Question about Sewing Machines
My singer 14sh564 serger was sewing just fine, and all of a sudden the threads were really loose.
  • 19 Answers
SOURCE: Singer Simple bottom thread is loose
hi there
raise pressure foot up thread making sure thread passes between thread guide this should solve problem never alter bobbin tension,
mary h
Posted on Dec 30, 2008
  • 3 Answers
SOURCE: Pfaff Hobbylock 788 Serger won't work
Does it still make noise? Maybe it needs a new belt or just some oil?
Posted on Jan 13, 2009
taran_2005
  • 10515 Answers
SOURCE: how to thread and use the Singer 14CG754 serger
Follow the simple steps  :-
http://www.ehow.com/how_2301477_thread-singer-sewing-machine.html
Thanks.
Posted on Mar 23, 2009
Michaelle
  • 65 Answers
SOURCE: How do you thread the Singer QuantumLock 5 Differential Feed?
www.singerco.com/pdf/14SH654_threading.pdf
Its a different model, but most sergers thread the same way.
Posted on Mar 30, 2009
  • 14 Answers
SOURCE: My singer serger isnt sewing..
Did you check to see if one of the needles or loopers are unthreaded, 9 times out of ten one or the other is unthreaded.
Posted on Jul 07, 2009
Can I replace the plate needle on the singer profinish serger myself
Laura's Blog: Do it yourself serger repair - How to adjust ...
bangerlm.blogspot.com/2007/.../do-it-yourself-serger-repair-how-to.htm...
Jan 30, 2007 - So I recently did something awful to my serger and the needle broke, the ... Plus it isn't really generic, it is basically some notes for some various olderSinger sergers. ... There were two screws on the bottom plate, plus 4 screws in each of ... If you thread the machine and you can't get the lower looper thread ...
How to fix timing on serger - YouTube
? 4:36
https://www.youtube.com/watch?v=BT6kiYyG2bw
Jul 21, 2013 - Uploaded by Jasmine Harris
Up and close detailed view of how to fix timing on your sergermachine ... looper and lower looper should be when the needle is up or down. .... way I can ever take it into the shop, so unless Ican fix it myself I'm out of luck. .... How to fix the upper looper timing on a Singer serger/overlocker - Duration: 11:02.
[PDF]Singer 14CG754 Serger Commercial Grade Manual.
www.sewingmachinesplus.com/media/.../singer/.../Manual_14CG754.pdf
Jan 10, 2016 | Singer Sewing Machines
I have a singer serger 14SH654, I have threaded it ok, (checked and double checked), and it's sewing ok, but whenever I go to remove the item I'm sewing the "yellow" looper always thread always breaks,...
I try not to pull the threads when removing my fabric from the serger. Instead when the fabric has cleared the needles, continue to sew a chain of about 5-6 inches, then simply cut it with scissors leaving part of the chain attached to the fabric and the rest of the chain attached to the machine.
Mar 27, 2015 | Singer Sewing Machines
I have a Tiny Serger. The thread keeps coming out of the needle when I try to make a chain. What am I doing wrong?
first try changing the needles
make sure you have long thread tails and pull them behind the needle toward the back of the serger.
make sure there is no loose thread in the looper area
Aug 18, 2014 | Singer Tiny Serger TS380
Tension off on serger
Is it the needle threads or the looper threads? The threading diagram is critical to follow, and make sure the tension discs are not stuck.
Dec 12, 2013 | Singer Tiny Serger TS380
I don't have the manual for Singer serger model # 14U555 and cannot get it threaded correctly.
I couldn't find a link to anywhere to get the manual free, but it's available for purchase from Singer here. They do have a serger threading guide here that may be helpful.
Hope this helps a little. Thanks for usin Fixya!
Feb 04, 2010 | Singer Tiny Serger TS380
Mar 30, 2009 | Singer Sewing Machines
I lost my manual and don't know how to thread the White Superlock 834DW electronic serger
Here is another singer threading manual
Should be the same.
Singer (white company) has a really good website.
You really want to reinvest in a manual for your machine, they really are a necessity.
Good Luck
Mar 30, 2009 | Sewing Machines
The threads are not tight on my serger
Here is an easy way to get your thread adjusted. Rethread the machine using four different colors. Then sew and for example the "yellow" thread is loose on the fabric, you know to adjust the tension with the yellow thread. Also a good starting place on your dials is 4-3-2-1 from left to right. Start with the tension set there and then adjust as needed.
Dec 20, 2008 | Singer 5050 Mechanical Sewing Machine
Sewing Machines Logo
24 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
