015 | Yamata Fy5318 Mechanical Sewing Machine
Machine is binding up
New needle, right way around, and thread again from scratch, manual in hand. Make sure you're threading with the presser foot up. Raise the bobbin thread. Start each and every seam thus:
1. Place the work under the needle. Use the handwheel or needle up/down function to drop the needle into the fabric.
2. Drop the presser foot.
3. Hold the bobbin and top thread ends together and take about 3 stitches.
4. Drop the thread ends and sew normally. See also: http://www.picturetrail.com/sfx/album/view/22521551 last pair of photos.
Apr 28, 2014 | Euro-Pro 9105 Computerized Sewing Machine
LOWER BOBBIN BINDING UP
Readjust the needle timing and check the thread tensions top and bottom.
Jun 09, 2013 | Kenmore Sewing Machines
Bobbin case jumps out of place when free-motion quilting
Skipped stitches
1. The needle is not inserted correctly
Remove needle & reinsert needle( flat side towards the back of machine)
2. The needle is damaged
replace with new needle
3. The wrong size needle is being used
Choose a needle to suit the thread & fabric
4. The foot not attached correctly
Check & attach correctly
bird nesting problems
Try these suggestions
1. Change needle
2. Rethread the machine--top --make sure to use every thread guide
3. Take the bobbin out --make sure it is inserted correctly into the bobbin
Case, & make sure the bobbin is turned the correct way
4. make sure the thread has not come off the thread take up lever
5. Clean under the needle plate & in the bobbin area for lint or threads
The needle thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
Sep 12, 2012 | Sewing Machines
The thread keeps coming off the needing when i sew
Hello
I would suggest that you revisit the threading up in your manual and double check that the top thread is under tension.
However, if the stitiching on top of the fabric is wonky, this is your bottom tension too loose, and if stitching on the the underside of the fabric is loose, its the top tension causing it.
Quite often bobbin winding can be the cause of bad stitching so pull out the manual and wind a bobbin carefully following the instructions, making sure that the thread is under gentle tension as it winds. What you don't want is for the thread spool to bounce around as it unwinds onto the bobbin as this gives uneven tension of the thread and when you then stitch a seam, the thread relaxes in different amounts causing puckering.
So wind at 3/4 speed, and gently guide the thread onto the bobbin so it fills evenly across the whole core. And ensure there is tension on via a tension guide if your machine has one. If not, then place the curved handle of your scissors onto the top of the thread spool and hold it there as you wind, which holds the spool down and keeps the thread coming off it smoothly.
Always raise the pressure foot when you thread the machine so the top thread goes into tension fully. And new needle for each new sewing job is really important, make sure it is the right size and type of needle for the fabric you are sewing.
Aug 02, 2011 | Brother LS-2125 Mechanical Sewing Machine
Bobbin thread is tangling around bobbin carriage as I sew. So I can only go a few stitches before the machine stops sewing and it's tangled.
Hello
This is Really not that big a problem. Simply pull out the bobbin thread with a long lead, put the assembled bobbin into the sewingmachine and take that long thread and close it between the sliding door and the machine itself to hold it temporarly.
Most sewing machine problems are caused by the usasge of wrong thread type. Make sure you have a thread that is for a sewing machine use, that is, good strong stuff, not hand needle basting thread as that will cause much problems.
Often the bobbin is thought to be the problem, those things are almost never the problem. A source of problems also is the usage of wrong or improperly machined flat on the needle itself. Be sure to buy a quality needle as that flat on there, if machined not deep enough will not allow the bobbin to pick up the thread, wind it around and form the stitch.
Jul 12, 2011 | Singer 4830
Bobbin stich is uneven and a tangled mess
you can dowload a manual from the singer website http://www.singerco.com/accessories/manuals.html
If the bottom stitching is uneven, its mostly the top thread not under tension correctly so check the tension dial and the threading up from the thread spool to the needle.
Also, review how you wind a bobbin, you want a nice smooth wind, not twisting or uneven build across the bobbin. The manual for this machine is pretty brief on this but bobbin winding is crucial to getting a good even flow from the bobbin when stitching seams. You want to wind thread smoothly onto the bobbin, across the full width of it, not just mainly in the middle. Give the thread a nudge with your finger tip to fill top and bottom as it winds.
Also, ensure the thread goes through the bobbin tension disc on top of the machine, and even then, use your scissors handle to put some downward gentle pressure onto the thread spool you are winding off so it doesn't jump or bounce as you wind. Wind the bobbin to 3/4 full, then stop.
