Question about Saws
Kobalt wet saw
Need a drain plug for the water tray
2 Suggested Answers
  • 54 Answers
SOURCE: Wet tile saw just stopped cutting; I only cleaned
How thick is the diamond bearing segment running around the rim of the blade? There needs to be at least an eighth inch. The last part contains no diamonds. If their is sufficient diamond left the material you were cutting may not have been abrasive enough to expose new sharp diamods. You can cut a small piece of asphalt. This will wear the matrix down so new diamonds are exposed.
Posted on Nov 19, 2009
Do you have a Kobalt 10 inch tile saw sliding tray?
Fixya does not sell Kobalt 10-inch tile saw sliding trays.
Dec 25, 2017 | Saws
Need a blade guard for kobalt miter saw 0358938
Fixya does not sell blade guards for Kobalt miter saws.
Oct 11, 2017 | Blade Saws
I need a arbor nut and washer for a kobalt 10 inch table saw model kt 1015
First try Lowe's, the only Kobalt tool retailer. If they can't help you, the Kobalt customer service number is (888) 356-2258. I looked for Kobalt power tool parts onlline without success. That may suggest that their one-and-only retailer is the only source, or it may mean you should look for a replacement saw, basing your choice on likely future parts availability.
Oct 04, 2017 | Saws
Kobalt 10 saw blows dust everywhere ,even with a 2 shop vac connected to the dust chute .
It is possible that the dust chute on the Kobalt saw is plugged, not allowing the vacuum to pick up the dust. Run a rod through the dust tube and see if that clears it.
Jun 19, 2015 | Shop Vac Vacuums
How to correct a saw dust problem on a kobalt 10 .dust does not go into chot a 2 shop vac hel
The hole behind the saw blade can become blocked solid with sawdust ( especially if the timber is green or wet). clean out the vacuum hose back to the collector.
Where do you put the water?
Most wet saws have a water tray below the table area. The blade moves thru this tray and gets cooled and lubricated by the water
Mar 06, 2015 | Qep 60087 Table Tile Saw 7" Wet
Blade won't spin properly on kobalt wet saw
Is the blade for that saw? is it set right?
Sep 29, 2013 | Air Tools & Compressors
I have a wts2000l and i have noticed that it is burning through blades. The water is pumping through but isn't hitting the blade at all. The water is spraying in opposite directions, I can't seem...
you just have to lift the blade guard and tweek the direction of the outlet, point them so they're spraying towards the blade. Not right at the blade but just so they're getting plenty of water spraying onto the tile. Don't put a bucket and catch the water "over flowing" from the tray, just drain the pan and put the bucket under the drain hole to catch the water. A lot less messier that way.
Aug 05, 2011 | Ridgid Wts2000l 10" Wet Tile/stone Saw...
Cannot keep water on the blade of my 10" Rigid wet
if waters not getting to the blade you will see the powder of what ever your cutting coming off the back of machine,i like to put my pump in a bucket of water under the drain plug instead of puting the pump in the water tray,you can run bigger tubing up to the blade and reduce it down and it will give you better presure,good luck
Dec 31, 2010 | Ridgid 10"Wet Tile Saw with Laser and...
Saws Logo
69 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
