Question about Troy Garden
I have a troy bilt 690 series 190cc self propelled lawn mower that won't run. I have changed the carb, spark plug, oil, and gas. The fuel line is not blocked because when I pulled it off the carb it poured out gas before I could plug it. I borrowed my wife and she held the spark plug against a bolt on the motor and when I pulled the cord she was able to see blue sparks. I sprayed ether into the carb and I still can't get it to start. Most of the time I pulled the cord and everything spun but nothing happened. On three occasions I have been able to get the mower to start but it stops after running for approximately 1 second. I examined the kill switch and everything appeared to working. I don't know what else to check.
    Master:
  • 969 Answers
Pinch off or turn off fuel line to carb. Remove carb from engine. Remove carb bottom bowl. Observe screw that holds bowl to carb if it has a whole thru it clean it out with a bread wrapper twist after you peal back about an inch of wire. Remove float and needle, use same wire to clean out port. Use same wire to clean out center fuel pick up port in center of carb. Ensure upon reassembly the float is free to move. Float up no fuel flow, float down fuel flow.
Posted on May 24, 2014
highspeedsan
  • 61 Answers
SOURCE: 6.75 B and S push mower wont start.
Check the kill switch. It may be stuck in the off position.
Posted on Apr 26, 2009
  • 93 Answers
SOURCE: BRIGGS/STRATION 675 SERIES, 190CC SELF PROPELLED
Rust on the Flywheel and Magneto wire brush off., Pluged Fuel Filter or Bad Gas.
Posted on Sep 14, 2009
RonInFla
  • 86 Answers
SOURCE: Troy Bilt lawn mower used months 2009 will not
stale gas in carburator...take the screw out of the bottom of the carb and let the gas run out...
Posted on Apr 18, 2010
  • 152 Answers
SOURCE: LOOKING FOR A MANUAL FOR A 21" CUT SELF PROPELLED
try putting your serial number and model number here. http://www.troybilt.ca/troybilt/troybilt_manual_search.asp
Posted on Aug 08, 2010
  • 251 Answers
SOURCE: My Troy Bilt self propelled
Hi , it can often be something as simple as the engine needing a oil change as oil looses viscosity/thins with use ( use correct grade ), replace or clean the oil filter and a good service or something more complex which requires a full engine stripdown like worn piston ring/oil scraper ring causing oil to flow up the cylinder walls and fouling the combustion chamber or oil leaking up through the valve stem oil seals , also storing the machine tilted can cause oil to collect in the chamber or petrol to leak into the sump causing the oil to thin.
Hope this helps , please rate accordingly
Posted on Aug 31, 2010
What is the spark plug gap seting fot Champion RJ19LMC?
.30 is the standard for most lawn mower engines...you might check the "engine specifications" in your owner's manual to be sure.
Aug 22, 2014 | Troy Bilt 5.5hp Self Propelled Mower
Mower will start but runs rough & stops
Is the carb flooding?is there black smoke coming from exhaust when running, if so it could be the carb over filling with fuel. Is there petrol leaking out of the carb? If not check the fuel pipe is in good condition
Jul 22, 2013 | Briggs & Stratton Lawn-Boy Insight Series...
Where is drain plug for oil on Troy bilt Tb230
It does not have a drain plug. You can remove the dip stick and tilt the mower to pour out the oil, or you can use one of those hand pump syphon units to pump it out.
Mar 23, 2012 | Briggs & Stratton Lawn-Boy Insight Series...
My Troy Bilt self propelled lawn mower keeps fouling spark plug out after one use. Why?
Aug 31, 2010 | Troy Bilt 5.5hp Self Propelled Mower
I have a troy bilt mower with a briggs & stratton engine. How do I change the oil?
There should be a drain plug on the underside of the mower deck. Raise that side of deck, remove the plug and drain the oil. Replace the plug and add new oil. Hope this helped.
Jul 18, 2009 | Briggs & Stratton Lawn-Boy Insight Series...
Apr 26, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Garden Logo
61 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Wade Mobley
Wade Mobley
Mike Squire
Are you a Troy Garden Expert? Answer questions, earn points and help others