And lastly, load the bobbin correctly following the manual directions, make sure it is turning the right way in the bobbin case. Also look at page 16, it shows the "dangle" test where you can check the tension on the bobbin case is right, you should be able to dangle the bobbin by the thread tail and it should "stay" but you should be able to pull on it to release thread too. Adjust the little tension screw in minute increments to get this right. Bobbin case tension springs can fail or break too, so check this out.
Hope this helps you; it is my experience that 90% of machine issues are caused by blunt or wrong sized needles, wrong threading, no tension or incorrect tension or lack of maintenance.
Apr 16, 2011 | White Sewing 1888 Mechanical Sewing...
Why does the shuttle hook grab the spool thread instead of the bobbin thread? It wraps the thread around the bobbin and binds the machine up.
The shuttle hook is suppose to hook the needle (spool) thread and loops it around the bobbin case to form the lock stitch. Is it possible that something was adjusted without proper clearances as to allow the thread looping around the bobbin case to do so without catching up where it should pass through freely?
~<Ray>~
Nov 13, 2010 | Necchi Sewing Machines
I cant remember how to fill the bobbin with thread :(
Insert the empty bobbin case onto the bobbin winder in the sewing machine.
Step 2 Set the spool of thread onto the thread peg. Use the same thread you want to use on your material to obtain the best finished stitch.
Step 3 Follow the arrows or guides to take the thread from the spool to the empty bobbin.
Step 4 Start the thread around the bobbin in a clockwise direction.
Step 5 Push the small lever against the bobbin spool to hold it in place. This disengages the needle so it won't go up and down while winding the bobbin.
Step 6 Press the foot or knee pedal to start the winding process. Stop when you have enough thread on the bobbin for your project.
Step 7
Cut the thread between the thread spool and the bobbin. Insert the bobbin into the bobbin case so you can begin sewing.
Open to clarifications.
rate this.
Jan 10, 2010 | Janome Jem Silver 662 Mechanical Sewing...
Hi, my problem is my bobbin. The tension is fine, it is when I put the bobbin into the bobbin holder. When I thread it through the plate with the top thread, it is so hard to pull out. It seems really...
TENSION: As you change projects and start sewing on different weight materials, you should test stitch on a piece of scrap material of the same weight before beginning the actual project so you can adjust your upper tension to that particular fabric. As an example, if you're changing from a denim type fabric to a silky fabric, you would definitely want to make sure the tension is correct and the stitching looks right before you start to sew the garment.
To determine whether the upper tension is too tight or too loose for the fabric you're wanting to use, try the following test. Take a small scrap of the fabric, fold it, and stitch a line ON THE BIAS of the fabric, using different colors of thread in the bobbin and on top. Grasp the bias line of stitching between the thumb and the index finger. Space the hands about 3 inches apart and pull with an even, quick force until one thread breaks. If the broken thread is the color of the thread in the needle, it means that the upper tension is too tight. If the broken thread is the color of the bobbin thread, the upper tension is too loose. If both threads break together and take more force to break, it means that the tensions are balanced.
BOBBIN: The most probable cause of the lower thread breaking is an improperly wound bobbin. Regardless of where you wind the bobbin, inside the machine, on the top of the handwheel or on the front side near the hand wheel, the basic "bobbin" rules apply.
** Always start with an empty bobbin. Never wind one color over another color.
** Don't wind the bobbin so full that it would be tight and hard to insert into the bobbin case. Most machines have an automatic "shut off" when the bobbin gets full, but if yours does not, be careful not to fill it too full.
** Wind the bobbin evenly across and in level layers.
** Never mix different sizes of thread in the bobbin and on the spool, unless you're doing sewing machine embroidery or some specialty type of sewing. Using different weights of thread on the spool and in the bobbin for general sewing will cause ragged stitches as well as other stitching problems.
NEEDLE: Probably 25% of machine repair jobs I go out on, the only problem was that the needle was put in backwards. I know you're probably saying "I've been sewing most of my life and I know how to put the needle in the machine"; however many times a seamstress will get in a hurry and not give the needle a second thought when putting a new one in the machine. If your machine will not pick up the bottom thread or skips stitches badly, in most cases it's because the needle is in wrong.
Each sewing machine requires that the "flat" side of the needle be put in a specific way - facing the front, the back, etc., depending on your particular make and model. If you have a sewing machine that takes a needle that doesn't have a flat side, you'll notice that each needle has a groove in it where the thread lays as it penetrates the fabric. Depending on whether your machine shuttle system faces to the front or to the left, the groove of the needle will also face front or left.
MACHINE THREADING: An additional area to check for stitching problems is whether the sewing machine is threaded properly. Each machine has a certain sequence for threading, and it only takes one missed step in the sequence to cause your machine to skip stitches. If you're in doubt, take the top thread completely out and start all over again.
Jul 05, 2009 | Sewing Machines
Sewing Machines Logo
21 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
