Question about Sony CFD G505 Boombox
Cd playback starting to skip then stops - Sony CFD G505 Boombox
I lost may xbox playback kit remote control what can i use as an alternative
Hey,
You can use your Xbox controller as a remote control to watch media.
Here are the actions for each button:
To... Press... Play or pause Note If the DVD is bookmarked, it will start playing automatically where it was stopped the last time you viewed it. START Skip back one chapter LB
or
A, then select skip back Skip forward one chapter RB
or
A, then select skip forward Fast forward RT Rewind LT Page up through a list of items. RT Page down through a list of items. LT Open the on-screen display for more advanced playback controls. X, Y
Source: http://support.xbox.com/en-us/pages/xbox-360/how-to/watch-dvds-movies.aspx
May 02, 2011 | Microsoft Xbox Console
My Sony CDP-XA7ES CD Player can play only up to 6 to 9 tracks depending on the length of the tracks n then stops.
replace the spindle motor. the motor's speed varies while playing cds and a worn motor will not keep to the correct speed for playback of certain tracks on various points of the disc and will cause skipping and even stop altogether.
hope this helps.
Apr 02, 2010 | Sony CDP-XA7ES CD Player
Cd player malfunctioning after cd lens cleansing
Ive replaced sooo many Bose systems for that very same reason. Id replace radio. Problem with Bose radios sometimes have no amp inside radio and if you replace the radio, you have to replace the entire system, very expensive, depends on year of vehicle too.
May 14, 2009 | Car Audio & Video
Durabrand model cd-968 mp3 anti-skip cd player Does skip...
I understand what you are saying. The Durabrand is very cheaply made and the ani-skip actually does not work near as long as stated by company. I would buy more expensive player or a different brand.
Look for 60 Second Anti-Skip if you want a good one.
May 13, 2009 | Durabrand CD-968 Personal CD Player
I HAVE A PROBLEM WITH MACHINE SKIPS ON PLAYBACK
I think the laser is mis-aligned and its one for a competant technician. Hope this helps.
Sep 25, 2008 | Sony RCD-W500C 5-Disc CD Recorder
CDs skip on normal playback
Hi, the most probable cause for this is the lasers light output falling off as it ages. Sometimes you can temporarly improve this by cleaning the laser lens with some alcohol. However the only real solution is to replace the laser.
If you are confident taking stuff apart you may be able to do this yourself. Almost all modern laser assemblies come fully calibrated so all you need to do is take the old on out and fit the new one.
The lasers often have the part number on the side of them. You can get spares from CPC in the UK. But a search for the part number should find you a spares supplier wherever you are.
Regards, Andrew
Sep 13, 2008 | Denon DCM-370 5-Disc CD Changer
How do i know if my car cd player is dirty
When cd starts skipping in playback, a little jump of car disturb track sound, such symptoms shows car cd player has dirt inside and specially on lens.
want to know more, please let me know.
Sep 10, 2008 | Audio Players & Recorders
CD playback skips back and forth
Did it just stop working one day, or did you move it, use it differently, etc?
Sounds like your reader/tray might be bad, but could also be a faulty circuit which may have shorted out. If your handy with a multimeter, you might be able to trouble shoot it. Make sure there is nothing lodge in there, and when you opened it up, did you see any broken pieces from the tray? Sometimes the teeth on the gears crack and break off, so check that also. You can't miss the gears, this is what allows the CD to move in/out of the unit.
- TWEAK A/V LAB
Nov 22, 2007 | Pioneer CDJ-100 Turntable
MP3 files start skipping/popping after few minutes of playback
Sony say in the manual that if you record high bit-rate mp3's the sound may be intermittent. I feel this is due to the decoder having to move ALOT of bits around to play, try some makeing a disk with mixed rate mp3's on. e.g.) some 64Kbps, some 128, some 192, and some as high as you can get and see if there is any differ Luck
Mar 02, 2007 | Sony CDX-MP40 CD Player
Sony CFD G505 Boombox Logo
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
