Question about Measuring Tools & Sensors
Kobalt manual for 4 cubic foot concrete mixer
3 Suggested Answers
  • 251 Answers
SOURCE: workshop manual for belle minimix 150
http://www.islandhirecentre.co.uk/docs/spares/B10201.pdf
to get any engine drawings i would need the engine model from the side casing
hope this helps
Posted on Oct 23, 2009
joecoolvette
  • 5660 Answers
SOURCE: concrete hollow block pan mixer manual
Looking to cut costs? Can't afford one? Unattainable in your area?
Understandable.
Want to try your luck at making a homemade Pan Mixer? Buy the materials yourself, and fabricate for relatively cheap?
Suggest using a variation of this,
http://www.motherearthnews.com/Do-It-Yourself/1980-09-01/Build-A-Low-Budget-Cement-Mixer.aspx
Build sturdy uprights, attach them to a frame, then attach the uprights to the tub.
Make the chute tiltable when you pull a release lever, so that you can ain it toward the individual blocks, and also have a sliding gate you can shut off for the chute.
Pan Mixer professionally made;
(Fourth item down)
Posted on Nov 08, 2009
How much premixed cement needed to fill 1 cubic foot
1 cubic feet or 0.037 cubic yards or 0.0283 cubic meters.
If pre-mixed concrete*, it is 133 lbs or 60.315 kgs.
If 60 lbs per bag, it is 2.217 bags.
If 80 lbs per bag, it is 1.663 bags
You can calculate it through- Concrete Calculator
Thanks
Visit- Best Astrologer in India Indian Astrology Famous Astrologer
Oct 16, 2016 | Office Equipment & Supplies
HOW MANY BAGS OF CONCRETE THAT ARE 2/3 OF A CUBIC FOOT TO FILL A HOLE 63X59X4
Lets assume that our concrete bag has a volume of 'x' and is 2/3rd the size of a 1 foot cube.
that means its volume is 2/3 cubic foots.
thus we conclude x = 2/3 CF (cubic foots)
Lets assume the hole has a volume of y and is equal to
63x59x4 CF
thus y = 63x59x4 CF
Divide to get the result
y/x = (63x59x4)/(2/3)
there is a rule in mathematics that makes the above convert into
y/x = (63x59x4x3)/2
yes the lowermost 3 jumps up only because it was coupled with the 2 below the divide sign
see the brackets
only in such special conditions the last digit jumps up.
Now a simple calculator will find our answer
Assume to calculate separately (seems easy to me this way)
63x59x4x3 = 44604
y/x = 44604/2
thus y/x = 22302 units.
That means to fill up a hole of dimensions 63x59x4 CF it will take upto 22,302 concrete bags .
Sep 28, 2016 | Office Equipment & Supplies
How many cubic yards for a 20x12 slan 4 inches thick
Assuming that 20x12 means 20 feet by 12 feet, then you take the three values in feet - 20, 12, and .333 (4 inches is 1/3 foot).
Multiply these three numbers to get the cubic feet:
12 x 20 = 240
240 x .333 = 79.92
Now that you have 79.92 cubic feet, to get cubic yards you divide by 9 since there are 9 cubic feet per cubic yard.
79.92 cu. ft. divided by 9 = 8.88 cubic yards (round up to 9).
Jul 27, 2016 | Building Materials
How many cubic yards is 3600 square feet in 6 inches?
  1. Calculate
    • Calculate your area (see below)
    • Calculate your volume; Multiply area times the depth, this will be volume in cubic feet
    • Calculate your cubic yards; Divide cubic feet by 27 to convert to cubic yards and this is your answer.
    • Where (ft2) = square foot, (ft3) = cubic foot, (yd3) = cubic yard
  2. Google
  3. or i'll do it 66 and 2/3 cu Yds
Mar 23, 2015 | Building Materials
Convert 30pounds per sq.foot to pounds per cubic foot(concrete=150#/cubic foot at 1in. thick conc. slab).
These are not the same, so cannot be directly converted.
Pounds per sq ft is a measure of pressure, while lbs / cu ft is a measure of density, weight per unit volume.
I think maybe what you are doing here is converting the weight of concrete in a 1" slab, where a sq ft would contain
1 x 1 x 1/12 = .0833 cu ft
The figure of 150 lb/ cu ft is correct for the average density of concrete, so the above slab would have
1/12 x 150 = 12.5 lbs/sq ft at 1" thickness
BTW that is a thin slab of concrete, insufficient even for a light-duty pathway. If you are referring to a screed for tiling or similar, that is cement.
Mar 01, 2015 | Office Equipment & Supplies
How to calculate cubic feet ?
Calculating the cubic feet of a space requires multiplying the area of the bottom times the average height. You get the bottom area by multiplying the length times the width. Remember, to get cubic feet, you need all your measurements in feet to start with.
Here is your formula:
VOLUME (in cubic feet) = Length (in feet) X Width (in feet) X Height (in feet)
If it's a rectangular room you're working with, it is all straightforward. If there are irregular walls, it may be necessary to divide up the room into rectangular sections and then add together their individual volumes. If the ceiling is sloped, you need to use the height that has the same ceiling area above it as below it. Good luck! Truly.
Jul 25, 2014 | Building Materials
1 yard cement is how many cubic feet
kakima is 100% correct, but to add to it so you understand how he got that 27 cubic feet... you can picture a cube.
A cubic yard is 3 foot tall x 3 foot wide x 3 foot high.
(A cubic foot is 1 foot tall x 1 foot wide x 1 foot high).
So 3 x 3 x 3 = 27.
Jul 18, 2014 | Masonry Tools
Cubic feet calculator
just under 18 cubic feet.
at 4 inches thick there will be 3 square feet to equal 1 cubic foot. there's .6 cubic feet in an 80 lb sac. I'd get 30 bags and be careful not to go over 4 inches deep to often.
Dec 14, 2013 | Office Equipment & Supplies
Measuring Tools & Sensors Logo
352 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
