Question about Pioneer PureVision PDP-4304 Television
HDCP issue. Apple says I need a firmware update. My model number returns no results on the Pioneer website.
2 Suggested Answers
  • 5344 Answers
SOURCE: need a firmware update for
The current firmware update for the Pioneer BDP-05FD is available from Pioneer: http://www.pioneerelectronics.com/PUSA/Home/Blu-ray-Disc-and-DVD/Elite-Blu-ray-Disc-Players/BDP-05FD . Click on the Firmware tab then download the .zip file (titled firmware upgrade). Extract the contents of the file.
Burn the .ISO file that is inside the .zip file to a new CD-R (or CD-RW) using your burning software. (If you have Win7, you can use the included burning software to do this. Just right-click on the iso in the file explorer and choose Burn Disc Image.)
Then check that the disc has the needed files and that the files are the correct size: DLfile.pkg 95.3Mbyte (99,942,480byte), .DLdiscidentifier.txt 93byte, DLdiscidentifier.txt 93byte (for v1.71)
Then put the upgrade disc into the player (work with the controls on the front of the player instead of the remote). Then wait until the disc ejects (do not power the unit off or unplug it). Remove the disc and then turn the unit back on. You should see various information show up on the screen that will indicate that the upgrade is in progress. If it doesn't give the prompts, then you may have an unreadable CD. Try burning a new disc at a different write speed (lower); try using a different burner/computer if problems persist.
I hope this helps.
Posted on Aug 05, 2011
I have a 2009 Lg 37lh30 Tv and for the most part it works until recently. I am now getting a HDCP rejection when using an Apple tv or Roku and no screen when using my bluRay Player (which use to work
Some TV's & cables are not HDCP compliant . Sometimes you can replace the cable to fix the problem & other times you have to replace the tv because its not HDCP compliant . First check to see if your tv is HDCP compliant .
Jan 03, 2015 | LG 37LH30 37 in. LCD HDTV
Tip
Known ram issue
With the aspire 5100 series there is a known issue with ram that causes all sorts of glitches, freezing and reboot. Upon a ram test, the ram will say errors accross the board and replacing the ram will yield the same result. The fix is to update the bios firmware and it will resolve the ram issue. Go to acer's website and click on support and drivers, type in your model number and get the latest bios update..follow the bios update instructions on the site.
on Apr 26, 2009 | Acer Aspire 5100 Notebook
Momentus 5400 fde.3 formatting error
Which operating system ?
If windows 7 click start richt click on computer select properties then device manager scroll to your disk (hard drive) expand right click select update drive software
Every Seagate drive requires a few firmware updates during its lifetime.
Seagate firmware must be up-to-date to ensure that the product will run reliably.
Changing the firmware on a Seagate product to a more updated version will improve the product's performance.
Check the Seagate website often for any update available for your drive.
The firmware can be changed with just a few clicks of your mouse on the Seagate Web page.
Click the "Start" button on the bottom-left corner of the screen.
In the window that pops up, click " My computer " or just "Computer."
Another window will show up with an icon for your hard drive.
Right-click the hard drive icon and press the "Properties" option.
This will tell you what model your hard drive is.
For example, your hard drive might be ST31500341AS.
Open your Web browser. Type in www.seagate.com and press "Enter" on the keyboard.
Wait for the webpage to load.
Enter the word "Firmware" and your model number in the search box on the upper right hand corner of the webpage and press "Enter" on the keyboard.
Using the example from Step 1, type in "Firmware ST31500341AS".
Click on the first link that is returned in the search results.
Locate the firmware update. Double-click the update.
Press the "Download Firmware Update Utility" link to start downloading.
Click yes on any pop-up boxes that you may see.
Open the new firmware file by double clicking the file that you downloaded in Complete the installation by accepting all of the default questions that are asked during the installation process.
Hope this helps
Nov 03, 2012 | Seagate Momentus 5400 FDE.3 320GB Hard...
Fix pinter head
The error can be the result of firmware code, printer contacts or the printhead itself failing. A firmware update for your Lexmark model addresses printhead issues. Please visit the Lexmark website to download and install the Lexmark Firmware Update. Select your corresponding model in the list to start the download. If more than one download is listed for your model, choose the first download in the list. If it is the wrong firmware level, an error message will tell you which firmware level is correct.
