Question about Kenmore Refrigerators
Door seals need to be replaced... I am looking to see how to do this myself. 795.78553 800 model number.
    Sergeant:
  • 304 Answers
Go to repairclinic.com type in your model number then look up what gasket you need. These are push in gaskets so you just pull out the old and push in the new one. Make sure you heat stretch the new ones first by putting them in the clothes dryer for no longer than 1.5 minutes on medium heat. This will help them seal better.
Posted on Jul 30, 2013
woodchuck789
  • 4059 Answers
SOURCE: cracked leaking door seal
Part 201 on this diagram and you can look at the freezer door diagram for it. http://www.appliancepartspros.com/partsearch/model.aspx?model_id=18149&diagram_id=782438#d782438
Posted on May 29, 2010
mreid542
  • 166 Answers
SOURCE: Can I replace the freezer door seal on a kitchen aid myself?
some door gaskets snap into a track and others are held on to by screws in a metal frame. you can pull the back of the gasket apart to see which you have.
are you sure that the gasket is bad? you can do the dollar bill test by placing a dollar bill between the gasket and door frame and shutting the door. if the dollar bill fits snugly and is not loose the gasket is good. However you may be able to look at your gasket and see that it is torn or warped and not sealing good.
replacing the door gasket can be a little tricky but with a little patience and some very hot water to soak the new gasket in to make it easier to work with, you should be ok.
keep the bottom of your refrigerator and freezer frames clean (this is where everything spills and gets sticky) to keep the gasket from sticking to the frame and tearing up over time.
Posted on Jul 24, 2010
SOURCE: Model No. 251RFD I need the door seals for this
Dear strusler,
Parts can be ordered through our Regional Factory Certified Parts Distributors. They will need your model and serial number in order to properly assist you. You will find their contact information by following the link to our Locator. Select 'Service, Repair and Parts', enter your zip/postal code and you will receive a listing for the Factory Certified Parts Distributor for your area.
http://www.subzero.com/locator/locator.aspx
If you have any further questions or concerns regarding this or any other issue, please contact us directly. You can contact us via phone Mon-Fri. 8:00-5:00 CST at 800-222-7820. We can be reached via email at CustomerService@SubZero.com.
Thanks!
Customer Care Team
Sub-Zero/Wolf Appliances
Posted on Feb 23, 2011
oldTech2332
  • 2341 Answers
SOURCE: I need to replace the door seal. I cannot find a
The model number can be in 4 places need it to order correct part,it could be on; ceiling of fresh food section,left side wall of fresh food section,under grill below doors,under crisper drawer
Posted on Aug 02, 2011
  • 963 Answers
SOURCE: What is the part number for the door seals on a coldtech model S3BRR-18-S
Your best bet is to contact them by phone or email, from this website:
http://www.coldtechcommercial.com/customer-care-page.html
There is also this statement posted on their Frequently Asked Questions page:
Our ColdTech Commercial products have the logo that is on the top, left-hand side of this web page. If it does not match then it is not one of our products. We can't speak for other companies.
There is another discontinued product-line called ColdTech that we have no affiliation with - confusing, I know. Our commercial refrigeration line launched Aug 1, 2011 and our thirteen digit serial numbers resemble this: 0111053500001.
Posted on Feb 11, 2012
Leaking from motor
Water Inlet Valve
If the dishwasher is leaking water the water inlet valve might be defective. If the water inlet valve sticks open, it will allow water to fill the dishwasher continuously. Some customers report that they see clean water filling the bottom of the dishwasher after it's been sitting all night or for a couple of days. If this happens, turn off the water that is supplying the dishwasher. This is normally a valve under the kitchen sink. Then, replace the water inlet valve, it cannot be repaired. The water valve needs at least 20 lbs pressure to shut off properly. If your water pressure is to low replacing the valve may not solve the problem.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Center Wash Arm Assembly
If the dishwasher is leaking water, the center wash arm assembly might be cracked or split. This can allow a jet of water to spray toward the door seal, causing a leak. If a crack or split in the center wash arm assembly is found, replace it. There isn't any glue that will hold the part together inside the dishwasher.
Lower Wash Arm Assembly
If the dishwasher is leaking water the lower wash arm assembly might be defective. If the lower wash arm has a crack or split on the end, it can force water to spray directly toward the lower part of the dishwasher door. Then, the water can be forced under the door and onto the floor. Check the lower wash arm for any cracks or splits and replace it if necessary. Also make sure the screws are tight in the wash arm support. If the screws are loose, water can spray out the side of the pump and cause a leak.
Upper Wash Arm Assembly
If the upper wash arm assembly is broken or cracked it can cause water to spray very forcefully toward the seams of the door, causing a leak.
Door Seal
Every dishwasher door has a door seal. If the dishwasher is leaking water, it might be that the door seal is defective or worn out. Try closing the dishwasher door on a dollar bill and see if the door seal is making good contact all the way around the door. If not, replace the door seal. If the door seal is good or has been replaced and there is still a leak check the door hinges. If the hinges are bent the door will not close properly and the hinges will need to be replaced.
Dishwasher Door Gasket
God bless youc9c8c0e9-8a93-431d-b16a-9b8d97f35d28.gif14b36f01-1d58-4f2a-8f54-fc14feec17e3.jpg
May 23, 2013 | KitchenAid Dishwashers
Leaking from top
follow the next step, for test. God bless you
Water Inlet Valve
Door Seal
Apr 05, 2013 | Whirlpool Dishwashers
How to replace the door rubber seal and part number
Here is the door seal to order.
Below is a video to show you how to replace the boot. The model may be a little different but the process is the same.
Feb 17, 2013 | Samsung SM-WF338AAW - SERVICE MANUAL
Can i replace the door seal by myself on upright Amana freezer?
Hello.
Yes the door gasket is replacable. If the model number for your freezer is the one listed in your question (AFU2076AW) the part number for the door gasket is 4357120 it could be purchased at your local appliance parts tore or online at;
apdepot.com
searspartsdirect.com
partselect.com
apwagner.com
repairclinic.com
GENE
Sep 14, 2011 | Amana 19.6 cu. ft. / 555 liter Upright...
How to replace door seal part number 1603291 on hotpoint washer
Hi -Can I myself replace and repair a seal on a bosch front loader? Thanks for your help and your time!
Thank you,
Linda
Nov 17, 2009 | Washing Machines
Kenmore Model 587.1514* and cannot find the remaining portion of the Model number
Those are all the numbers you need - the remaining numbers are just the color ie: 587.1514 is the model 587.15142400 means its white
Jul 29, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Sub-zero door seal
THE TRUE IS .. replace a door seal is a little pain to replace. YOU HAVE TO INSTALL RIGHT. ( some model using silicon. if you are patient. and able to remove aroun 30 screws. do it. if not. better call a tech........good luck.............................. LEAVE A COMMENT IF IT WAS GOOD FOR YOU
Dec 06, 2007 | Sub-Zero 642
Candy washing machine
door seal replacement can be done with a little skill and a bit of common sense, 1st thing to do is buy a replacement quoting make model etc, then you will see how the seal is shaped to fit, unplug the machine and work from the front, open the door and remove the thin wire clamp from round the edge of the door seal, remove from the lip of the cabinet and that will enable you to see inside the casing, there is a wire spring or an adjuster on the drum end of the door seal, remove that and the seal will pull off with a gentle pull, refit as removed, take note how you removed wire etc, check for leaks and state of fit before leaving machine unattended and running difficult job hard to describe in writing, but not too hard with a little thought
Sep 17, 2007 | Washing Machines
Refrigerators Logo
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
