Question about RTO Automatic Transmission And Engine Oil Pressure Tester
I have an meec tools gasoline generator (740-036) The engine isnt starting. There are no spark in the sparkplug. The ignition coil is ok but there is a little box with 5 cables in to it i need that box Where can iget it? Any one know?
    Top Expert:
  • RTO Master
  • 40,734 Answers
Before you go out and spend big money have you check the low oil switch for operation. If the sump oil is not at the correct level then that switch turns off all ignition power.
Posted on Aug 18, 2013
  • Tommy K
    Tommy K Mar 13, 2016
    Hello! I cannot find any hints in the manual that i need to check it. Where can I find the oil sump filling?
  • Bill Boyd Mar 13, 2016
    there will be a ***** plug about 2" from the base plate
    the oil has to be level with that hole and that will be in the user manual
Before boost the car starts to spit and fire and boost on and of
Gasoline:1Common:Bad sparkplugs/sparkplugs wiring integrity/loose 2 Ignition platinum if apply.(ceck /under distributor cap/ also for dirt,humidity,rust,central carbon brush worn,loose,missplaced spring,eventually replace distributor cap ,if cracked,it looses spark power).3Too much gasoline.(ceck carburetor /tune) 4Very rare:ignition coil..Cheers
Oct 24, 2013 | Cars & Trucks
No spark on kohler generator 4ckm21
I don't have any idea what Carl just said, but remove the little ground wire from the coil and try to start the engine. If it fires and runs ok, you have a grounding issue somewhere and need to follow the wires around to see if anything that shouldn't be touching metal, is.
Oct 10, 2013 | Kohler CH25 PA-CH730-0040 Command Gasoline...
Toro CCR 2450, Common starting problems? Fresh gas/oil mix. Good compression. Just pulls, no pops or sputters.
Next step would be to check the ignition module(coil),I have a lawnmower that uses the same 2 cycle engine. Check coil for spark by removing the spark plug from the block then connect the insulator side of the sparkplug back to the coil then ground the plug by touching the threaded side to the block away from the sparkplug hole while turning the engine over. Should see a spark, if not you'll need a new coil,not hard to replace. calls for Briggs & Stratton #80-1268 you can also use a Toro/Lawnboy coil #99-2911 or #99-2916 or #684049.
Jan 31, 2011 | Toro Lawn Mower With Toro Power Tools
Are coil plugs on a 2003 Ford focus the same as the spark plugs or no? Also are the ignition wires the same as sparkplug wires?
Coil plugs? Honestly ive never heard of that. I would assume you meant the ignition coil or ignition coils, and no they are not the same thing as the spark plugs. Ignition coils are actually what generates an electric spark for your spark plugs.
Igntion wires are in fact the same thing as spark plug wires just a different name for the same thing.
Nov 24, 2010 | 2003 Ford Focus
Honda engine pressure washer won't start
Remove the sparkplug spray isoproxyl (rubbing) alchohol in the cylinder and on the sparkplug this will "dry out the engine" reassemble and, start the engine.
It should start as a "wet with gasoline" sparkplug can not spark nor, will liquid gasoline ignite
May 23, 2010 | Honda 8 HP Engine
No start on old gasoline forklift engine.
most likely the ign switch is ok if you are getting spark. so you have a hot spark at coil and weak fire at plugs? if you have a test light check the positive side of coil for power when turning key on and cranking. if it is dropping power on positive side then ign switch could be bad. can "hotwire" coil by jumping a wire to positive side of coil to pos of battery this will eliminate ign switch.
Apr 07, 2010 | 1978 Chevrolet C1500
The starter will turn the motor over but not start it
johnnymleder, Remove sparkplug from engine. reconnect sparkplug to sparkplug wire. Make sure sparkplug is in contact with engine cylinder head. If you don't see a spark when cranking engine over( in dark garage at night) then something will be wrong with the motor's ignition system and will require servicing it to restore operation. If you see spark then reinstall plug into the engine. Do NOT connect ignition wire!!! Crank engine for 15-25 seconds. Do you smell RAW GASOLINE at the tailpipe??? If NO you may have clogged fuel system. Have FIRE extinguisher handy at ALL times when performing work on any fuel system!!!! Good luck with repair!! 12fixlouie
Jan 12, 2010 | RTO 200cc Full Size Four Wheeler ATV
1978 YAMAHA RD400E NO SPARK ON ONE CYLINDER BIKE RUNS ON
Remove both sparkplugs from engine. Plug them back in the sparkplug cables and let them rest on the engine.
Make sure your battery is well charged.
Check for sparks while kick-starting...
Interchange the sparkplugs in the cables:
-Same plug give sparks: replace the spark plugs.
-Same side of engine sparks: interchange the low-voltage connector at the ignition coils.
Give it a try:
Same engine side sparks: Replace the defective ignition coil.
Other side of the engine sparks: Check the circuit harness for loose connectors, and/or Clean-replace the breaker points ( left side of the engine carter ).
Aug 28, 2009 | Yamaha RD 350 Motorcycles
I have a lawnmower with a BSA 3.5 engine that I cannot start, the problem seems to be no spark at the spark plug. As I have never worked on a lawnmower I have no idea what generates the spark on...
Test for spark by placing a screwdriver into the spark plug wire and holding it close to a bolt on the engine. should see a spark (blue). If not, problem is likely the armature (coil). The coil is located under the engine shroud and held in place by two bolts. If you replace this part, (normally $30 to $40) you must ensure a proper air gap. Auto parts stores have inexpensive repair manuals to help.
Lee
Cherokee Small Engines
Apr 21, 2009 | Garden
RTO Automatic Transmission And Engine Oil Pressure Tester Logo
461 people viewed this question
Top RTO Measuring Tools & Sensors Experts
jdthefixer
Steve
Vuk B
Are you a RTO Measuring Tool and Sensor Expert? Answer questions, earn points and help others
