Question about Brother P-Touch 1180 Label Printer
How do you print vertically on p-touch pt-d200
The font won't change. It always prints in the same font no matter what I pick...
Try to reset it. Read the full manual, which you can Google for it online, put in make, model and manual and you should get the .pdf file to save to your computer.
Mar 02, 2015 | Brother P-Touch PT-D200 Label Printer
Print vertical on the p touch 1830
You need to go to printer setting and go to print type. now you will able to see your paper printing type. you need to click on that and select A4 paper size.
Feb 21, 2015 | Brother P-Touch PT-1830 Label Printer
PT-2400 HOW DO YOU VERTICAL PRINT
Most folks forget that this printer does Landscape not portrait. Unfortunately, Widows defaults to Portrait. Go to your properties button when you hit the file-print command and change that in the paper options tab.
Oct 22, 2013 | Brother P-Touch 2400 Thermal Label Printer
P touch d200 defaults to mirror printing
This worked for me:
The machine turns on Mirror mode by itself, how can I correct this?
1. Turn Off the machine.
2. Open the tape compartment cover and remove the tape cassette from the machine.
3. Re-install the tape cassette back into the tape compartment. Push down on top of the cassette; ensure that it is seated firmly in the tape compartment and close the cover completely.
4. Reset the machine.
Note: All text, settings and stored files will be cleared.
a. Hold down the Shift and R keys.
b. While holding down the Shift and R keys, press the On/Off key once.
c. Release the Shift and R keys.
5. Try printing a label.
6. If the problem appears, try another Brother TZe tape cassette.
If the problem persists, your machine may require service.
The machine has a one year limited exchange warranty. If the machine is in warranty, call Brother Customer Service at 1-877-Brother (1-877-276-8437) for warranty options.
If the machine is out of warranty, contact a Brother Authorized Service Center for repair by clicking on the link below:
http://www.brother-usa.com/service/default.aspx
Feb 03, 2013 | Brother P-Touch PT-D200 Label Printer
Print vertically
Try F+3, select style and scroll through the selections until you see vertical. Select it and you're on your way. If you don't have the instru, go here:
http://www.brother-usa.com/Manuals/Default.aspx?WT.cg_n=Support&WT.cg_s=Manuals, and choose the English manual.
Apr 20, 2009 | Brother PT-1000 Thermal Label Printer
Nikon D200
My first question would be what lens are you using - some lenses have auto stability features - please post lens make, type, model number and when you purchased it.
Dec 22, 2007 | Nikon D200 Digital Camera with 18-200mm...
Brother P-Touch 1180 Label Printer Logo
451 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
