Question about Miele Dryers
Condensor dryer smells like burning
Burning smell like gunpowder
    Top Expert:
  • Miele Master
  • 12,223 Answers
Make this test and fix it. God bless you
Usually when an electric dryer overheats it's because of a defective cycling thermostat or a clogged vent system. Clean any lint from the internal and external ducts and/or replace the cycling thermostat.
Cycling thermostat
Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork . It will have 4 wires connected to it. 2 wires opposite each other will be closer than the other 2. The ones that are closer together should have continuity if it doesn't replace thermostat
Posted on Jul 31, 2013
  • 1073 Answers
SOURCE: dryer smelled of burning plastic, smoked stopped turning on
check the power cord itself, if you see on the back side of the cord a burnt or blackened spot then the cord is the issue
Posted on Apr 12, 2008
  • 958 Answers
SOURCE: Duet Dryer
burning smell would be coming on the coil of an electric dryer. the coils could have catch some lint that produces that distict burning smell..
i hope i was able to solve you problem..
pls rate me.
tnx
drcool
Posted on Jul 22, 2008
SOURCE: Burning smell
We had the same problem. After we used it a few times, the smell went away.
Posted on Sep 07, 2008
SOURCE: smells like somethings burning, more
did the drum stop turning,when motors overheat they smell realy bad.
Posted on Nov 01, 2008
aborcass
  • 2651 Answers
you can unplug the unit , and reomve the lower aces panel (3 screws along the front bottom of unit) youll probalby see an excess of lint built up in which case you can vacuum it out, and then check/clean and or replace your dryer vent
Posted on Nov 16, 2008
When dryer running there is a burning smell
Clean the lint trap and make sure you have good fan operation. Check your outside vent for good air flow. Could your burning smell be electrical wiring? Does it smell like plastic burning or lint burning?
These are things one needs to know in order to locate the trouble.
Feb 03, 2016 | Whirlpool GEW9250 Electric Dryer
Only had condensor dryer aqualtis aqc9bf7 1week very bad burning smell
could just the newness or fluf got into heater keep an eye on it good luck tom
Feb 15, 2015 | Washing Machines
We purchased this product a month ago and it seems to be giving off a burning type of smell which we can smell both outside the vent and in the dryer itself. it seems to work fine
If it smells like an oily burn then it is just the oil burning off of the new parts in dryer, this is common. If it smells like electrical burning then call the manufacturer for repair. Could be a wire burning and if it is new it is covered under warranty.
Jun 14, 2010 | Whirlpool WED5800S Electric Dryer
Lent is damp dryer takes too long to dry and burning smell
Your burning smell might just be lint which has been loosened by you, getting onto the dryer's heating element. If this is the case, the smell should not last long, nor will it damage the dryer.
Sep 10, 2009 | Dryers
GE Dryer smells like its burning
the burning smell may be caused by a belt some have a look at the belt
Mar 07, 2009 | GE Dryers
Dryer stoped running
Your drive belt may have broken if it smelled like rubber burning. If that is the case then your motor bearing are worn out or something has been lodged between your dryer drum and the dryer housing. If the smell was the odor of burning plastic, then your motor is probably burned up.
Feb 24, 2009 | Maytag Dryers
Burning rubber smell and the dryer will not turn on
sounds like you need a new belt for your dryer, the smell of burning rubber is the belt slipping, thats my guess
Feb 09, 2009 | Dryers
Duet Dryer
pls rate me.
tnx
drcool
Jul 15, 2008 | Whirlpool GEW9250 Electric Dryer
Dryers Logo
122 people viewed this question
Top Miele Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Are you a Miele Dryer Expert? Answer questions, earn points and help others
