Question about Toaster Ovens
The wire and cap wont stay on together. how do i rewire the wire correctly
  • 16,974 Answers
Tell us more about the problem
Posted on Aug 02, 2013
Why wont myoven stay off? I have to unplug it everytime because it turns itself back on and goes to the stay on setting?
The problem should be a melted wire of a melted control., either of which allows the electricity to flow constantly.
To prevent a fire, please stop using this appliance.
Mar 05, 2018 | Toaster Ovens
Toaster wont stay down
Just fixed my Breville CT20. Cleaned the contacts, there were no impeding crumbs so I tested again and still wouldn't stay locked. I finally replaced the 470uf 16v capacitor on the control board just below the electromagnet and wow, works like a brand new toaster! I got lucky, saving bits and pieces of old circuits sometimes pays off.
Jan 12, 2015 | Breville Vtt002 Polished Stainless Steel 4...
Hi i have a four slice toaster it is only 13 months old but one side does not work please can you help as i think this should last a lot longer as it was not cheap i dont think it is fit for purpose i
Hi, Try to set the toaster to a darker setting. this will make the toast stay down longer. But keep an eye on it as it can burn. As for the other side not working. Unplug it and look carefully at the heat coils.
If there is a break in the wire you will have to take it to be repaired. Good luck.
Jan 12, 2015 | DeLonghi Toaster Ovens
The door spring came off of hamilton beach 31100
The door of the Hamilton Beach Model 03008 or similar toaster oven does not stay closed when the door return spring or the hook it connects to breaks. The repair is very simple and takes just a few minutes!
The door spring is about 1 inch long and connects to a small clip on the inside of the left side panel of the unit. To see the small clip and the door spring, you simply remove the left side panel of the toaster oven which is done by removing just one screw.
The mounting clip on the side panel for the door return spring is located about half way up the side panel near its front edge.
The other end of the spring (its bottom end) connects to a metal hook. If the spring is not connected on its bottom end then the wire hook is broken. This is a simple repair that only requires a few inches of metal wire.
The other end of the metal hook (its bottom end) is connected to the bottom of the door hinge where it inserts into a small hole in the left side mounting hinge of the door.
When the steel hook breaks on either end then the spring cannot function, so the door does not stay closed.
To fix this problem, you simply get a piece of steel wire that is about 1/16 inch thick and a few inches long.
Bend the wire to make a hook at one end that the spring will connect to.
Then insert the other end of the wire into the small hole on the left side mounting hinge of the door. Then bend the wire on the inside of the hole to make a U or hook so the wire stays mounted in the hole of the door hinge.
Then adjust the position of the bend on the other end of the metal wire so the spring will have good tension when it is attached to the hook and to the clip on the side panel.
To do this you make the U shaped bend on this end of the wire to be about 1/2 inch from the end of the open end of the spring when the top end of the spring is attached to the mounting clip on the side panel.
To attach the spring to the wire hook, first remove the spring from the mounting clip. Then hook the spring onto the hook (bend) you made at the top end of the wire, then just stretch the spring to connect it to the mounting clip. The door will now stay closed.
Nov 10, 2013 | Hamilton Beach 31197 120 Watts Toaster...
My toaster oven stopped heating all together.
your heating element has gone bad or there is some bad wiring in the oven itself
to check open up the toaster oven and look at the wires coming from the heating elements inside to the timer on the front panel if there is no bad wiring then the heating elements are bad and the toaster oven needs to be replaced
Jan 02, 2011 | DeLonghi XR640 Retro 1500 Watts Toaster...
The broil element and bake element both come on set for Bake.
You are correct in your diagnosis. The selection switch has 2 sets of contacts that should only make one when on bake. The contacts internal to that fuse are most likely fused together, the other thing that could be going on is a short circuit in the wires to the selection switch causing the same problem. Typically a repair unless under warranty would be costly unless you are up for the challenge of replacing the switch and checking the wiring yourself.
Apr 20, 2010 | DeLonghi XU1837 Trilogy Bake 'N' Broil...
TR0651WC Black & Decker Toater Oven. Stopped working all together
Trace the electrical circuit with a multi-meter, while unplugged.
May 08, 2017 | Euro-Pro EP278 Bravetti Platinum 1500...
Toaster switch- Black and decker- TRO360TY6
I don't know if you can fix it but if you are good at basic diagnosis you can take off the right side and see if the toast latch is broken or perhaps out of place. This type of unit is not so easy to take apart and put back together. The parts fit is a bit strange.
May 14, 2008 | Black & Decker TRO360 Toast-R-Oven Toaster...
Toaster oven
THERE IS A SAFETY MECHANISM ATTACHED TO THE DOOR THAT TURNS OFF THE OVEN WHEN YOU OPEN THE DOOR. INSIDE, BEHIND THE KNOBS THERE IS A SPRING THAT ATTACHES TO A WIRE THAT IS CONNECTED TO THE DOOR. WHEN THE DOOR OPENS THE WIRE RELEASES THE SAFETY MECHANISM AND THE OVEN SHUTS OFF. WHEN CLOSED THE WIRE PUSHES AGAINST THE MECHANISM AND THE OVEN WORKS. I WAS ABLE TO FIGURE OUT HOW TO RECONNECT THIS FEATURE SO THAT THE OVEN WOULD WORK.
Feb 24, 2008 | Black & Decker TRO210 Toaster Oven with...
Blown fuse
You need to go to your local Harbor Freight Tools and pick up a security tool kit for $9.99 so you'll get the bits required to remove the special screws. You need to remove all the screws around the outer edge of rear and then pull the white rubber plugs out of feet and remove the screws from feet. Then the entire cover lifts off of unit. That exposes where the power cord enters the back of unit. You'll see a smaller black wire leaving that area going over to the timer knob. Before the wire gets to the timer knob, there is a sleve covering the wire. If you'll cut the zip tie holding all the wires together, you can slide the sleve (mine is red) backwards toward where the power wire comes into unit. That will expose the inline fuse that is blown. You will need to call Delonghi to order the wire. It is pressure fitted on. You should be able to pull the connectors lose by hand on each end. Simple fix!!
Dec 28, 2007 | DeLonghi XU1837 Trilogy Bake 'N' Broil...
Toaster Ovens Logo
Top Toaster Ovens Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Toaster Oven Expert? Answer questions, earn points and help others
