Question about Sony Alpha DSLR-A230 Digital Camera
Reinsert SD card - Sony Alpha DSLR-A230 Digital Camera
Shows 'BUSY" all the time however low the quelch & with full power batteries
sd card fault sd card full.1 reinsert card, 2 change card for new one,3 remove unwanted pictures to free up some of the sd cards memory
Sep 03, 2015 | Cameras
New 164GB SD card when put in to either of my 2 cameras a message reinsert card appears on screen. No further operation can be done until card is removed. Can this problem be fixed?
The 64 GB cards are not SD cards. They are SDXC cards and need a different interface. The card lloks the same, but the electronics is different. Your camera or any device you are using should be SDXC compatible.
On this page, scroll down half a page and look how the compatibility works for SD, SDHC and SDXC.
What SD Information SD Card Panasonic Global
Apr 01, 2015 | Cameras
My problem, when I will take a photo, there is text "reinsert your SD memory".maybe sd memory is error or broken?
What model Sony camera? Is your memory card an SD card or an SDHC card? What size is the card?
Feb 04, 2013 | Sony Cameras
I reformat my sd card in the computer to remove all the photos the when im using it in my sony cybershot camera it appears "reinsert memory card" how can i fix the it to use it again in the camera
When you need to delete the photos from the SD memory card, do not use your computer to do it. Use your camera to format the SD memory card.
To fix this problem, insert the SD memory card in your camera then go to the camera's Menu and format the SD memory card.
Nov 03, 2012 | Sony Cyber-shot DSC-W80 Digital Camera
Getting a message "card locked"
You didn't specify the type of memory card, so I assume it's an SD/SDHC card.
SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Jul 30, 2012 | Cameras
How to fix reinsert memory card from sony DS - W330 digital camera?
Hello.
Remove the SD card then replace it back. If you are still having a problem, format the SD card using the camera. If that still doesn't solve the problem, you need to replace the SD card with a new one.
Aug 09, 2011 | Sony Cybershot W330 Digital Camera
My camera displays "No SD card" when I do have a
Hello beach.... remove the sd card and check the perimeter of the card to find the locking mechanism. If the card is in the lock position, move it to unlock. Then reinsert the card, turn on the camera and go into the menu. Find format. Format the SD card and then it should be good. Joe
Thanks for choosing Fixya!
Jan 04, 2011 | Bushnell Trail Scout 11-9830 Digital...
Reading Card Error. followed instructions to turn off and reinsert but the problem still exists
The ZR85 is only capible with an SD card. A SDHC card will not work. SD cards only go up to 2GB, no higher. Make sure your card is 1) not SD HC and 2) no larger than 2GB.
Jul 03, 2010 | Canon ZR85 Mini DV Digital Camcorder
Music aint on my phone
Save the music onto the computer from the SD Card. Format the SD Card, It should give you this option in the phone and on the computer in my computer. Redownload the songs to the SD Card and try to reinsert the card. See what happens...
Dec 07, 2009 | LG Vu CU920 Cellular Phone
Recovery mode
For those with the 4 GB model, try removing the SD card and powering completely off, without selecting any of the recovery options.  You will probably get prompted to recover when the device boots, click OK to recover - do not reinsert the SD card.  Perform a complete power off and power on cycle without the SD card.  If this works, reinsert the SD card and perform a power off/power on cycle.  If it prompts you to recover the system, the SD card is bad (the data can probably be read by the device after it has restarted, but will continue to cause the recovery mode).  Note that reformatting the card in the device does not seem to resolve the issue.  Try reformatting the card in a PC or digital camera (this option worked for me).
Jun 13, 2008 | Archos 605 WiFi Digital Media Player
Sony Alpha DSLR-A230 Digital Camera Logo
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