Should the problem continue even after updating your printer, please contact Lexmark Technical Support Center for additional assistance.
Feb 12, 2012 | Lexmark Office Equipment & Supplies
I can't write BD-R 2X25 GB, LTH tipe!
Hi, I would like to help you out.
There is a small understanding needed when it comes to this single layer blue ray disc. The main sources say that there is a compatiblilty issue with your BD burner, If your BD burner is a 2009 or later model there is no issue, it'll work fine with almost all the manufacturers like panasonic, sony, pioneer and so on. However if the Blue ray hardware was manufactured before 2009. we need to check the manufacturer's website for firmware updates. It'll work fine once the firmware is updated.
I can help you better if you can tell me about your BD burner's manufacturer or you can understand a lot by checking this website to know which manufacturer's firmware needs to be updated.
Please take a look a look at this website for better understanding, so that my explanation may not look like its too hard to understand :)
http://www.verbatim.com/UserFiles/File/BDR%20LTH_JulyCompatibility2010.pdf
please let me know if you need more help. Good luck
Please vote if you think this solution will help others. Thank you:)
Oct 25, 2010 | Computers & Internet
I have a CDJ 1000. Is there a firmware update? How would I do it?
CDJ1000 Mk1 & Mk2's need to be sent to Pioneer or Videotec for firmware updates, Mk3's software can be update from CD. Visit the Pioneer website for the file (to burn to disc) and instructions.
http://www.pioneerdj.eu/uk/content/support/support/upgrade/CDJ1000MK3.html
http://stores.ebay.co.uk/methleykev
Oct 03, 2009 | Pioneer CDJ-1000 CD Player
HDMI port not working
I have the same problem - its a HDCP handshake issue. Sony says the firmware in the Westinghouse TV needs to be updated - Westinghouse says that they have firmware updates for some models depending on your TV's serial number, otherwise they are working on firmware updates for the rest of us that should fix the problem. Call Westinghouse to see if you can get updated.
Jul 13, 2009 | Westinghouse SK-19H210S Television
IStat reads 126 degrees on Macbook - and gets very slow
Perhaps it is a software or firmware issue.
Make sure you have updated you mac to the latest firmware possible via software update. To get to this, click on the apple in the top left hand corner of your screen and select software update.
If that doesn't fix it, then perhaps doing a complete reinstall of the software will help, followed by updating your software using the method previously mentioned.
If this still doesn't help, then it would be a good idea to bring it into apple.
you can find a local apple reseller by calling apple on 1-800-MY-APPLE
Or you can visit an apple retail store by visiting http://www.apple.com/retail/
Hope this helps.
Nathan.
Apr 14, 2009 | Apple MacBook Mac Notebook
Pioneer dvr 112d power calibration error
updated firmware will not help. this is a known issue with Pioneer DVR-112D, drive needs to be replaced. Contact Pioneer for a free replacement, here is the url http://www.pioneerelectronics.com/PUSA/Support/Important%3A+Notice+Regarding+CD+Read+and+Write+Functionality+in+Certain+Pioneer+Computer+Drive+Models
The issue occurs only under limited environmental and use conditions that are not typical for most end users, so Pioneer anticipates that most users will not be affected. If you are not experiencing any issues currently, there is no need to take immediate action. The service issue does not pose any health or safety risk.
Pioneer is aware of a potential issue with the above drives’ CD (not DVD) read/write capability. Under certain environmental and heavy use conditions, the above drives may become unable to read or write to CDs. To address this issue, for any of the above model drives that become unable to read and/or write to CDs, Pioneer will provide a replacement unit (which may be a newer model number) at no extra charge, shipping prepaid, subject to the terms and conditions of Pioneer’s standard limited warranty(excluding duration).
Again, we anticipate that most drives will not be affected. However, if your DVR-1810, DVR-2810, DVR-X122, DVR-112D, DVR-112DBK, or DVR-112DSV drive becomes unable to read or write to CDs, please contact Pioneer Customer Service by one of the following methods:
Complete an online replacement request form and submit it online. Once your model and serial number are validated, you will print out the completed form to mail along with the affected drive.
This online form is for United States customers only. For Canadian residents, please contact Pioneer Electronics of Canada customer service directly at 877-283-5901.
Mar 07, 2008 | Pioneer DVR-112D DVD RW Dual Layer Burner
Pioneer PureVision PDP-4304 Television Logo
26 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
