Question about Husqvarna Garden
Have 21hp Husqvarna mower leaks oil at filter .change filter still leaks when running .
  • Husqvarna Master
  • 1,807 Answers
Have you tightened it up enough, also is there a rubber seal between the housing and the filter and is this correctly in place.?
Posted on Jul 30, 2013
  • 41 Answers
SOURCE: Briggs & Stratton 4.5 hp running rough...too much fuel
Hi did you squeze excess oil from filter so it can **** air in??
Posted on Aug 04, 2009
cjrepairs
  • 60 Answers
SOURCE: 6522sh husqvarna mower leaks oil
no solution other than have the seal replaced its cheap part but the labour content makes it cost.however the cost of a damaged engine & shaft make the repair worthwhile. overfilling of oil can cause this just check if the oil sump breather is clear as this can cause excess pressure on the seal.
Posted on Aug 16, 2009
huffman49
  • 235 Answers
SOURCE: My mower will start but not run
if the filter is a sponge filter then it's suppose to have oil in it(helps trap dirt) and if your getting gas out of the muffler then the engine is flooding when you try to start it..good luck
Posted on Apr 14, 2010
SOURCE: lawn mower wont start. changed air filter, spark
Does it turn over? If it does, what happens? Does it sound normal when its cranking? I need more information to help. Is it a push mower or riding mower? Does it start by key or pull start?
Posted on May 01, 2010
SOURCE: husqvarna 7021 kohler 173cc looks like its leaking
The carburetor probably needs cleaning -- the float is sticking.
Charlie
Posted on Jan 07, 2011
I am losing power going up hills and smoke comes out in front of mower
check for excessive oil in the sump (carby needle and seat allowing fuel to drain into the sump past the rings when standing for a period of time )
what you describe is indicative of excess oil and the oil ring cannot handle the oil control
this in turn affects the air/fuel mixture and makes it hard for the engine to run
Jan 09, 2016 | Husqvarna YTH21K46 46" 21HP Kohler Lawn...
Engine cranks but does not start on 21 hp briggs and straton
May have oil in the carb. If it smoked its burning oil due to having to much in it.
Jul 02, 2013 | Husqvarna YTH21K46 (46") 21HP Lawn Tractor...
Leaking oil in front of my engine
Check your valve cover. Tighten the bolts a little, may fix the problem.
May 12, 2012 | Husqvarna Garden
I have oil leaking out my 491056 oil filter on my mtd lawn mower. I have not changed it in about 8 years could that be why it is leaking? or ? It is pretty much pouring out now. Was a small leak now a...
Change you oil and while you are at it change the filter. Do not run until you have completed. You risk engine damage by loosing too much oil while running it.
Jul 24, 2011 | Briggs & Stratton 491056 492932 Briggs ...
Carb blows black smoke and runs bad but run good with no air filter or with a new filter
The old filter must be clogged. So if it runs ok with a new filter do you still have a problem?
Apr 16, 2011 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
Garden Logo
42 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
